Firmware 1.1.1 update issue
Started Mar 18, 2008 | Discussions
domjames New Member • Posts: 2
Hi, I've just done the new 5D firmware 1.1.1 update - followed it to the tee! and my camera LCD screen flashed off and the red read led went off just after it started and hasn't come back!!! I waited about 8 mins before trying anything - pushing the menu button, play button but nothing!
I turned it off and back on again and the top led has data on and it appears to focus and read exposure but wont take a picture and the LCD screen wont come back on.
Any ideas what to do now?
Anybody done it successfull?
Thanks - I really need help.
Dom
3cameras Regular Member • Posts: 289
Re: Firmware 1.1.1 update issue
updated two 5d's about two hours ago...no problems at all....i don't know what to tell you....good luck
Peter Aczel Senior Member • Posts: 1,874
format the CF card!
but nothing!
Dom
Did you format the CF card after the procedure??
Canon 5D, 24-105L, 70-300 IS, Sigma 105mm, 430 EX
http://www.aczelpeter.uw.hu
 Peter Aczel's gear list:Peter Aczel's gear list
Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM
tissunique Veteran Member • Posts: 3,321
Same thing happened to me, so here's what you should do (I think!). Take out the batteries and charge them. then put them back fully charged and turn the camera on... it worked for me.
Tony
OP domjames New Member • Posts: 2
As the previous post said. I changed the battery and I turned my camera on this morning and it was back to life at firmware 1.1.0
Thank God! I'm sticking to this version.
Regards to all
Dominic
AndyC105 Forum Member • Posts: 90
Canon has recommended with other updates that the lens is removed before the update process begins - although I didn't see any recommendation to do that this time, I always do it and had no probs updating.
manutremo Regular Member • Posts: 145
I just installed it from 1.1.0 and everything was fine.
John W Peterson Senior Member • Posts: 2,737
Removing Lens
I had a somewhat similar problem a while back, updating the firmware on (if I remember) a 20D. The update had hung after I ignored the advice to remove the lens before doing the update. I replaced the battery (after restarting the camera), removed the lens (put a body cap on instead) and was able to proceed with the update.
NC_Glider
NC_Glider Regular Member • Posts: 385
It Worked
The firmware update worked for me.
James Kei Senior Member • Posts: 2,156
I only have one 5D, and it just doing fine with the upgrade.
After upgrade, I do not feel anything more.
sjprg
sjprg Senior Member • Posts: 1,884
Sounds like you didn't follow the advise to charge the battery first. Any EPROM requires full voltage to flash. Most are flashed connected with a 120V power supply. Canon allowes you to use the camera, but stipulates that you charge the battery first.
Paul
http://www.pbase.com/sjprg
http://www.sjprg.us
 sjprg's gear list:sjprg's gear list
Sony RX100 V Sony RX100 VII Canon EOS-1Ds Mark III Nikon D800E Canon EOS M +14 more
jerryk Veteran Member • Posts: 6,628
Did you follow the summary instructions (8 or so bullet items) or the detailed instructions, 5 pages? The summary instructions have at least 1 maybe two errors, so you should read all of the pages first.
jerryk.smugmug.com
mark Bedwani Regular Member • Posts: 382
no...
If you try to upgrade the FW with a LOW battery it will warn you and stop. try it.. It will only go ahead with a full battery... it's not that stupid...
Qique Regular Member • Posts: 111
For me update worked as a charm... no issues/remarks whatsoever.
