GGS LCD protector for D300
Started Jan 30, 2008 | Discussions
Photobug Veteran Member • Posts: 5,561
Thanks for Bob Elkind and others' recommendations. My GGS protectors for D300 arrived yesterday. They work out perfectly and protect both top and rear LCDs. I ditched the factory protector and there's no more interference with plates. Highly recommended.
B Pedit Regular Member • Posts: 435
from?
I got my GGS for the D200 from kaidomain.com but they don't seem to show the D300 version on their site. Where did you obtain yours?
Thanks,
Byrne
OP Photobug Veteran Member • Posts: 5,561
Re: from?
eBay. This is from the same seller:
http://cgi.ebay.com/LCD-Protector-Glass-for-Nikon-D300_W0QQitemZ180210985561QQihZ008QQcategoryZ50508QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If you search by "D300 protector", you'll see it from many more sellers.
Thanks,
Byrne
jgarnold Regular Member • Posts: 355
Re: GGS LCD protector for D300
I purchased one of these GGS protectors from Ebay a couple of weeks ago (it only took about a week to arrive from Hong Kong). It's easy to install and looks great. Much nicer than the stock plastic protector.
-Jeff
Joe Marques Veteran Member • Posts: 5,963
Couldn't agree more. No loss of quality or brightness. No glue on the LCD screen. Clearly more protection from impact than any kind of flexible cover (which only proctects against scratches).
Joe
 Joe Marques's gear list:Joe Marques's gear list
Sony a7 IV Samyang AF 50mm F1.4 FE Sigma 24-70 F2.8 DG DN Sigma 35mm F1.4 DG DN
breivogel Senior Member • Posts: 2,403
This appears to be the same as the ones sold by Giotto. I tried these on a Canon A710, and cracked both of them. Very Delicate, and not much impact resistance. Does have better AR then the plastic ones though.
 breivogel's gear list:breivogel's gear list
Panasonic Lumix DMC-LX7 Sony Cyber-shot DSC-RX10 Sony RX100 III Sony RX100 IV Olympus TG-5 +19 more
bob elkind Veteran Member • Posts: 5,832
stay away from Giotto protectors ?
much impact resistance. Does have better AR than the plastic ones
though.
The GGS protectors provide very good impact protection. Sounds like the Giotto protectors are much less worthy (and more expensive, to boot) than the GGS products. That's good information.
P.S. The DaProducts protectors aren't as thin as the GGS products, but they are otherwise equal to the GGS protectors. I tried both on my D200, and the GGS is my favourite (based on being thinner and having the sticky bead pre-applied).
  • Bob Elkind
 bob elkind's gear list:bob elkind's gear list
Nikon D3300 Nikon D850 Nikon AF Nikkor 50mm f/1.8D Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tamron AF 28-300mm F/3.5-6.3 XR Di VC LD Aspherical (IF) Macro +6 more
Wow, how did you manage to crack them?
though.
TrekSF6 Veteran Member • Posts: 4,092
Re: stay away from Giotto protectors ?
Thanks for the tip. I ordered one. I was just going to go naked with the D300 LCD but this GGS cover ooks a little nicer aesthetically than my Daprotector I have on my D200, so I went for it.
Scott A.
 TrekSF6's gear list:TrekSF6's gear list
Sony a7R III Sony a6600 Sony E 50mm F1.8 OSS Samyang 12mm F2.0 NCS CS Sony FE 28mm F2 +2 more
I think he cracked the Giotto protectors, not the GGS protectors. I don't think GGS even offers protectors for Canon A710. I could be wrong, however.
Or maybe there's a story behind the post, along the lines of a meteorite scoring a direct hit on the LCD :=) I'm not sure what he meant, specifically, when he said "cracked both of them".
  • Bob E
though.
I don't think so, these are very rigid and I'm confident they won't crack without a significant hit. How did you crack yours?
Joe
though.
Not a meteorite impact.
The Giottos are thin (
YES! stay away from Giottos protectors !
sticky tape around the periphery. You stick them to the LCD screen
(and also remove them with a hairdryer, if needed after they break!).
Since the center of the protector is spaced away from the screen by
the thickness of the tape, even a minor impact can crack it, say
hitting a belt buckle. Also, packing the camera in a bag, and
applying a bit too much pressure breaks it too. They are sold in a
variety of sizes (for DSLRs and Compacts_. Made in China, and might
be marketed under differnt brands.
Next time you have your hair dryer out, try putting a GGS protector on your camera body inplace of that Giotto unit. The GGS protector on my D200 has withstood the belt buckle test on numerous occasions... and I think it's also survived a meteorite hit or two.
  • Bob Elkind
I knew, but they look very similar. Either way I was curious how they were cracked. If a sharp object is used, even the toughest glass that thin will crack.
wrong, however.
  • Bob E
though.
Michelle Regular Member • Posts: 326
Giotto a bust for me, too.
They looked good in the camera store so I put one on and in very short order it was cracked every which way.
There has never been any trauma to the camera or rough treatment. I will never buy another one. Thanks for the lead on a better one.
Michelle
http://www.michellemahood.com
Bill McClung
Bill McClung Veteran Member • Posts: 3,364
Ordered Mine 14 JAN .... Received it today
Got mine off ebay:
http://stores.ebay.com/John-Camera-Store
Although the listing indicates that you will receive only the main LCD cover, the kit sent to me contained a cover for the main LCD and another cover for the top LCD. The directions were all in Chinese, but there are illustrations for us linguistically challenged folks. (all you do is peel and stick....and the backing peels very easily)
Fast shipping service (when you consider it came from Hong Kong) and excellent packing. Took less than five minutes to put both units on. Looks like part of the camera. The sticky part only touches the camera body, not the LCDs.
Haven't had any meteor strikes yet.
Bill McClung (a.k.a. 'NC BILL')
Image galleries at http://www.pbase.com/nc_bill
'Every other artist begins with a blank canvas, a piece of paper.....the photographer begins with the finished product.' --- Edward Steichen
Re: Ordered Mine 14 JAN .... Received it today
Indeed. The GGS protector is so much clearer than the scratched up factory one. It does the high-res LCD justice.
But just to set one thing straight to prevent confusion... the sticky part actually sits around the borders of the LCD glasses. They are cut exactly the same size as LCD glasses and do look like an integral part of the body.
Bill McClung wrote:
Got mine off ebay:
