EXIF Brightness Value (what is it)
Started Jul 28, 2008 | Discussions
Brian Salyer Senior Member • Posts: 1,096
Hello,
I have searched and have not found anthing that explains what the "brightness value" in the exif information is on an S5 file.
I recently shot a wedding Saturday. We did all the formal shots with two monolights set to meter F8 at 125 ISO400. Set the camera to the same settings in manual mode. Did a custom white balance and we were off to the races. No exposure comp.
I shot in F1 mode with a +1 on sharpness and +1 on color.
I shot jpg large fine + raw.
The images looked great on the lcd and the histogram looked right on the money.
Upon opening them up after the wedding. The images are a touch on the dark side. An auto level in photoshop brightens them right up and of course I have the raw files to work with.
However the exif data shows a -1..... in the brightness value.
I have no idea what this is or if any camera settings affect it.
Any thoughts would be greatly appreciated.
Brian
ej64 Regular Member • Posts: 226
It's the average scene luminance
It's an ASA standardized brightness value of the avarage scene luminance. It is used within the APEX system.
Have you ever bothered using wikipedia?
http://en.wikipedia.org/wiki/APEX_system
best regards
Eberhard
my site: http://www.ej64.de -- galleries, blog (german) and other stuff
DiDo Regular Member • Posts: 346
Re: EXIF Brightness Value (what is it)
not really sure about it. i made a control with a photo of the following parameters:
ISO Speed 200, f-stop 6.7, shutter speed 4.5 sec. the S5-Brightness is -2.5. the correct result with the formula in the tutorial is 9.4. What isi wrong??
no, your Fuji is right
read the above posted wiki-link.
Bv = log2 (A² T/Sx/N)
A= Aperture, here 6.7
T= Time in s
Sx= ISO speed
N= konst. ~ 0.30
=> Bv = log2 (6.7² 4.5/200/0.3) = log2 (0.166) = -2.588
For you can't compute a base 2 logarithm on most calculators, you can use a simple base change:
log2 (0.166) = ( log (0.166) ) / ( log (2) )
best regards
Eberhard
Mike Wee Contributing Member • Posts: 662
Re: It's the average scene luminance
Eberhard,
Do you know if this is the sensor-measured value or the calculated value from shooting parameters?
Ex-Tee-Eye * Fifty mm 1,8 * Seventeen-Eightyfive mm 4,0-5,6
En-Ee-Ex-5 * Sixteen mm 2,8 * Eighteen-Fiftyfive mm 3,5-5,6
 Mike Wee's gear list:Mike Wee's gear list
Sony RX100 II Canon EOS 400D Sony Alpha NEX-5 Sony a6000 Canon EF-S 17-85mm f/4-5.6 IS USM +11 more
ShortCipher New Member • Posts: 8
Re: no, your Fuji is right
There's a typo in ej64's example.
6.7² 4.5/200/0.3 = 3.366
It should be
6.7² /4.5/200/0.3 = 0.166
nixda Veteran Member • Posts: 5,515
It should be
Haha, this might be a record for resurrecting the oldest thread.
 nixda's gear list:nixda's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Vic Chapman Forum Pro • Posts: 10,694
It should be
Trying to correct the calculation after 9 years have passed is bad enough - but to incorrectly correct it is even worse - where is this phantom 3.366 you mention?
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
It should be
No, no, he is right. The way it reads in ej64's post is:
6.7^2*4.5/200/0.3
and that gives 3.367
But it should be 6.7^2/4.5/200/0.3, which gives 0.166
nixda wrote:
It should be
6.7^2*4.5/200/0.3
I'll take your word for it. It's all double Dutch to me. I missed 2 years schooling through ill health (13/14) and was in full time work at 15.
Vic
