Maxxum 5D, 7D max CF card size
Started Aug 4, 2008 | Discussions
hcoley Senior Member • Posts: 1,223
My father has a Maxxum 7D. He cannot find his manual and I cannot find the support site for it. Can anyone help out by telling me what is the largest capacity CF card these guys can use and if there are any other specification limitations on CF type?
Thanks!
'I got a Pentax camera. I love to take a photograph, so mama don't take my Photoshop away.'
 hcoley's gear list:hcoley's gear list
Pentax K-01 Pentax K-50 Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 50-200mm F4-5.6 ED +17 more
Jersey Girl Senior Member • Posts: 2,623
Re: Maxxum 5D, 7D max CF card size
Thanks!
All the manual says is Type I and II CompactFlash cards and Microdrives are compatible. To my knowledge there is no restriction on capacity. I tend to use 2GB cards just because I don't want to lose 4 or 8GB of photos on one card.
You can download the manual at:
http://ca.konicaminolta.com/support/manuals/digital_cameras/dslr/index.html
I would suggest saving a copy and putting it on a CD for your dad.
Norma
Long S Hwang Forum Member • Posts: 75
4G works fine on my KM5D. I have not tried anything larger than this.
OP hcoley Senior Member • Posts: 1,223
Thanks all !
EvilOne
EvilOne Forum Pro • Posts: 14,627
when the 7D came out 4 years ago, there wasnt anything larger than 2 gigs... so the manual would not reference anything bigger .. 4 GB works with no problem..
Bill
Capturing memories, one at a time.
Please visit my galleries at
http://evil-twin.smugmug.com/
 EvilOne's gear list:EvilOne's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 990 Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 +5 more
ctwyatt Regular Member • Posts: 253
7D manual
If your father still needs the manual try here. I downloaded my copy here and just printed it out at work
skip
NM Guy Contributing Member • Posts: 620
Can't add anything to your question that hasn't been said before, I use a 4G card regularly.
Can add that I really like your tag line though.
thx
NM Guy
RogerRex Veteran Member • Posts: 3,322
I have used Extreme III and Ultra 8GB with no problem.
http://rogerrex.zenfolio.com/
Renato1 Veteran Member • Posts: 3,385
8 Gbytes Maximum!
We discussed this a while ago, and I posted the results of lots of testing with my cards on the 5D and 7D.
8 Gbyte CF cards work fine.
16 Gbyte CF cards work fine until they are half filled up, and then odd things start happening and the shots you take appear to be stored on the card, but then aren't.
Renato
hardwood New Member • Posts: 1
Re: 8 Gbytes Maximum!
Please remember to format the memory card. The camera, KM 7d can format the card. I am under the opinion that the manual is ignored sometimes because we are in a hurry to use the camera, read it. The manual will eliminate problems later. As for memory size I am experimenting since the manual didn't state size.
 hardwood's gear list:hardwood's gear list
EvilOne
Your first post !  Welcome to the forum. Since you didn't notice, you are answering a thread that is 9 years old. Most of the people in this thread are now dead. I'm the only living survivor and still use my 7D on occasion. Its still a great camera . : )
Bill aka ET
Taken with my KM 7D when this thread was just started back in 2008
EvilOne
KM 7D... still looks good
photographer1954 Junior Member • Posts: 34
This is an old thread, but to give a reply, I am using a SanDisk Extreme 32 GB  CF Card in my Konica Minolta A7D (Japan) Same as the  Maxxum and Dynax 7 D model. The card works fine so far with no problems. I've never read or heard of the capacity limit size  of a CF card that can be used on a 7D.
unclebrudy
unclebrudy Contributing Member • Posts: 575
Curious if this held true once you got past a certain capacity/filled it up completely. I'm still shooting my many 2 or 4gb cards and while I've never had a problem, the notion of seeing my 5D's ticker in the thousands would be pretty sweet. Thanks in advance if you do respond!
Just a Maxxum, an Alpha, and crossed fingers.
 unclebrudy's gear list:unclebrudy's gear list
Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-T3 GoPro Hero6 Black Fujifilm XF 18mm F2 R +6 more
Mr Voice New Member • Posts: 1
I know this is an old thread, but updates are always useful. I have just installed a SanDisk Extreme 16 GB UDMA CF Memory Card and it works flawlessly in my Konica Minolta Dynax 5D on single or continuous adv.
photogeorge
photogeorge Contributing Member • Posts: 707
I'm not dead yet.  I think I probably read that thread in 2008.  My 7D is still in fine working order.   I even still have a handful of working memory sticks and CF cards up to 16 gig.  I still have a working Minolta 5600 HS flash.   Good stuff lasts for a very long time.  The new Sony e-mount gear is too expensive and I read people have problems with that new gear too.  My A-mount gear keeps chugging along.
darobin1 Regular Member • Posts: 428
OK, so has anyone managed to get a 32 GB CF working in a 7D?
 darobin1's gear list:darobin1's gear list
Canon PowerShot G5 Canon PowerShot G6 Minolta DiMAGE A1 Konica Minolta DiMAGE A2 Fujifilm X-S1 +5 more
neilt3
neilt3 Veteran Member • Posts: 3,008
32 GB ?
That's a hell of a lot of shots needed to fill up a card from a 6mp camera !
I think I have either a 4 or 8 GB card in mine .
Even on a few weeks holiday  there's space to spare .
Also if you've read this thread you'll have noticed one post stating that after a certain amount has been stored , while the card seems to be storing them , it isn't working right .
Three quarters of the shots you take might be lost , and that's a sh*t load of shots to risk loosing !
Why take the risk , these small capacity cards like 2 or 4 GB are no use in today's 24mp cameras shooting RAW , so use them in your older cameras and stick the big cards in the new cameras .
Dead easy .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Joseph Balson
Joseph Balson Regular Member • Posts: 299
I just tested the sandisk extreme pro 32gb in my 7D.
format worked, the display says 2546 photos remaining in raw+jpg. With 16GB card it says 1273.
No issue whatsoever, the 32GB works.
It's just some glass, some silicon and magnesium. It isn't a religion.
neilt3
Let us know when you've got 2546 images on the card .
Even though the camera formats the card and says it'll hold that much , people have had the problem that once it's got a certain amount on it , it doesn't store any more .
So it seems to be working fine untill you get home and can't transfer the full days shoot to your computer .
That's where the problem is .
Whether this affects all cards is unknown .
