24.4 MP Nikon D3X DSLR on the way?
Started Apr 15, 2008 | Discussions
AxelR Senior Member • Posts: 1,169
The following strings are in the D3's B-firmware file v1.10, starting at offet 3'614'640:
6048x4032 24.4 M
4544x3024 13.7 M
3024x2016 6.1 M
5056x4032 20.4 M
3792x3024 11.5 M
2528x2016 5.1 M
3968x2640 10.5 M
2976x1976 5.9 M
1984x1320 2.6 M
D3X
philip callaci Regular Member • Posts: 148
Re: 24.4 MP Nikon D3X DSLR on the way?
Hope so!
danielniel New Member • Posts: 14
May be a future hack could convert a D3 in a D3X?
Jim Kaye Senior Member • Posts: 2,820
What are you saying -- that the D3 already has the potential to be 24.4 MP? That each of it's photosites is actually two photosites (grouped together electronically now) that can potentially be separated functionally with a future firmware upgrade? (Didn't Nikon functionally group several individual photosites or something like that in one of the D1 vintage cameras?) Or do you think the firmware we just got for the D3 is planned for use on a future model that has 24.4 Meg photosites?
I guess I'm wondering what you think the significance of what you are pointing out really is...
Jim Kaye
'I believe that the electronic image will be the next major advance. Such systems will have their own inherent and inescapable structural characteristics, and the artist and functional practitioner will again strive to comprehend and control them.' -- Ansel Adams, 1981
smhagger Senior Member • Posts: 1,435
I found references also...
I just opened up the file and began searching for references to 'D3X' and saw some of the sizes that you mentioned--including the 6048 x 4032 size...
It can't be too long now...
Sean
 smhagger's gear list:smhagger's gear list
Nikon Z6 II Nikon AF-S Nikkor 200mm f/2G ED-IF VR Nikon AF-S 70-200mm F2.8E FL ED VR Sigma 135mm F1.8 Art Nikon Z 24-70mm F2.8
OP AxelR Senior Member • Posts: 1,169
I'm not sure who's questions were for, but the strings come straight out the D3's V1.10 operating system (B-file), as for example "6048x4032 24.4 M". Someone typed those string in the firmware, and he/she probably did it for a good reason.
It's all over the place in the D3 firmware update!
Here's just a sample cut and paste from the text of the file: (notice the resolutions and the D3X callouts...
"› Ñ †!Å ÿ Ÿ ∑ ˆ 6048x4032Ñ 24.4 M 4544x3024Ñ 13.7 M 3024x2016Ñ 6.1 M 5056x4032Ñ 20.4 M 3792x3024Ñ 11.5 M 2528x2016Ñ 5.1 M 3968x2640Ñ 10.5 M 2976x1976Ñ 5.9 M 1984x1320Ñ 2.6 M ñ ó Ÿ Ñ!∏ É Ä
Ò!É"ˆ¬·¬Á Ω Å ∑ ı ö ¿! ö D3X Ÿ ¨ î
NEF(RAW) É JPEG ˘¬˝¬Å NCD3X Å OK 2 - 3 4864x3240 4864x3648 4560x3648 ±¬´!î "
Sean
In English...
" dial. ÿ Ÿ Cancel Cannot delete file. ÿ Ÿ Cancel Done. Done. Å Back Paper low. ÿ Ÿ Done 6048 x 4032; 24.4 M 4544 x 3024; 13.7 M 3024 x 2016; 6.1 M 5056 x 4032; 20.4 M 3792 x 3024; 11.5 M 2528 x 2016; 5.1 M 3968 x 2640; 10.5 M 2976 x 1976; 5.9 M 1984 x 1320; 2.6 M Firmware can not be upgraded at
current settings. Only NEF (RAW) and JPEG pictures created with D3X can be selected. NCD3X Å OK 2 - 3 4864x3240 4864x3648 4560x3648 RECENT SETTINGS > bÛ > b˙ > c > c"
noirdesir Forum Pro • Posts: 13,797
Finally some substantiated rumors
That is a clever find. This also indicates that the D3x will use a variant of the Sony sensor which has a very similar resolution.
For those asking what a reference to 24.4 MP should do in a D3 firmware:
The firmware for the D3 and D3x almost certainly will share a lot of code. Nikon most likely therefore maintains a common code base and creates branches for both cameras (in the case of the D3x for the early prototypes). At some point the did not bother to separate the code.
Jack_DC Senior Member • Posts: 2,442
Re: Canon is warned ;)
First the D3 tops the 1D III, now the D3x about to top the 1Ds III....
Interesting times.
Paul Simon needs to re-release his song.
Thom Hogan
Thom Hogan Forum Pro • Posts: 14,558
Re: Finally some substantiated rumors
code.
Sure. But the real reason is almost certainly that there are some D3 bodies out there with the new sensor being tested.
Thom Hogan
editor, Nikon DSLR Report
author, Complete Guides: D40/D40x, D50, D70s, D80, D100, D200, D1 series, D2 series
http://www.bythom.com
arambo New Member • Posts: 17
That's a real brilliant find! Congratulations. Amazing to know now that it will exist, will be 24.4 MP, and be here probably rather soon. On the other hand, could Nikon ignore that by posting the firmware they were likely to reveal the information? Amazing, really.
It's quite funny. I was thinking while writing my previous message about Thom Hogan, and wondering if he would get the information fast and report it on his site. Well, he was already there. 4 minutes before me. Congratulations Thom! And waiting for your D3 book. I'll buy it for sure (I have the D300 on order).
Georgi Veteran Member • Posts: 7,638
Which song?
50 ways to leave your lover?
bmcent1 Contributing Member • Posts: 857
Makes sense, I bought a D3 yesterday...
Sigh
Last year at this time I couldn't wait any longer to jump into a pro body and jumped in with a D2Xs... six months later, Nikon announced the new end all be all of DSLRs.
Now I just pulled the trigger on a D3, so of course Nikon is going to come out and top it the next day
I'm not bitter. But you guys should start pooling money for me to buy a new body any time you want to nudge Nikon on to one up themselves!
code.
Thom Hogan
Thanks for the replies, to both of you.
Jim Kaye
Re: Which song?
Nice one!
love_them_all Senior Member • Posts: 2,794
Let's hope the 24mp model would cost like US$7000-8000. Then the balance of the force will be even out by a lot.
Interesting times.
David314 Veteran Member • Posts: 4,790
That doesn't make sense
code.
there are undoubtedly d3 bodies running around testing sensors just like there were D40 bodies and probabaly D300 bodies and all kinds of things running around being tested with different sensors
i just don't think you start putting stuff into a major baseline releases just to test a couple of cameras -
however, if you are really going to be releasing a D3X in any quantity for the summer olympics you had better be finalizaing production, if not already started, now
David
Henrik Herranen Senior Member • Posts: 1,734
Interesting times.
Yes. It is very rare to see a vaporware camera that just might be released in 2008 from one manufacturer to have a 7.7% higher linear pixel count than a camera that has been available to buy since late 2007 from another manufacturer. Thank you for pointing a link to this thread on the Canon 1D/1Ds/5D forum.
Kind regards,
  • Henrik
And if a million more agree there ain't no great society
My obligatory gallery at http://www.iki.fi/leopold/Photo/Galleria/
 Henrik Herranen's gear list:Henrik Herranen's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM +7 more
