SD14 to EOS conversion
Started Aug 7, 2008 | Discussions
Arky Regular Member • Posts: 434
Works perfectly on my EF lenses. It actually has an EF-S mount but I think some (most?) EF-S lenses protrude too much and would hit the dust protector. I don't have any IS lenses so I don't know if IS works, probably not.
This EF 85mm f/1.2 L can't be converted to SA, the rear element is too big to fit in the smaller SA mount.
My grand-daughter generously agreed to pose for some portrait samples with that lens. The first is wide open at f/1.2 for the bokeh, the second is stopped down to f/2.5 for DOF and sharpness.
For pixel-peepers, the originals direct from SPP can be found here:
http://www.pbase.com/bigflat/sd14_to_eos_conversion
I'm mostly color blind, so my apologies in advance for any annoying color cast. I processed these with auto white balance in SPP.
-Jerry
 Arky's gear list:Arky's gear list
Sigma SD1 Merrill Sigma DP1s Sigma SD14 Canon EOS 50D Canon EOS-1D Mark II +14 more
lita Regular Member • Posts: 140
Re: SD14 to EOS conversion
Hi:
I don't know if I am missing something here, but is your post the original one on this thread, as I would like to know a bit more about this conversion.
Did you do it yourself: can you expand a bit on the process?
Is the autofocus working?
Are you using the Sigma contacts to link to your EOS lenses, if not how do you change the aperture?
Are you using other EF lenses, or did you do this conversion solely for the 85mm F1.2.
If this has been answered somewhere else, please be kind enough to refer me.
Thanks.
OP Arky Regular Member • Posts: 434
lita wrote:
Yes, I did it myself. I installed the mount, electrical pinset and locking pin from a canon camera into the SD14.
Yes, AF and aperture work normally.
I replaced the Sigma pinset with one from a Canon body, and soldered its leads to the SD14 internal pin circuitry.
for the 85mm F1.2.
I have other EF lenses too, Canon 50mm f/1.4, 135mm f/2 L, 200mm f/1.8 L, Sigma 100-300mm f/4 EX and 80- 400mm OS EX. The Canon 85mm f/1.2 L is the only one that can't be converted to SA mount on the lens.
refer me.
The compatibility between the electronics of the of the EOS and SA mount has been discussed here before. Search my history, I don't post very much, but I sometimes weigh in on these threads. As far as converting a SD14, I'm not aware of it being done before, although it has been done on the SD9.
Thanks.
docmaas
docmaas Veteran Member • Posts: 7,023
Congrats! Jerry. Looks like you got a canon lens lock in place. Overall looks like a very nice job. I gave up on mine after deciding the canon lenses weren't the holy grail I thought they were. I got some Zeiss glass and were I to do a conversion now that is the direction I would go but the shallow depth in front of the IR cutoff filter is a limitiation with those lenses as well unless you modify the lens.
At this point I think I am going to go the dp-1 direction and simplify.
Mike
People do not seem to realize that their opinion of the world is also a confession of character.
  • Ralph Waldo Emerson
the lens.
Mike
Thanks Mike.
I did it for convenience more than anything else. Also the availability of extension tubes the ability to rent lenses like the EF tilt/shift series and other niche lenses to try out before buying.
Good luck with your DP1.
-Jerry
Tom Rowland Veteran Member • Posts: 5,891
Arky wrote:
SNIP
My biggest single gripe about Sigma is no ET. I have captured some great macro images using both my Canon 500/f4 and Sigma 300-800 with stacked extension tubes and my Canon bodies.
The detail is good; but not up to the standard my sd10 or sd14 get with a Sigma 150 macro.
I would love to try out tubes and the sd14 on the 300-800; it finally gives me the working distance I need to get skittish insects to fill up the FOV.
Thanks for sharing.
Those who forget history are condemned to go to summer school.
Tiffles Veteran Member • Posts: 5,042
 Tiffles's gear list:Tiffles's gear list
Sigma DP1 Sigma DP1 Merrill Sony RX1R Nikon D700 Sigma SD10 +7 more
LUIS A GUEVARA
LUIS A GUEVARA Regular Member • Posts: 413
-Jerry
Oustanding work Jerry !! Many people said it couldn't be done , including myself . I am glad to have been proven wrong .
I can see that 3 of the Face Plate screws have been countersunk to mate with the existing SD14 attachment points , by using the presence of the Bayonet Lips at those positions , something that could not have been done for the other 3 due to the absence of those lips at those positions. That was very clever. Now what about the original Canon screws that can be seen in place ,are they threaded into the Body or are they Phony?
The big question is , since your Faceplate seems to be not sitting as deep as the original SA , can you Focus at Infinity?
For what is worth I am preparing a Special Milling rig that will allow me to create a precision recess in the Mirror Cage so the IR/Dust Filter will sit about an extra Millimeter Deeper , which is ,I believe , as much as you can go without having the Mirror hit the Filter, and or perforating the cage .In the case of the Leica 35mm f1.4 Summilux is all the extra clearance that it needs. Maybe that would also solve your problems. I invite you to email me directly to luis@sigmacumlaude.com to exchange some ideas and information.
Luis
http://photo.net/photos/Luis-A-Guevara
http://www.pbase.com/luis_a_guevara/galleries
http://luis-a-guevara.deviantart.com/
http://gallery.leica-users.org/v/LUIS+A+GUEVARA/
http://www.summiluxart.com/
http://www.sigmacumlaude.com/
LUIS A GUEVARA wrote:
Thank you Luis.
The 4 canon screws are actually threaded into the mirror box, but the plastic isn't very thick at those places. I wouldn't trust those screws alone to solidly support a heavy lens. The 3 sigma screws, together with the stainless steel mount provide a very solid attachment. I would trust them even without the 4 canon screws.
I'm not sure why you think it doesn't sit as deep as the SA. The EF mount was .007" thicker than the SA mount so I shaved .007" off the front of the mirror box to keep the same registration distance. I can actually focus past infinity. When focused at infinity, the indicator on the distance scale lines up with the infinity mark the way it should. Maybe since the pins set deeper in the EOS it makes the face plate look not as deep.
I had to mill out the port side of the mirror box deeper, to allow clearance for the EOS lens contact module. The dust protector sits in its original position and doesn't interfere with any of my EF lenses so I guess I can live with it as is.
Thanks for your interest Luis.
-Jerry Boyd
LUIS A GUEVARA
It was just an impression from your photographs, It is incredible how much Serendipity worked on your favor , for example the place required for your Release Button landed right in between the 2 small push buttons on the side althewhile allowing the lens markings to line up perfectly the way they should.
This lens certainly look impressive . Is it my idea or you had to Mill the Pentaprism Housing to accommodate its large Diameter?
Again , congratulations for your achievement .Luis
Pvuong Regular Member • Posts: 335
Hi Jerry,
Thanks for sharing the information to us.
I would like to modify my SD14 too!
Do you have any recommendation?
Which Canon body model should I buy and use as a conversion parts
For mount, electrical pins set also a locking pin.
Thanks again!
pvuong
 Pvuong's gear list:Pvuong's gear list
Leica Q2 Sony RX100 III Sony RX10 IV Sony RX1R II Sony a7R II +8 more
Both of those buttons still work too. Believe me it wasn't easy to keep the functionality of the DOF preview button. I really don't know why I bothered with it so much, I rarely use it.
I did mill the front cover to allow clearance for the girth of that lens. the actual internal pentaprism/flash housing is untouched.
Pvuong wrote:
Hi Jerry,
I would be very careful if you want to try the full electrical conversion. The entire mirror box must come out of the body to access the pinset circuitry. As the mirror box comes out of the camera it disengages from the shutter and the shutter clicks into the uncocked position. Don't just try to put it back together while holding the shutter in its cocked position. I tried that and ended up with the dreaded stuck mirror syndrome. Luckily no permanent damage was done but I found out later that could have very easily stripped the gears in the mirror shutter drivetrain. The 2 sets or mirror box gears and the shutter control tabs must be timed together upon reassembly like the camshafts on a engine. I know a camera repair technician that reinstalled my mirror box but even after watching him and listening to his explanation, I don't think I would attempt to put one back together without his supervision.
The parts I used came from a junkbox so I'm not really sure of their origin. The mount is an EF-S so it must have come from a DSLR, it is stainless steel. Most of the older EOS film SLRs have either a plastic or brass mount so I would stay away from those. I would imagine the pinset and locking pin are all about he same.
Thanks again!
pvuong
DaSigmaGuy Forum Pro • Posts: 12,312
Thank you Luis.
I'm not sure machining of the mirror box was necessary at all given that the EF and SA mounts both have the same registration distance (44mm).
I can
Maybe a consequence of the possibly unnecessary machining you did?
 DaSigmaGuy's gear list:DaSigmaGuy's gear list
Fujifilm FinePix F660EXR Sigma SD10 Sigma SD14 Samsung Galaxy S7 Samsung Galaxy S9 +26 more
DaSigmaGuy wrote:
Thank you Luis.
(44mm).
Okay, here's a thought exercise for you Alf. The mirror box plus the thinner SA mount together measure 44mm thick. Now imagine the same mirror box with the thicker EOS mount. Is the assembly still 44mm thick?
I can
No, actually it's due to the fact that all modern SA and EOS lenses are designed to focus past infinity. As I previously stated, the distance scale on the lens is accurate. That's the acid test for checking registration distance.
What is wrong with brass?
Yes, it is quite possible that a lot of older EOS EF mounts are plated brass, but why would one stay away from those. Too hard to pierce?
Thanks.
Re: What is wrong with brass?
lita wrote:
No, brass is much easier to machine than stainless steel. I actually made a mount from brass and then decided it needed the extra rigidity and shear strength of steel.
