clock battery flashing at small LCD - why ?
Started May 2, 2008 | Discussions
James Kei
James Kei Senior Member • Posts: 2,340
Can someone tell me why small clock battery flashing at small LCD ?
My D3 is brand new less than a month.
 James Kei's gear list:James Kei's gear list
Pentax K-5 II Sony a7R Nikon Z5 Nikon AF-S Nikkor 300mm f/4D ED-IF Sigma 120-300mm F2.8 EX DG HSM +2 more
konan16 Forum Member • Posts: 74
Re: clock battery flashing at small LCD - why ?
The battery may be faulty or the contacts need a clean ?
Jeff Diaz Contributing Member • Posts: 593
Just go into the set up menu and set the time.
Even though you may find that the time displayed is correct, part of the set up requires the user to go to the set up menu and set the time in order to make the little clock blinky go away. This was shock to several of use when we first picked up our D3's in December (posted on this long ago).
Here's the link
williams-pics Contributing Member • Posts: 874
James ,
You need to set the time in the menu see page 40 in the manual, see page 408 in the manual for the error message.
Bruce.
James Kei
OP James Kei Senior Member • Posts: 2,340
thanks all of you
my time is correct, so only change timezone, so to touch it..
