New firmware for D80 (version 1.1)
Started Jan 22, 2008 | Discussions
naqqaf
naqqaf Senior Member • Posts: 1,694
Re: New firmware for D80 (version 1.1)
so u think that Mr Leung could help translating..
but what does the firmware do?
makes it faster? new menu? what exactly does it do?
http://aliz.zenfolio.com/
A.Z.
Some people dream of success..... While others wake up early and work hard at it.....
philaitman Regular Member • Posts: 293
I was about to say this has been out for ages BUT I was thinking of 1.01 not 1.1 hopefully this is completely new and comes out over US/UK soon.
Then again 1.01 was a fix to improve long exposure Noise reduction so maybe it's not new.....
This weeks Favorite shot
http://www.flickr.com/photos/philaitman
David Bookbinder Contributing Member • Posts: 980
Looks as if it is primarily a fix for long-exposure noise reduction, possibly having it kick in at 1 second instead of 8 seconds (or adding the option to have it do so).
Hopefully an English version will be out soon.
David
tameria11 Senior Member • Posts: 2,538
translation from the link:
The latest firmware in the long noise-reduction] [a] and the shutter speed from 1 to 8 seconds after the shooting when a noise reduction to improve the effectiveness of treatment.
加えて、USBのプロトコル「MTP」(Media Transfer Protocol)に対応した。 In addition, the USB protocol "MTP" (Media Transfer Protocol) capabilities. これに伴い、セットアップメニューの[USB設定]内の[PTP]を[MTP/PTP]に変更し、アイコンも変更した。 With this in mind, the setup menu settings USB PTP] in [] [MTP / PTP] to change the icon changes.
また、Certified for Windows Vistaロゴを取得した。 The Certified for Windows Vista logo fetched.
Dave
Having fun!
http://www.pbase.com/tameria11
FourBeer Contributing Member • Posts: 622
I was hoping it would fix the problem where the frames per second rate was severely cut when long exposure noise reduction was turned on.
Bummer.
(unknown member) Forum Pro • Posts: 15,443
It's on the Australian site...
It's on the Australian site:
http://nikonasia-en.custhelp.com/cgi-bin/nikonasia_en.cfg/php/enduser/std_adp.php?p_faqid=5747&p_created=1200300185&p_sid=Jx6h5pWi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xMjM1JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
-The product will be “Certified for Windows Vista".
-Support for the new USB Media Transfer Protocol (MTP) has been added. The PTP option in the setup menu's USB item will be modified to MTP/PTP. The icon will also be modified.
-The effects of noise reduction processing performed at shutter speeds of 1 - 8 s with shutter speed set to “bulb”, when On is selected for Long exp. NR in the shooting menu, have been improved.
Apollo13 wrote:
There have the new version firmware for D80
but now status only have Japanese version ,
hope the other will coming soon
http://dc.watch.impress.co.jp/cda/dslr/2008/01/22/7781.html
Translate :
http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Fdc.watch.impress.co.jp%2Fcda%2Fdslr%2F2008%2F01%2F22%2F7781.html&lp=ja_en&btnTrUrl=Translate
Nikon Japan :
https://support.nikonimaging.com/cgi-bin/nikonimaging.cfg/php/enduser/std_adp.php?p_faqid=9921
Patco
A photograph is more than a bunch of pixels
Re: It's on the Australian site...
So since there's an English version there now who's feeling brave ;0)
Sandozer Contributing Member • Posts: 800
Ok , have upgraded to V1.1, and still have a working camera....
Same deal as the last upgrade (to V1.01 ), exact same method of installation.
MAKE SURE YOUR BATTERY IS FULLY CHARGED...!! it does take a few minutes to do.
Can't verify any of the Vista stuff as am using XP.
 Sandozer's gear list:Sandozer's gear list
Nikon D300 Nikon D500 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 300mm f/2.8G ED VR II +4 more
Vandyu Veteran Member • Posts: 9,056
I haven't downloaded the first update. Do you know if the second one includes the first as well, or do you have to do one then the other?
 Vandyu's gear list:Vandyu's gear list
Nikon D80 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +9 more
Vandyu,
I had already installed the earlier firmware update, and it does not mention this as a requirement. I would check before trying, or install the V1.01 first.
I find it to be good practice to keep abreast of firmware updates, that way you can never be far out of synch with the current firmware standard.
Ian
Thanks, Ian. I got my D80 in the fall of last year and read about the first firmware update, but decided if it wasn't broken, I wouldn't fix it. So, it's done well so far, but maybe it's time to update the camera's insides. I'm in the U.S. I'll see what's going on here.
Mr Graceful Senior Member • Posts: 1,123
My understanding is that you DO have to upgrade to 1.01 BEFORE installing 1.1.
http://www.flickr.com/photos/mr_graceful/
naqqaf
and what about the Mac users? r we suckers?
is there anything for us or I need to do it with a PC only??
A.Z.
e268 Senior Member • Posts: 1,708
Here is the instruction
which took me a while to find. I hope someone will find this useful.
1.
Download and expand the firmware files
2.
Format an approved SD card in the camera
3.
Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
4.
Copy to the top level of the card the downloaded "A firmware" file
5.
Disconnect camera from computer
6.
Update the firmware from the "Setup" menu
7.
Follow the camera's on-screen menus
8.
Repeat steps 2 through 7 using the "B Firmware"
9.
Re-format Card
 e268's gear list:e268's gear list
Fujifilm X-E4 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +2 more
LitoD80 Senior Member • Posts: 2,395
Cracks?
For one thing, they know Mac users don't need no stinking updates!
Just kidding, OK. So, at the bottom of the link offered above for Australia, third item up, download for Mac
BTW, anyone knows of a cracked version that will allow the D80 to behave as the D200?
Lito
D80 + Mac
naqqaf
Re: Here is the instruction
can I use an SD card. or I need to connect the camera to the computer?
1.
2.
3.
4.
5.
6.
7.
8.
9.
Re-format Card
A.Z.
Re: and what about the Mac users? r we suckers?
Can't find a pointer to the installation instructions anywhere on the site. How, exactly, do you do it? My D80 came with 1.01, so I've never investigated.
David
You can do it with just the card. I am doing it as I type this
Lito
D80 + Mac
