Cclr
Regular Member
Thanks to John_A_G, I learned the strengths and
Thanks to John_A_G, I learned the strengths and distance limitations of the 85 f/1.8 for basketball. This is the lens I use with the XTi for basketball; I continue to work on his advice, among others, and have an appreciation of just what I'm aiming for . . . thanks again, John_A_G.
shot taken off the dribble -- upper right color cast, no ball in photo, daughter's face partially blocked (focus is on face!), but it will do -- for now . . .
f/1.8, 1/400, ISO 1600, 0/3 EV, Center AF pt.
To Annette, Ed Yamanaka's pointers are useful in regard to the XTi in that "you can squeeze a few more RAW images before the buffer fills [over the XSi]. You will probably want to shoot RAW eventually because it allows much more control over the final image."
I received a second XTi today that I ordered online the morning after a recent price dip to $519 from J&R (I've ordered from jr.com twice before with great results, same with B&H -- now 3 orders from bhphotovideo.com) and noticed on jr.com that it sold out that same day.
It sounds like you'll appreciate either camera under consideration, with the right lenses for your purposes. Enjoy your dig into the learning process; many knowledgeable people here are quite generous with highly valuable information, I also recognize experienced posts from bronxbombers, and I thank them all.
Best regards,
Bonnie
http://flickr.com/photos/sbmgar/
John_A_G
wrote:
You're welcome.
These shots were taken with a 1dmkIII. But the XTi ans XSi are both
quite capable cameras.
I'd like to highlight something though - these shots were all taken
from the floor, not the stands. I want to highlight something from
my previous post - the effective range for the 85mm is about 20-25
feet. That is not very far. In volleyball you need to be right off
the net for the lens to cover the far side of the court. You'll also
find within that range the framing is VERY tight. By HS age you'll
find if you stay inside that range many of your shots will not be
full body (the camera I use has a 1.3 crop factor vs. the 1.6 of the
cameras you're going to use so more of the subject is visible in the
pictures I shoot).
For basketball 25 feet isn't much. If you're shooting from the
baseline then you can't really get quality at the half court line.
And if you're at the corner of the baseline and your subject is
outside the arc around the other corner you'll find the quality of
those shots to be lacking as well. Shooting from the stands will be
VERY limiting as to the shots you can get. With that lens the only
decent shots you'll get is the point guard coming up the floor with
the ball and some shots of your team defending around the perimiter.
Almost every other shot will be either too far away or will have your
player facing away. Besides action in the shots I posted, with the
exception of 1, they all clearly show faces. That's key to good
sports shots. To get faces you have to be in the right position.
So, I just caution you before you spend your money. Getting good
shots from the stands can be VERY difficult and you'll be very
limited in your shot selection because of the way players are facing
and because of how far away from the action you are.
So far there are 3 keys to success:
1. Gaining experience and skill as a sports shooter.
2. Having the right gear - right camera and right lens for the job
3. Having the proper positioning and access. Don't underestimate
this one. Especially for low light sports this is essential.
Best of luck to you!
