40D Focusing issues..
Started Apr 21, 2008 | Discussions
oldeddies New Member • Posts: 5
After about 10,000 pics on this new camera there are only about 100 that are tack sharp, others are acceptable to soft. Liveview proves lenses are sharp.... any thoughts...
Bob Tullis
Bob Tullis Forum Pro • Posts: 40,026
Re: 40D Focusing issues..
That's a lot of trial and error to reach that conclusion. The way you phrased it, no informal but purposeful testing was done. It's probably best just to send the gear into Canon, with some example images, for them to assess and adjust your gear.
I'd suggest first taking a bulb blower to the AF wells (put the camera in sensor clean mode, remove lens, and look for them at the bottom of the lens mount chamber). If blowing them clear doesn't help. . .
...Bob, NYC
Galleries: http://www.pbase.com/btullis
 Bob Tullis's gear list:Bob Tullis's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Brian D. Schneider
Brian D. Schneider Forum Pro • Posts: 18,225
I have just under 5000 exposures & have no complaints about sharpness, any not sharp are my fault. It sounds like a trip to Canon service for calibration would not be a bad idea.
Brian Schneider
Adrian_H New Member • Posts: 23
I could be facetious here since you don't exactly give a lot to go on.
Give us some more info... for example, were you focussing manually or automatically?
Philip Persio Forum Member • Posts: 52
I just upgraded from 350D to 40D, and I am disappointed.
The 40D has the AF issue with all my Tokina and Sigma lenses.
Apart from my Canon 18-55 kit lens (350D), the 40D just could not focus correctly with all my lenses, which have been working properly with my 350D.
I just got a replacement (Firmware 1.0.5) yesterday and the replacement still has the AF issue with all my lenses except the Canon 18-55 kit lens. With the replacement, only the center point of the 9-point AF sensor can focus properly. The AF of my 40D just cannot work correctly at Automatic Selection Mode or single AF point mode with AF point other than center..
I will update the firmware of my 40D to 1.0.8 and try. I just hope that the AF issue is not due to the new 9-point cross sensor and the problem can be resolved with the firmware update. If Canon does not solve this AF problem for my 40D, my next camera should not be a Canon.
Persio
What f-stop are your Tokina and Sigma lenses?
Brian D. Schneider
with my 350D.
Canon.
Thats pretty strange, I have 17-50 f2.8 Tamron & 150 f2.8 Sigma & have no problem. I have not updated the formware from 1.0.5 yet.
Brian Schneider
shawn finger Senior Member • Posts: 1,049
My Tokina 12-24 is perfect on my 40D, I have not done the firmware update. In your testing, have you put the camera on a tripod and used a remote cable or timer with MLU? This is the test I normally do to rule out shaking and user error.
Oak and Acorn Veteran Member • Posts: 6,124
Realy? 5 posts in 8 months and this is all you can come up with?
Please post some samples if you want any meaningful help and advice.
And, after well over a day since you're original posting, and still no response from you to other members' suggestions and queries, I'm assuming you've lost interest?
Vibrio Veteran Member • Posts: 4,004
yes, you can't take pictures properly or
you are blind.
http://blog.quantum-capture.co.uk/
update 19.04.08 - blogged Harman paper products
chevysales Senior Member • Posts: 2,709
Re: Canon 40D focus problems with long tele lenses
oldeddies - 1 month ago
I've taken about 9,800 shots with my 40D and some that were good, some that were very good and only 1 that was so sharp it would knock your socks off. Liveview shots proved the lenses are excellent. See samples at http://www.eyefetch.com/profile-images.aspx?user=eddies&view=popular
????? at 200 shots a month how did you read 10,000?
some nice shots at your gallery
Forty Dee paired with the Seventy-Two Hundred IS f4L and the Seventeen-FiftyFive IS f2.8 capped off with B+W MRC UV filters and a few Kaesemann Circular Polarizers... and growing.
All safely wrapped and easily carried in a Kata R102 backpack.
 chevysales's gear list:chevysales's gear list
Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Pixelmator Chameleon Apple iPhone X Apple iPhone XS Max +2 more
Paul Hancock Senior Member • Posts: 1,751
Technique!
Likely technique and/or user error.
What lenses?
What aperature/shutter speed?
Handheld/tripod?
What subject matter -action/portrait?
etc.
Hard to respond to questions like this when you supply no info and no examples.
http://www.pbase.com/pwh
