Rikenon 50mm f2 vs XR Rikenon 50mm f2
Started Jun 4, 2008 | Discussions
EnriqueBello Regular Member • Posts: 373
Anyone knows the difference beetween the two?
Is XR a lot better or..?
I saw this comparision beetween the Rikenon 50mm f2 vs SMC 31mm Limited
http://blog.asterisk.gs/item/527/catid/3
What do you think? It seems these old rikenon is better or the same in terms of IQ, how can it be? is it really?
Enrique
PvH Regular Member • Posts: 461
Re: Rikenon 50mm f2 vs XR Rikenon 50mm f2
Take a look here:
http : www .pbase.com/steephill/mtf_data
These old lenses aren't bad at all...
I own a Ricoh XR Rikenon 50mm F2 L ( 1985). It's pretty good i think (don't own a Pentax version, so no compare). Read somewhere that the Ricoh version is as good as the Pentax version... but... no SMC, so use it with a hood to prevent flare.
Be aware of the 'P' versions: they have the famous extra pin that get's stuck in the AF coupler...
Btw: there is info on this forum about the Ricoh 50mm lenses: A year ago I posted info i found about them. Do a search...
Assen, The Netherlands
Pentax SLR since 1988... and dSLR since 2006
istDL + Split Focus Screen
 PvH's gear list:PvH's gear list
Pentax K-70 Pentax smc DA 18-55mm F3.5-5.6 AL Sigma 10-20mm F4-5.6 EX DC HSM +1 more
Re:
Found it:
(I posted this 16 April 2007)
There are three versions of Ricoh lenses:
  • the 'normal' version
  • the 'L' version (it says 'L' on the front of the lens: better IQ than
the normal version, probably multi coated)
  • the 'P' version (it says 'P' on the front of the lens, and has a
'auto aperture pin' where Pentax has the AF coupler: like the
L version, but with 'Ricoh Auto Aperture')
