Focusing accuracy improved after installing 40D firmware 1.08
Started Apr 10, 2008 | Discussions
Vinny Regular Member • Posts: 248
I used to having small soft focusing issue with my 24-70 f2.8. But after 1.08, I found the result of my 24-70 became much sharper. Can anyone to confirm it please?
Vinny
 Vinny's gear list:Vinny's gear list
Canon EOS 80D
hangerhead Regular Member • Posts: 102
Re: Focusing accuracy improved after installing 40D firmware 1.08
sure...send me your camera and lens...
OP Vinny Regular Member • Posts: 248
Sure, your address please?
Canon EOS 80D
jsy sent my 40D to canon for calibration actaully...wonder if they'll update it to latest firmware meanwhile?
JimH Forum Pro • Posts: 12,912
My guess is: Yes.
I think Canon updates to the latest firmware any time they have the camera in for work.
So I suspect you'll get it back with 1.0.8 installed.
Jim H.
This is all depends, I had sent my 3 cameras for service in the last 4 years. They never updated the firmare once.
My 24-70 is the only problem that I.m having. I am not sure if this update will affect other lenses too.
Canon EOS 80D
Rinus Boone New Member • Posts: 1
Focusing accuracy improved after installing 40D firmware 1.08, also with 70-300 mm
I was also pleasantly surprised by the fact that focussing is more accurate after the update. This is just after a short session with my Canon EF 70-300/4-5.6 IS USM, but it was so clear that I Googled on the sumject and came to this thread. Canon is not specifically clear about this, but there must be more on this update than officially published.
BryanP Veteran Member • Posts: 4,914
Canon will update your firmware, unless you specifically
tell them not to.
Bryan P.
OneDMark3, FortyD, ASixFiftyIS
http://www.flickr.com/photos/29386469@N00/
http://blplhp.smugmug.com/
The best thing that could poke you in the eye....is your viewfinder.
Cassius Moura Regular Member • Posts: 202
It may be wishful thinking but...
I noticed that too.
Re: Canon will update your firmware, unless you specifically
They didn't update mine at all.
came back from calibration and works as i expected it would, but firmware is unchanged.
Jeff Peterman
MOD Jeff Peterman Forum Pro • Posts: 13,464
Wishfull thinking. Probably.
Typically, Canon mentions everyhing that is in an update. If they had improved focusing, they would shout about it to attract new customers who were concerned about focus problems, and not have it as a hidden update.
I think that the problem is the almost all the focusing issues are in the eyes of the shooter - once you hear there is a focusing problem, it is easy to find shots that prove it even though the focus error in those shots could have been anticipated by the way they were taken (I fell into that trap). Now that you think focusing has been improved, it is easy to find sharp shots that prove it too!
Jeff Peterman
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
http://www.pbase.com/jeffp25
http://www.jeffp25.smugmug.com
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +19 more
KariP
KariP Veteran Member • Posts: 5,860
I was thinking. Probably.
Hi Jeff!
I have been trying to see some "focus issues" - i have not found any and i have had an unpleasant suspicion sometimes (only sometimes after reading this forum) - that i can not look.
I almost started to upload the latest firmware to reduce "issues" that probably do not even exist.
This tech forum gives interesting insights to human mind...
Kari
SLR photography for 40 years
60°15´N 24°03´ E
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +10 more
Will O Contributing Member • Posts: 697
Re: Wishfull thinking. Probably.
update.
I thinks so too. I read the list of what the update does and could not find any mention of AF - or anything else that interested me for that matter. I even rang Canon to ask if the latest update has any effect on AF, and was told certainly NOT! In that case, I will pass on this version.
The 'placebo' effect that some things can have on the human mind is quite amazing!
Of course you were told there are no focusing tweaks in the software.
because to have done so, would be to ADMIT the 40D has a problem...
[ shifty mode engaged - Conspiracy]
CottonEyeJoe Regular Member • Posts: 332
Just was wondering....I've still got version 1.03 and have never had any issue's other than err 99 which pisses me off, but can live with it...
I think it's time to update to newest version, can I go direct from 1.03 to 1.08, or do I have to stair step it up....
Thanks!
thecameraguy Senior Member • Posts: 1,358
now this is a sad day...
i am a lee iacoca fan.. and have not bothered to update my perfectly working firmware.. (like i need improved norwegian menus..pah)...
but now...aaargh!..
this i cannot resist............
~ Being over-exposed can get you arrested ~
http://ramsden.smugmug.com/
cvandevere Regular Member • Posts: 153
Yes you can go directly from 1.03 to 1.08. The firmware updates are progressive and include changes from previous ones.
 cvandevere's gear list:cvandevere's gear list
Canon 6D Mark II
