No blue dot on new 1D3
Started Mar 20, 2008 | Discussions
David Birkin Veteran Member • Posts: 3,022
Received my second 1D3 today. There is NO blue dot on the box. The build date is OW0308 and SN is 5637xx
My existing 1D3 is SN 5525xx and DOES have a blue dot on the box.
HTH
a fair bit of gear, a reasonable idea.
 David Birkin's gear list:David Birkin's gear list
Canon EOS-1D Mark III Canon EOS-1D X Canon EF 85mm f/1.2L II USM Canon EF 16-35mm F2.8L II USM Canon EF 100mm F2.8L Macro IS USM +3 more
astroguy Regular Member • Posts: 403
Re: No blue dot on new 1D3
Where did you buy it?
'Gravity its not just a good idea its the Law'
Fred Blockland
PhilJeffrey Forum Member • Posts: 60
This is also the case for my new 1D3, received from Amazon last week. (no blue dot)
I haven't tested AI Servo significantly yet, however.
OP David Birkin Veteran Member • Posts: 3,022
warehouse express, UK
Bob Roy Regular Member • Posts: 284
My WAG is that they probably feel they are far enough away from the problem to not have to distinguish them any more. That and they can save .001 cents a camera...
Bob Roy
Colin Key Senior Member • Posts: 1,148
Have you had a chance to test it, and does it work?
Colin
http://www.pbase.com/accentor
shhboom Forum Member • Posts: 78
Received mine Monday..Serial #565....no Dots ...camera is a success in all respects !
Bartek Senior Member • Posts: 1,408
manufactured this month there is no chance of being affected with the submirror issue so probably no need for markings anymore.
I bought a 5D late in 2005 and it had the reddot just the same way as now 1DIII had the blue one. Some more people also had the dot but few more months later and untill now 5D don't have any dots anymore.
Bartek
 Bartek's gear list:Bartek's gear list
Canon EOS-1Ds Mark III Canon EOS 5D Mark III
Ophrys Contributing Member • Posts: 775
The blue dot is usually hidden beneath the bar code labels (as mine was). Enjoy your new 1DIII !
Ophrys
