Serious bug with D3 with updated firmware
Started Apr 16, 2008 | Discussions
Sasa Pahic Szabo Regular Member • Posts: 286
I've updated the firmware to my D3 yesterday , was really happy how they fixed Auto iso and the flash with matrix metering .
then today at semi final of the slovenian football cup this happended:
i tought it was caused by the new and improved auto iso . so i switched it off.
Only happends with a long burst .
the camera was in Nef loosless compressed + Jpeg Normal quality optimised
i used two different Lexar 300x Udma 4gb cards
ive already contacted my nps representantive and send him the raw files , so he can forward it to support . this is serious
the link to the original files if anyone is interested
http://www.2muchbeauty.com/d3bug/SPS_4524.jpg
http://www.2muchbeauty.com/d3bug/SPS_4750.jpg
http://www.2muchbeauty.com/d3bug/SPS_4851.jpg
Marianne Oelund Veteran Member • Posts: 7,788
Too early to conclude it's the firmware
switched it off.
Only happens with a long burst .
How long is "long?"
optimised
I'll see if I can reproduce the problem, but should note that until it's confirmed by another user, it is too early to declare this as a firmware problem. It could also be that your camera has developed an addressing fault to the buffer RAM, for example.
OP Sasa Pahic Szabo Regular Member • Posts: 286
Re: Too early to conclude it's the firmware
long burst , would be 10-13 frames , since you can only do 15 in Nef+jpg mode
i am aware that it could just be my camera , but this didnt happend before the firmware update yesterday ,i shot footbal the day before that , and i've done atleast 30 games since i got the d3 , ill try the other Sandisk udma card i have. i just posted this so the word got out if this might be a bigger problem than just my camera.
xrdbear Veteran Member • Posts: 3,961
Purely for curiousity. Did you use the card you used to input the firmware files and if so, did you format it again after the final update?
Brian
Fine Art Print sales of the Isle of Skye at:
http://www.eyeofskye.co.uk/
Pbase gallery Pictures from Isle of Skye
http://www.pbase.com/xrdbear
update?
nope . i performed the update on the sandisk udma card , which i formated afterwards , these were lexar udma
sclamb Veteran Member • Posts: 5,127
Just subscribing (nt)
Anil Bouri Contributing Member • Posts: 750
Re: Just subscribing (nt)
took 18 shots continuous just now, the 14th looks like what the OP posted, the rest are fine.....lets see what happens....any suggestions what I should do to try to help?
akb
akb
contact your nikon support or nps office , the more of us report this in the quicker it will be fixed
graemehunter New Member • Posts: 3
Re: Serious bug with D3 with updated firmware
same problem, updated firmware from nikon uk's site yesterday.
was shooting stills on a tv show today & after every burst the same effect.
really disappointed after initial brilliance of camera, ( was early adopter in december last year)
i'll forward images to nikon in the morning
ems like a software/firmware problem...
seems like a firmware, software problem.....like 2 images have been overlapped int he writing process...called nikon, they wanted the RAW file. I am not too worries, should be fixable with firmware update, at least its not a hardware problem.....
akb
Julian Contributing Member • Posts: 525
Re: ems like a software/firmware problem...
Just curious - the poster stated he was shooting with a Lexar UDMA card - what makes of cards are others seeing this issue with - to confirm if this is a Lexar and 1.01 issue or a wider problem...
 Julian's gear list:Julian's gear list
Nikon D3 Nikon D800 Nikon Z6 Nikon AF-S Nikkor 14-24mm f/2.8G ED Sigma 50mm F1.4 DG HSM | A +4 more
i'm just delighted i'm not the only one. look forward to the next update !
Tomasz Wojczyk Regular Member • Posts: 266
Did 3 max (13 exposures each) bursts of NEF uncompressed - no problem
http://www.pbase.com/bonoman68
http://bonoman68.zenfolio.com/
i had quite a lot of bursts during the game today and not all were wrong .
try setting the nef to lossless compression + JPG
Grig
Grig Senior Member • Posts: 2,313
wrong .
Tried on mine - several bursts - just fine... But, I use Extreme III... May be it's UDMA related?
Real photography - it's just the ability to see what was already created by God!
http://www.pbase.com/grig
 Grig's gear list:Grig's gear list
Fujifilm X-E1 Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-T4 Fujifilm GFX 100S +24 more
did nef uncompressed+JPEG no problem using generic 16 gb cf; update from US site
Sabenza Forum Member • Posts: 96
New firmware. Just did 28 continuous NEF lossless compression (no JPEG), 14bit, CH set to 9 fps, max 130 release, cards set to overflow, 1st slot - Scandisk 8GB Ducati, 2nd slot Extreme IV 4GB, formatted both cards before test and therefore writing to 1st slot.
RESULT - 2nd photo exhibit this characteristics
 Sabenza's gear list:Sabenza's gear list
Sony a9 Leica M10-P Leica Summilux-M 35mm f/1.4 ASPH Leica Noctilux-M 50mm f/0.95 ASPH Leica Summilux-M 50mm f/1.4 ASPH +7 more
Yamil R. Sued Veteran Member • Posts: 4,528
Nothing about Lexar would surprise me and I still not trust UDMA 100%
I moved to Extreme III last year and haven't looked back
Y
Jeweller Contributing Member • Posts: 915
I hope they can isolate this problem and fix it soon.
http://www.pbase.com/jeweller
http://www.usefilm.com/photographer/68206.html
tsfotocom New Member • Posts: 10
I've just done a test with 2 cards, ExtremeIII 4GB and Transcend 16GB 133x, all frames are good.
Same settings as the OP.
 tsfotocom's gear list:tsfotocom's gear list
Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 18-35mm f/3.5-4.5G ED
