New Nikon D300? - START HERE!
Started Feb 16, 2008 | Discussions
klh Contributing Member • Posts: 796
Re: Thanks ...
I will use this
 klh's gear list:klh's gear list
Canon PowerShot G7 X Nikon D5300
gobey New Member • Posts: 15
Accessories for the D300
B Bretz wrote:
Please feel free to use this thread to post more helpful ideas, thoughts,
links, pics questions so that well all benefit.
Great idea, Brad. Now if only there were some way to make a "sticky" on the DPR forums. Not sure if this will help but I've compiled a few links to threads that address some common D300 accessories. Thanks to everyone for their valuable contributions.
WIRED/WIRELESS REMOTE SHUTTER RELEASE:
Useful for long exposures, self-portraits, etc. Nikon makes the MC-30, MC-36, and ML-3. Phottix remotes seem to be a popular and economical alternative and sell on eBay for
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26615314
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26724241
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=25994906
http://www.planetnikon.com/forums/index.php?showtopic=7524 – Inside the old Phottix N1.
http://www.dpnotes.com/phottix-cleon/ - A nice review, thanks to David Chin.
http://www.phottix.com/ - Not much content here.
LCD SCREEN PROTECTOR:
Though the D300 already has a tough, tempered-glass screen, some like to have an additional barrier against scratches. People have recommended hard, glass protectors from GGS and DaProducts, as well as clear films from invisibleSHIELD and others. About $15 shipped, or less.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26687997
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26581029
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=25837466
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=25921782
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00N02o
http://www.ebay.com – GGS found here.
http://www.daproducts.com/
http://www.invisibleshield.com/digital-camera/nikon/d300.php
QUICK-RELEASE PLATES AND L-BRACKETS:
For Arca-Swiss style quick-release systems, Really Right Stuff (RRS) and Kirk are frequently discussed. Markins and Acratech also make custom-fit plates for the D300, while Wimberley makes a universal plate. Very roughly, $50 for a conventional plate, $150 for an L-bracket, and $180 for an MB-D10 grip L-bracket.
http://bythom.com/support.htm - Background info for beginners.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26068150
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=25893047
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26207364
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=25755691
http://www.reallyrightstuff.com
http://www.kirkphoto.com/
http://www.acratech.net/
Continued in the next post (exceeded 6,000 character limit).
canadianbc Regular Member • Posts: 166
Same...and thanks
Much appreciated.
Hugoneus Contributing Member • Posts: 854
Thanks.
(NT)
cwmartin Senior Member • Posts: 1,203
Re: New Nikon D300? - START HERE!
Thanks for the work putting this together. Maybe some day this site will put together an FAQ section for each camera model and this would be a good posting for that.
 cwmartin's gear list:cwmartin's gear list
Nikon D4S Nikon D810 Nikon D5
Re: Accessories for the D300
Continued from my previous post.
GPS:
A GPS with serial output can be connected with the 10-pin Nikon MC-35 cable. Alternatively, you can use an aftermarket solution connected by cable or Bluetooth, or even a DIY solution. If you already have a standalone GPS, free software is available to synch up timestamps between your photos and saved track logs.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26077562
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=24247805
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=25797845
– Garmin eTrex.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26497190
– DIY.
http://www.stockholmviews.com/diyphotogear/nikon_mc-35.html – DIY.
http://www.moosenewsblog.com/archives/2007/06/23/coolest-tool-ever-062307/
– Moose Peterson.
http://www.nikona.org/downloads/eZine34.pdf – Nikonians eZine, see pg. 7.
http://www.dawntech.hk/di-GPS/index.htm
http://www.solmeta.com/en/products_detail.asp?id=1
http://www.ayay-sir.com/
http://www.redhensystems.com/ – Bluetooth.
http://www.foolography.com/home.php – Bluetooth.
http://pc-mobile.net/nikongps.htm – Aftermarket cables.
http://code.google.com/p/gpicsync/ – Software solution, free from Google.
BATTERIES:
Can't go wrong with genuine Nikon, but some find aftermarket batteries to be an affordable and acceptable alternative. Either way, make sure you have a 3-terminal EN-EL3e or equivalent designed to work in the D300 (not EN-EL3 or EN-EL3a). Some have reported that older aftermarket batteries for the D200 no longer work in the D300.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26290438
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26226104
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26177811
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26706237
STRAPS:
Whether for comfort, convenience, or looks, some prefer an aftermarket strap. Some suggest OP/TECH or UPstrap.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26213439
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=16410461
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=25531865
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26507174
– Handstraps.
http://www.nikonians.org/forums/dcboard.php?az=set_linear_mode&forum=140&topic_id=808
– Anti-theft strap.
http://www.optechusa.com/
http://upstrap-pro.com/
http://www.tiffen.com/results.html?search_type_no=10&tablename=domke
http://www.pacsafe.com/www/index.php?_room=3&_action=detail&id=16
– Anti-theft strap.
BAGS:
Many options ranging from holsters to slings to backpacks. Perhaps it’s best to run a search.
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26299955
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26761489
http://forums.dpreview.com/forums/readflat.asp?forum=1039&message=26270968
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=26534566
http://forums.dpreview.com/forums/readflat.asp?forum=1039&thread=24990716
http://bythom.com/bags.htm – Thom’s thoughts.
http://www.cambags.com – Reviews.
http://www.kata-bags.com/index.asp
http://www.lowepro.com
http://www.naneupro.com/
http://www.shootsac.com/
http://www.tamrac.com/
http://www.tenba.com/
http://www.thinktankphoto.com/
http://www.tiffen.com/products.html?tablename=domke
http://www.tiffen.com/products.html?tablename=zing
DanielBan Regular Member • Posts: 231
Great idea, thanks!
OP B Bretz Regular Member • Posts: 403
Re: Accessories for the D300 - THANKS GOBEY!!!
Thanks gobey!!! awesome additions to the thread!!! I agree, I wish we could make a sticky thread with all of our contributions, oh well.
And thanks to everyone for their positive feedback to the thread.
Larry Auerbach Regular Member • Posts: 144
Thank you so much!
I was fumbling around Nikon's D300 webpages looking for
something like your Digitutor link and couldn't find it. Is it just me,
or is Nikon's website not designed in the most useful, user-friendly
way?
theresa Regular Member • Posts: 224
Brad that had to take some time and effort to put all that information in this forum I for one really appreciate this information I just got my D 300 and been 3 days reading manual. It is surprising all the tecknical information is there but not how to use it for what shooting situations.. this you have made easier by your offered links I really thank you . That is what is so great about this forum happy shooting to you too.
R Scott Webb Regular Member • Posts: 258
Tag/Thank you! n/t
momo Contributing Member • Posts: 859
Thanks for all this info (nt)
'Of course, there will always be those who look only at technique, who ask 'how,' while others of a more curious nature will ask 'why.' Personally, I have always preferred inspiration to information.' -Man Ray
http://www.grapefruit.zenfolio.com
http://morristaub.aminus3.com
bill henry Senior Member • Posts: 1,392
Very good, I only find one flaw,which is,
Folks have to have the ambition to go to the sights and actually apply themselves and read, HMMMM quite an assumption
LeeR Senior Member • Posts: 1,518
Good help....thanks. (nt)
Lee.
 LeeR's gear list:LeeR's gear list
Fujifilm X-T20 Sony a6500
Ms Barb
Ms Barb Contributing Member • Posts: 744
add: The D300 Lounge to the list
Loving my new D300, but it still has secrets locked inside that I haven't discovered. Thanks for the learning tools.
I haven't read all the replies so not sure if it has been mentioned.
But the Lounge is an info source as well.
http://www.nikond300.ning.com
And thank you for posting all the helpful info.
Barb ;}
thru the lens and into the world~~
Bmark Senior Member • Posts: 2,332
Good links, thanks.
Mark
 Bmark's gear list:Bmark's gear list
Sony RX100 II Sony RX10 III Nikon D800 Nikon D850 Nikkor AF-S 300mm f/4E PF ED VR +11 more
micklerlop Junior Member • Posts: 35
Thanks for the compilation
rdef01 New Member • Posts: 2
Thanks for the links. Got mine a week ago and haven't had the time to hunker down with the manual yet. Can't wait.
D a v e Contributing Member • Posts: 775
Agreed thanks!
Dave
 D a v e's gear list:D a v e's gear list
Fujifilm FinePix X100
scribe Regular Member • Posts: 378
This is great...thanks for posting!
