Long Exposures with an e510?
Started Mar 15, 2008 | Discussions
Rhino95 Regular Member • Posts: 229
It only maxes out at 60 seconds (Right?). What if I want a 30 minute star trail?
djbrom
djbrom Senior Member • Posts: 1,324
Re: Long Exposures with an e510?
Unfortunatly the most you can do is 8 minutes, and you need the RM-1 remote or the cable remote (RC-1??). Its only the e3 that has max 30min exposure.
 djbrom's gear list:djbrom's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +11 more
OP Rhino95 Regular Member • Posts: 229
RM-1 won't work will it? How does the camera recognize the remote?
djbrom
Yep RM-1 works....
Ive used it a few times.
Re: Yep RM-1 works....
Sweet! Thats good to know! Pretty inexpensive too.
djmacedonas Regular Member • Posts: 121
How does it work... ive tried in in bulb mode on my e500, and I can't get it to work
http://forums.dpreview.com/forums/read.asp?forum=1022&message=27180245
I'm still trying to figure this out...does this mean I can go for longer than 8 minutes?
djbrom
Rhino
as i mentioned you can ONLY go up to 8 minutes. No longer. Its ONLY the e3 which allows you to go up to 30minutes. So for all Olympus dslr's (excluding the e3) the max is 8 minutes only.
60 seconds is the best you can get without the remote. Any longer than 60 sec you need the remote.
