broken Nikkor 24-70/2.8
Started Mar 29, 2008 | Discussions
SergeSmArt I Regular Member • Posts: 284
I found this story on russian forum ... and I think that maybe better to show it here...
The guy just place D3 and 24-70 on the tripod... and two hours later the half of the lens just drop down onto his bed whithout any reason at all ...
( that's his explanation .. )
Zorpie Senior Member • Posts: 2,836
Re: broken Nikkor 24-70/2.8
Hello Serge,
That's a strange story and one which is hard to believe. It's almost as if the three screws holding the bayonet mount on the back of the lens body, were perhaps lose and the whole thing parted company under the weight of the lens supported by the mount on the camera body ?
It will be covered by Nikon's warranty if the lens is new - but it is very unusual to see this on an expensive Nikon optic. This kind of 'damage' is usually attributable to the camera being dropped with the lens on it and being ripped off the body by the impact. But the screws and screw mounts don't look damaged so that cannot be the case here.
I'd be very interested to hear of any follow-up on this one.
Zorpie
http://www.pbase.com/zorpie
If it seems too good to be true - then it isn't. If you cannot believe your eyes - then don't.
thomas2279 Forum Pro • Posts: 10,876
That is a horrible scene at least we know where the weak point in the lens is... Not sure about this fault whether it is design fault, QC problem or he knocked the combo off, I would expect further complaints with this lens already if it was a mass design fault.
Would be interested in getting some other D3 and 24-70 owners views on this.
My Pictures & Web Site: http://www.dltp.co.uk
Hi Thomas,
I have the 24-70mm and have used it a lot on the D3 and have never had a problem !! I have had it attached to the camera around my neck on a neckstrap - walking around for ages at a time - and never had an issue.
This picture caused me to go and take a close look at my own 24-70 to see if the mount or the three screws were in any way lose - but - as expected - they aren't.
So I am really puzzled by this and it almost looks to me as if the bayonet mount securing screws might have been lose when the lens came from the factory. But then again - in the photo you can clearly see the locking paint on the bottom of the three screws - so I have no idea what has caused this. I hope the OP comes back with some more information !!
Zorpie
gonzalu
gonzalu Forum Pro • Posts: 10,389
That's normal and will happen to all lenses
....NOT... unless they have been dropped or something... ludicrous to think this would actually happen JUST LIKE THAT.
I mean, in the last 50 years of Nikon glass, I have NEVER HEARD a single story or rumor like this one... I doubt it happened this way with a brand new lens from Nikon that had not been previously dropped or severely mishandled.
Manny
http://www.pbase.com/gonzalu/
http://www.mannyphoto.com/
FCAS Member - http://fcasmembers.com/
 gonzalu's gear list:gonzalu's gear list
Sony RX100 III Nikon D4S Nikon D7200 Nikon D500 Nikon AF-S Nikkor 14-24mm f/2.8G ED +19 more
This is not an impact.
Hi Manny,
I tended to agree with you on the theory of a drop or impact. BUT look at the screws and screws holes in the spacer rings.
If the mount HAD been ripped off on impact (from a drop or whatever) the spacer rings would be distorted and the screw holes would be enlongated with the screws remaining IN their fixing holes in the lens body.
The screws have come out perfectly with the locking paint - still on the threads ? If the impact had been such to rip out the screws - the spacer rings would be severely warped and bent. They aren't. They are perfect. All three screws would not come out perfectly - all together. Not on an accidental drop of lens and camera body.
I have no idea how this 'damage' has occurred. Unless as I said earlier, the lens came out of the factory with the screws lose and it literally did - fall off the camera mount ? Slightly unbelievable I know.
There are no other marks on the lens body (unless on the side we cannot see) to indicate a drop.
Zorpie
markmark Senior Member • Posts: 1,648
the only thing missing from this photo is the screwdriver that took it apart..
Kabe Luna
Kabe Luna Veteran Member • Posts: 9,493
Bull. The lens mount was just removed from the lens, that's all. There's no damage
to indicate the mount was sheared from the lens, which would have been the case if the lens had just "fallen off."
Kabe Luna
http://www.garlandcary.com
 Kabe Luna's gear list:Kabe Luna's gear list
Nikon D800 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Sigma 50mm F1.4 EX DG HSM Nikon AF-S Nikkor 85mm f/1.8G +8 more
Pradipta Dutta
Pradipta Dutta Veteran Member • Posts: 9,781
Bingo
it apart..
My thoughts exactly ;-).
 Pradipta Dutta's gear list:Pradipta Dutta's gear list
Nikon D2X Nikon D3 Nikon D800 Nikon D3200 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Re: Bingo
yep after reading zorphie's great analysis and yourself it looks like a screwdriver job, if he didn't want the lens if the first place i'will be glad to take the lens off his hands.
Next thing we probably see a microwave test...
pepper Regular Member • Posts: 102
had a similar problem with a 2 week old D3 and 24-70, Nikon said it was impact damage and charged $241 for repair. explained it was not impact but they would not budge on repair cost. good news, like the short supply of the lens, there are no replacement parts and a brand new in the box lens was returned. was charged the $241 for repair though. the screws did not looked damaged or threads stripped, exactly like this photo and promise there was no impact.
rodinis Contributing Member • Posts: 673
fell on his bed??
Who puts a tripod over their bed?
Sounds like the originator of this story was trying to find an answer to a foreshadowed question from his audience: "If the lens fell off the D3, why is there no impact damage on the metal?" Quick and easy answer: "Oh, luckily (!) the camera was positioned directly over my bed!!"
at all ...
jb_va2001 Veteran Member • Posts: 7,741
Smells fishy. Hoax? Joke? /nt
at all ...
johnchap2 Contributing Member • Posts: 636
Re: That's normal and will happen to all lenses
I have read of several such occurances with Nikon lenses. They simply come apart. But obviously with the hundreds of thousands if not millions of Nikons in use, it is a very very unlikely occurance. Likliest cause would probably be bad threading in the holes where the screws were to go. I did have a Kiron lens do that to me one.
PhotoTraveler Forum Pro • Posts: 11,700
Re: fell on his bed??
I'm sure there are shooters in Southern California that such a setup would be normal for their work.
Joseph S Wisniewski Forum Pro • Posts: 34,130
Canon troll's first post to Nikon forum (nt)
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
http://www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Canon EOS 5D Mark II Nikon D90 Nikon D2X Nikon D3 Nikon D100 +43 more
yes i was reluctant to mention them though.
gonzalu
No, I meant the lens had been PREVIOUSLY
dropped or mishandled, not this instance, but before it, giving way to this occurrence...
Manny
Markus Richter Senior Member • Posts: 1,104
LOL! Maybe the couple was too wild and she touched the lens with her heels :))
I use the 24-70 since two weeks and shot with it for several hours with camera on tripod, nothing happened like this.
The first 24-70 came with a faulty zoom ring, unable to work with it. Nikon replaced it with another 24-70 in less than six days.
MR
J Kuek Regular Member • Posts: 312
And it is not even April 1 yet!!!
I don't know who to feel more sorry for... the poster or those who believe this rubbish!
