one touch bracketing
Started Feb 7, 2008 | Discussions
Mustbe Junior Member • Posts: 28
Is it possible to make multiple exposures or bracketing, with just one touch of the release button?
So I don't have to press the relaese button 5 times, in order to prevent camera shake? Yes I use a tripod.
Really I can't find it in d300's manual...
Happy shooting
Menno
Howard Moftich Veteran Member • Posts: 9,986
Re: one touch bracketing
use custom function f4, 5 or 6 to assign bracket burst to a button.
then set the camera to either CL or CH release mode
Setup your bracketing program/sequence.
press and hold the button you assigned and shutter. the camera will fire the entire
sequence and stop.
OP Mustbe Junior Member • Posts: 28
Thanks, a bit further. So I did but it still seems I must press the relaese button as long as the the sequence/bracketing takes. Correct me if I'm wrong.
Menno
trix Regular Member • Posts: 349
I would use a cable release to avoid movement.
Sagittarius Veteran Member • Posts: 8,267
Happy shooting
Menno,
Yes, it is possible. You can use intervalometer feature.
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon Z6 II Nikon Z7 II Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR Nikon Z 100-400mm +1 more
David Sulley Regular Member • Posts: 256
Interval timer.....
Set the bracket number of pics, say 5 at .3 stops
choose interval timer to take 5 pictures at whatever interval you choose, I choose 0. push OK and bam, 5 pictures
manel Contributing Member • Posts: 978
Interval timer.....
I was not aware of that, thanks. Good to know if you don't have the remote.
thats right. Personally I don't mind it and actually prefer it since it minimizes any finger movement once the sequence starts.
But as others note, you can do it w/ intervalometer etc.
Wow, usefull, thanks all, what a wonderful that camera it is...
okay I keep going on with experimenting HDR...
Menno
manel wrote:
Interval timer.....
remote.
Menno
Mark den Hartog Veteran Member • Posts: 3,679
can this be done with MLU
I always use mirror lockup and usually take the shot 4 secs after the lockup,....
now it would be very interesting to be able to automate all this in a single click
For HDR I found I would like to take only two exposures but with more separations than just one stop. What do you think?
I should try.. I read it somewhere in a online tutorial which tells me to take 3 shots overday en 5 by night. recommended. with seperations of one stop
Menno
