D80, new firmware available
Started Jan 23, 2008 | Discussions
bertone61 Forum Member • Posts: 50
Hi,
has anyone installed it yet? The Update is not announced on the Nikon US site, so I hope its not a fake...
http://nikonasia-en.custhelp.com/cgi-bin/nikonasia_en.cfg/php/enduser/std_adp.php?p_faqid=5747
CU
Steve
kenwilkes Regular Member • Posts: 465
Re: D80, new firmware available
I installed it last night. There was a thread on it in this forum. I didnt experience any problems.
Ken
Tweekie Contributing Member • Posts: 638
Asia firmware on a US body? Is that safe?
EDIT: I did the update, works great, no difference from before other then a new version number haha, I guess if I really cared about the stuff it fixed I'd be more excited.
-Kevin-
Equipment specs in profile.
my photo gallery http://www.revtotheredline.com
Dileep Kumar
Dileep Kumar Contributing Member • Posts: 697
Hi Ken,
Good to know that you could do that w/o much trouble.
I downloaded the update 1.10 for windows and unzipped it. I could not find any instruction to install it in the camera.
Appreciate if you could explain to me how to do that in my D80.
Thanking you in advance for your assistance.
Dileep
Ken
gpzbeaner Junior Member • Posts: 26
What is it supposed to fix/improve?
Eric R.
'Remember; no matter where you go, there you are.'- B. Banzai
e268 Senior Member • Posts: 1,334
Here are the instructions
Dileep Kumar
Re: Here are the instructions
Thank you very much for the link.
Best,
Dileep
e268 wrote:
that I posted on the other post.
http://forums.dpreview.com/forums/read.asp?forum=1034&message=26462514
berdies Senior Member • Posts: 1,226
Works just fine ! Thanks for the link. Only remember to put A first and only and then B second and only on the card. Perform the procedure for A and B one at a time.
TripleDES Regular Member • Posts: 359
Here are the release notes - nothing significant to me
  1. The product will be “Certified for Windows Vista".
  1. Support for the new USB Media Transfer Protocol (MTP) has been added. The PTP option in the setup menu's USB item will be modified to MTP/PTP. The icon will also be modified.
  1. The effects of noise reduction processing performed at shutter speeds of 1 - 8 s with shutter speed set to “bulb”, when On is selected for Long exp. NR in the shooting menu, have been improved.
M@
Thomas Comerford Veteran Member • Posts: 9,745
Re: Here are the release notes - nothing significant to me
Does that mean that LENR now kicks in if the exposure is longer than 1 second? Previously the threshold was 8 seconds (according to the manual). Can someome try it and see?
M@
Snapsh0t
Snapsh0t Senior Member • Posts: 1,196
I agree, nothing that seems worth the upgrade. Unless someone knows of any hidden changes that do make it worthwhile, I'll wait for v1.20.
 Snapsh0t's gear list:Snapsh0t's gear list
Sony Cyber-shot DSC-RX10 Fujifilm X30
jwylie Contributing Member • Posts: 764
Good luck with the wait. Unfortunately, I think the only reason this was released was because of Vista compatibility issues. They threw in the others as padding. I doubt there will be any more D80 firmwares, just a D80 replacement. I could be wrong, but hey, it makes sense to me.
Sandozer Contributing Member • Posts: 779
I think it makes sense to do firmware updates as and when they are issued, Vista has been mentioned as being the main reason for the upgrade. There are other issues that have been addressed too. (RTFM). There may even be issues addressed that are not publicised, how can you tell?
It's FREE.. just do it...You know it makes sense....
 Sandozer's gear list:Sandozer's gear list
Nikon D300 Nikon D500 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED VR II Samyang 85mm F1.4 Aspherical IF +4 more
Yes, absolutely do it. It does make sense. Firmware updates are for the good of all and there should be more of them. I just dont think there will be many/any more for the D80. Sorry.
GlennA Contributing Member • Posts: 633
If Nikon didn't think it made sense....
....I don't think they would do it.
Thanks for the heads-up on this, just downloaded and installed....no problems.
eNo
eNo Forum Pro • Posts: 11,744
Thing is... to upgrade to v1.20, you will have to install v1.1 first. Might as well do it now.
Test everything; hold on to the good.
Old photos: http://esuastegui.esmartweb.com/c2020z
New photos: http://esuastegui.esmartweb.com/D80
JayMitch Senior Member • Posts: 1,515
If shooting RAW is there any benefit to the changes in noise reduction?
bertone61 OP Forum Member • Posts: 50
afaik: no!
Long Exposure NR is actually applied directly to the raw data, so if they have improved that function then yes there is a benefit even when shooting raw.
bertone61 wrote:
afaik: no!
