D700 scan
Started Jun 30, 2008 | Discussions
heavymeister Contributing Member • Posts: 534
D700 scan
Will translate later when more time.
HM
rhlpetrus Forum Pro • Posts: 26,874
thanks!
They don't say much about the prism, if same as in D3 or not.
But dust removal and built-in flash great! They also say price is 2,500Euro, 2,000Uero less than D3. This would translate to a similar value in dollars, since D3 is now 4,800 USD in the US. Likely lauch at 3,000USD but prices will start to drop soon.
Regards, Renato.
http://www.flickr.com/photos/11435304@N04
OnExposure member
http://www.onexposure.net/
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
gefrorenezeit Contributing Member • Posts: 564
Re: D700 scan
Many thanks for this scan! I am very tempted to sell my D2X to get this baby - i like the available light performance of the fx sensor and the fact that my beloved 1.2/55 is stil exactly that. :))
Greetings Andy
whatever you do - do it with passion.
http://www.gefrorene-zeit.de
 gefrorenezeit's gear list:gefrorenezeit's gear list
Sony RX100 VI Sony a7R II Leica Noctilux-M 50mm f/0.95 ASPH Sony E 20mm F2.8 Sony FE 55mm F1.8 +3 more
David Chin Forum Pro • Posts: 11,670
Thanks for the nice scans! (nt)
Regards, David Chin
http://nikond700.dpnotes.com/
Edmond Wong Contributing Member • Posts: 575
Re: D700 scan
Thanks. I hope it will be available soon !
Edmond
fabgo Senior Member • Posts: 1,300
This thing is as heavy as the D2x! (nt)
Fabian
Wonder what's ...
... contributing to all that weight?
Regards, David Chin
Antonio Rojilla Senior Member • Posts: 1,242
How do you open the CF door?
How do you open the CF door? It seems you do it from the side of the grip and not from the back as in the D300. There is anew buttom there labeled... Info?
Re: Wonder what's ...
Bigger viewfinder/prism, bigger shutter, bigger sensor, bigger LCD...??? The only extra you get with a D2X is an 'empty' battery grip... add the battery to the final weight...
Regards.
Regards, David Chin
Matthew Austin Regular Member • Posts: 214
Re: How do you open the CF door?
Does it look taller than the D300 to anyone? I for one am hoping it'll be nicer to hold than the D200/D300 size bodies, yet remain more compact than the D3.
I dont like the fact that it has the zoom controls from the D300, i dont see whats wrong with the D200/D3 method of zooming.. so why change it?
 Matthew Austin's gear list:Matthew Austin's gear list
Fujifilm FinePix X100 Fujifilm X-Pro2 Nikon D850 Nikon AF-S Nikkor 50mm F1.4G Fujifilm XF 35mm F1.4 R +2 more
Fair points ...
It's interesting that the Canon 5D is a fair bit lighter :> http://www.dpreview.com/reviews/canoneos5d/
Regards.
Regards, David Chin
dasams
dasams Senior Member • Posts: 1,078
Cosmetic Changes from the D300
1. Round eyepiece w shutter and new style diopter adjust
2. Orientation of the AE-L and AF-L button
3. Release lever for CF card (on side?)
4. Info button moved from the 'protect' button to position adjacent to CF light
5. Lack of LCD screen cover
6. New style covers on 10-pin remote and PC sync
7. Raised bar separating playback and delete buttons
Others? dave
 dasams's gear list:dasams's gear list
Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 200mm f/2G ED VR II
OrangeBullet Forum Member • Posts: 50
The given weight is WITH the battery
As crappy as my German is, I think that "gewicht mit akku" means "weight with battery".
If that's the case, then the camera is only about 100 grams heavier than 5D.
Re: Fair points ...
Yes, it is lighter, but compared to the (rumored) D700 it misses:
  • Weatherseals (same as D300 I guess).
  • Built-in flash.
  • Sensor cleaner (or dust filter or whatever it is called).
  • 3" LCD with tempered glass.
Hey, even the DX D300 is heavier at 825/903 gr. vs 5D's 810/895 gr. (w and w/o battery), and not that far away from the rumored D700 weight: 1076 gr. (battery included?).
So I guees it is all about the few extras and construction quality (in the Nikons). Let's see how much a 5DII weights with all those additions...
Regards.
Thanks ...
I really appreciate that you presented the figures the way you did!
  • Built-in flash.
weight: 1076 gr.
Regards.
Regards, David Chin
steras Senior Member • Posts: 1,198
Re: D700 scan
Body dimensions (W x H x D):
D300: 147 x 114 x 74 mm
D700: 147 x 123 x 77 mm
 steras's gear list:steras's gear list
Canon PowerShot G10 Nikon D40 Nikon D90 Nikon D2H Panasonic Lumix DMC-G1 +10 more
200mm Senior Member • Posts: 1,210
Re: D700 scan
Great, if it is around 3K I am getting one.
Roger.
Re: The given weight is WITH the battery
That's a correct interpretation. Weight is with battery.
Baywing Veteran Member • Posts: 4,245
Re: D700 scan
Looks like the finder has the cover built in, like the D2x, F5, just flip the lever, no more plastic cover to loose.
'I may not know much about art, but I know what I like' John Cleese, Monty Python
http://www.pbase.com/baywing
Re: D700 scan
The multiselector and focuspoint lever has been moved down and slightly to the right a bit. Other buttons almost identical placement to the D300's.
