Canon, please fix that disappointing AI-Servo
Started Mar 29, 2008 | Discussions
Hubs Forum Member • Posts: 55
I've always been a fan of Canon cameras. The controls are user friendly and the build quality is high, at least for the 400D and 30D I used. However, I shoot cars most of the time, and inconsistency of the AF really puts me off when I start chasing race action or panning.
The 40D has some nice gimmicks over the 30D, but all I really need are:
1) higher resolution screen so that I can actually check the sharpness of my shots on the spot;
2) AI-Servo that stays on target during continuous shooting, and not wander off after the first shot. 3FPS or 10FPS means nothing if I can't keep the object in focus. I don't use continuous shooting anymore for this reason.
It's ok that the 40D AF is not as quick as the 1D (for capturing approaching cars etc.), but at least it should be accurate. It'd be nice to add the AI servo sensitivity adjustment function to the next crop sensor DSLR.
Canon, please work on what's important. The D300 is tempting cos it offers what I need without having to spend 1D3 prices, but I really don't want to switch my lenses and learn new controls from scratch.
Am I alone?
Bob Blount Veteran Member • Posts: 7,458
Re: Canon, please fix that disappointing AI-Servo
Hubs,
Are you using just the center AF point or all nine? Several other posters have suggested using on the center one since using all nine is letting camera decide what you want to be in focus. Landscapes and portraits may benefit from all nine but action shots require user selection.
I use my D40 for birds in flight so it is difficult use just the center point but worth the effort.
Bob
'There are always two people in every picture: the photographer and the viewer.' - Ansel Adams
Canon 40D, 70-200mm f4L IS, 28-135mm IS, Sigma 17-70mm f2.8 Macro, 100-400 mm f4.5L IS
Sony R1
Canon Pro1
 Bob Blount's gear list:Bob Blount's gear list
Canon EOS 5D Mark II Canon EOS 7D
tetapunto Regular Member • Posts: 142
ai servo
Below are some extracts from another thread. Make a search in the forum and you will find many suggestions. Daniella made many beautiful photo using ai servo
tetapunto
A)"If you use all focusing points with the AI servo, make sure that your initial AF lock is right on your target, as if you start a burst sequence with the wrong subject acquisition, it will be hard to correct without refocusing."
B)"Your suggestion to use Auto Focus Points on AI Servo rather than just Center Point Focus increased my keeper rates from a dismal 20% to over 90% with the same subject: "Weimaraners in Flight"!"
C)"I would only use the center AF point alone if I had a bird that was so large in the frame that I would not be afraid of losing it from the main AF point.
The camera is quite fast to pick up something behind if all the active points get off the subject.
So..in that reguard if you only use the center point and it drop off the target during a tracking (like with a bird that is small in the frame), then the AF will probably wander around.
with all focusing points, as long as you keep at least one on the target, your chances of keeping the tracking are better. That is from my own experience though."
OP Hubs Forum Member • Posts: 55
Hi Bob,
I use single point AF for all the pics I take, and I pick the AF point depending on how I frame each pic. I don't recall using the centre point to be significantly more in focus. It'd be great to have other motorsports photographers to confirm on this.
I've seen reviews of 40D for motorsports, but I don't think the 9 cross sensors have improved on the success rate for this task.
J A K Forum Pro • Posts: 15,833
Maybe there is something wrong with your camera/lens.
AI servo works great in my 40D (as well as my 30D and 1DmkII). I've had no complaints shooting in AI Servo AF mode (I use this shooting mode a LOT) and have to wonder "if" there could be something wrong with your equipment. If possible, you might try shooting your lens/body on a borrowed body/lens from a friend to help isolate the cause of your problem(s).
Joe Kurkjian, Pbase Supporter
SEARCHING FOR A BETTER SELF PORTRAIT
Glenn W. Veteran Member • Posts: 6,428
LCD resolution is fine.
The LCD's resolution is about the same as a typical computer screen, perfectly fine for judging focus, etc... The problem is Canon only gives us a small preview image to look at... your inability to judge focus has little or nothing to do with the LCD's resolution.
Others have also explained that the AI Servo in the 40D is actually quite good....
crop sensor DSLR.
Am I alone?
Re: Maybe there is something wrong with your camera/lens.
Thank for your advice. Will try to borrow a 40D for testing next time.
Re: LCD resolution is fine.
Thanks. Unfortunately the LCD resolution just doesn't do it for me. There're many occasions where the car decals look sharp in the LCD screen, but turns out to be a bit off in the com. Same when I do lens comparison tests with tripods and mirror lockups, where I cannot possibly judge from the LCD. Anyway, this is less of an issue compared to the AI problem I've been experiencing. I really hope that I have a faulty camera, then I'll have the excuse to upgrade
Adam2 Veteran Member • Posts: 7,760
That's why I bought another 1dmkII
After trialing the 40d and finding it not quite ready for prime time sports, it went back. In addition to the AI servo issues the AWB isn't on par. Most of the time, I'm shooting in manual mode but on the occasions I rely on AEX, it wasn't there either.
Save yourself some grief and buy a good used 1dmkII. Use it for a couple of months and if you don't like it then you can sell it for virtually no loss. Hopefully, the 50d will offer improved AF and address the other issues and perhaps I'll revisit the xd line.
Dale Buhanan Veteran Member • Posts: 4,280
I have played with AI-servo mode on the 40D a lot and have learned its personality. AI-servo works best with all points enabled. It will always lock on the center point first and then pass off to peripheral points as needed if the subject wanders (or flies) off center. You will only loose lock if the subject moves out too far to the edge and is no longer covered by any of the points.
In summary, with AI servo always put the center point on the subject prior to acquiring focus. Then it will track using all points. Works just super!
Hubs wrote:
Hi Bob,
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +35 more
Thanks Dale, it's great to know how AI-Servo works!
However, say if I want to pan a car that is approaching at an angle, like this pic here:
http://www.fotop.net/Hubspace/20070324e/IMG_5922
if I use auto focus point, I would probably end up getting the door area in focus, as it is closer to the center focus point, rather than the front bumper, right?
DiveDr Contributing Member • Posts: 712
Re: That's why I bought another 1dmkII
My AI Servo works just fine with all the AF points enabled using the 70-300 DO IS. The resolution of the screen is not the problem as the OP said. The sample image we are viewing on the LCD is very low res compared to the actual image file. Canon would do well to implement the ability to switch between view the full image or the thumbnail in the menu options. The user then could chose between viewing speed or accuracy as they please.
All in all not many complaints about my 40D!
Stollen123 Senior Member • Posts: 1,241
switch to Nikon..lenses are no problem you can sell them..
it is really amazing what we read in this forum..if the resolution of an LCD could be a reason for switching between top of the line camera. hmmmmm
crop sensor DSLR.
Am I alone?
R Valentino Veteran Member • Posts: 3,269
There's nothing to be "fixed" It's as good or better than any
other camera in its class. Including the D300.
I've seen nothing, nor read anything that shows or says that the D300 does indeed have better AF tracking.
Sure it has more options and is more configurable which may or may not help in certain circumstances.
But there is no definitive proof that says you'll get more in focus shots with the D300 than you will with the 40D.
If you want the AI Servo "fixed" step up to a 1D or D3.
Gene
Thanks for clarifying that it's the preview image size rather than the LCD resolution that I'm less happy with. I'm not familiar with the technical aspects behind the camera.
Panasonic Lumix DMC-TZ5 lcd 460 000
DRG Veteran Member • Posts: 5,217
As explained, it's not the LCD
Since the camera will pretty much provide a 100% view on the LCD, the resolution is not the problem. It's enough to see every single pixel of the review image. The problem is the review image itself, which is not a full-resolution image. You are viewing a downsampled thumbnail on the LCD, which is why you are finding it poor for judging sharpness.
Canon needs to provide a full-res review image for it to even make sense to allow 10x magnification on the LCD.
David
Re: As explained, it's not the LCD
Hi David,
thanks for correcting my mis-understanding
unfortunately I can't edit my top thread to correct this...
bogongbreeze Contributing Member • Posts: 826
As others have said, it's the lower res thumbnail not the screen resolution. Having said that when you magnifiy it to just below full magnification it's about the same as 100% viiew on a computer monitor and almost as sharp. Doesn't take long to learn how to 'read' the focus. Of course this isn't necessary most of the time because the camera's AF is excellent. I only use it for manual focus in the field. Otherwise if I've auto-focused properly then so has the camera
crop sensor DSLR.
Must be something wrong with you camera, assuming you are experienced with AI Servo and used it successfully on your 30D. The AI Servo on my camera cannot be faulted and gives almost 100% accuracy in every sequence of shots whether with cars, birds, planes, gliders or pro cyclists. I find it not only accurate, but that it sticks to the target well even when briefly interrupted by distractions such as trees, telegraph poles etc.
I don't think the D300 is better with AI Servo from what I've read. The D300 uses a larger jpeg for magnifying the image preview, I believe, which you might find important if you rely on this feature for checking focus. However I've read in the D300 forum where the image preview has mislead some users there as well (showed soft images as sharp, rather than sharp images as soft).
Am I alone?
Maybe. Either faulty lens, faulty camera or faulty technique with AI Servo. The 40D is at least as good as the 30D for AI Servo and probably markedly better, with it's improved focus points. To guarantee better performance you'd need to go to a 1DIII.
 bogongbreeze's gear list:bogongbreeze's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.8 II Kenko Teleplus Pro 300 AF 1.4x Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS 90D +10 more
