One Button Burst Bracketing
Started May 24, 2008 | Discussions
Michael Firstlight Veteran Member • Posts: 3,667
For anyone doing a lot of tripod based HDR shooting and interested in true one-button single-cycle burst bracketing without having to keep both the FUNC+shutter buttons fully pressed throughout the sequence, try this nifty trick:
One time setup only: On the Interval Shooting menu, highlight NOW, then move to the right. Make sure it reads... 00:00':01" and then move to the right again and make the next screen show...001 x 1 = 0001.
In the field:
1) Put your camera in manual or aperture-priority mode to maintain a constant aperture and Choose the bracket settings you prefer, hold the BKT button and rotate dials until you get the number of frames and exposure difference dialed in as usual.
2) Compose your shot while the camera is on the tripod, making sure the camera can find focus. In the Interval menu, navigate right and pick START > ON. You are now ready to shoot - the OK button becomes your Shutter release button for that sequence. To shoot another burst, repeat this step.
Someone showed me this nifty trick a long time ago and I needed is this past weekend and it worked like a charm when I needed to burst bracket on a tripod with long exposures and didn’t want to keep my hands on the camera throughout the burst sequence nor felt like plugging up a remote and count frames in my head.
This works on other Nikon models that have an intervalometer – the menu settings may be organized slightly differently – but same process. I still wish Nikon would give is dedicated firmware (menu) control for set-and-forget HDR shooting to automate this kind of setup (a dedicated menu preset for exposure mode, focus mode, default number of bracket frames and EV steps between then and true one button auto burst and so on), but in its absence, this helps.
Enjoy,
Mike
 Michael Firstlight's gear list:Michael Firstlight's gear list
Nikon D800 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +29 more
willett58 Senior Member • Posts: 1,109
Re: One Button Burst Bracketing
Interesting, I set up my bracketing through a function button and It is much easier to set up different bracketing settings. Also, remember LV is great for Tripod use - but make sure you set it up for Tripod LV mode, and turn off VR!
http://www.nikonman.smugmug.com
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 15,371
When I set bracketing, I also set Ch mode. Press shutter, hold down, and the camera automatically takes the number of bracketed shots. I don't think I'm so good that I'm timing these just right - I think the camera 'knows' to take 3 or 5 or 7 frames and pause a bit? However it does this, it seems to work well for me.
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +37 more
OP Michael Firstlight Veteran Member • Posts: 3,667
The neat thing about the method I outlined is that you only need to press the shutter release button and immediately let go rather than have to keep the shutter release fully depressed through the entire sequence (contributing to possible additional camera shake on long exposures). The other methods work well, but this is the only method that permits instant press and release and automatically do the full burst sequence.
In all other methods, not only do you need to keep the shutter release fully depressed during the bracketing sequence, you also have to count the number of frames shot to know you've completed the full bracketing sequence.
Mike
FloydianSlip Junior Member • Posts: 38
Thanks for the tip Michael ... I can see this really coming in handy when doing HDR work. Cheers.
My galleries:
http://parabola-pop.deviantart.com/
http://www.flickr.com/photos/parabola-pop/
