What is a Zoom Key in a 24-70L ?
Started May 29, 2008 | Discussions
John_Co Forum Member • Posts: 96
I posted this in the Canon Lens forum but no one knew.
Just had my 24-70L repaired by Canon and they stated that they replaced the Zoom Key in the lens.
Does anyone know what a Zoom Key is ???
Its RKM Veteran Member • Posts: 3,135
Re: What is a Zoom Key in a 24-70L ?
I have sometimes heard the cam that links the zoom control ring to the movement of the zoom elements called that. Not sure if that is what they mean in this instance though.
John_Hoffman
John_Hoffman Senior Member • Posts: 1,548
I don't know for sure, but it might be the piece that allows the rotating zoom ring to engage the internal mechanism that moves the lens assembly axially.
 John_Hoffman's gear list:John_Hoffman's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM Canon EF 70-200 F4 II
OP John_Co Forum Member • Posts: 96
I couldn’t take it and called Canon. It took 3 different people before I got an answer. It is in fact the cam the links the zoom control ring to the movement of the zoom elements.
I guess that explained why the lens was out of focus worse when it wasn’t zoomed out.
Thanks for the help!
