D300 Shooting Mode Samples
Started Dec 22, 2007 | Discussions
Joe Josephs Senior Member • Posts: 1,836
I used a few masterworks at NYC's MET museum to compare seven shooting modes.
The set below and the other sets available at http://jimi1127.smugmug.com/gallery/4031781#234711527 all progress in the following order:
Standard - Neutral - Vivid - D2X Mode I - D2X Mode II, D2X Mode III and finally Ken Rockwell's High Saturation Settings.
Tried my best to control those pesky variables - Used 50mm 1.8, Tripod, Timer,
A Priority, RGB Adobe, Auto White Balance, AF-S, ISO 200, Noise & Sharpening OFF. Gallery lighting was consistent.
Bottom line for me (and I assume you too) is subject matter determines settings (especially shooting mode choice) but I found the results a decent illustration of the choices open to us.
Apartment Houses, Paris, 1946
Jean Dubuffet (French, 1901–1985)
Standard Mode
Neutral Mode
Vivid
D2X Mode I
D2X Mode II
D2X Mode III
Ken Rockwell
steves7k Contributing Member • Posts: 626
Re: D300 Shooting Mode Samples
thank you for that
i had been wondering if it was worth the time to load up the d2x settings
now i don't think i will
breivogel Senior Member • Posts: 2,260
Which one best represents the original art?
 breivogel's gear list:breivogel's gear list
Sony Cyber-shot DSC-RX10 Panasonic Lumix DMC-LX7 Sony RX100 III Olympus TG-5 Sony RX100 IV +17 more
D200_4me
D200_4me Veteran Member • Posts: 4,519
D200 Picture Control...
You know the funny thing is, with a NEF file, you can even apply the Picture Style settings for D200 images, after the fact in Capture NX. Also the D2x modes too. Although from my experience in playing with those options, the standard D200 output usually looks better to me. I'm sure those pictrure style settings aren't intended for D200 NEF files though. Just found it curious you can do that in NX.
 D200_4me's gear list:D200_4me's gear list
Nikon Z7 Panasonic G95 Nikon Z 24-70mm F4 Nikon AF-S Nikkor 24-120mm F4G ED VR Panasonic 12-60mm F3.5-5.6 OIS +1 more
OP Joe Josephs Senior Member • Posts: 1,836
A darn good question and not easy to answer. Each of us has different & unique visual system but my sixty-one year old eyes 'sees' Neutral, Standard and D2X Mode I as close to the 'real' thing.
Intrepid24 Contributing Member • Posts: 534
Sixty-one, good for you. I'm not trailing you by much...
No wonder you have a knack at this.
The ken rockwell had me roaring. Hey Joe, it's not saturated enough!
DezM
DezM Forum Pro • Posts: 34,960
Interesting results Joe. It seems that the D300's "Vivid" setting is similar to the D2X Mode III setting, except it displays reds differently.
Also, how did you manage to use a tripod at the museum??
BTW, thanks for the heads up. I picked it up today and I am quite pleased
Dez
http://www.dezmix.com/photography
 DezM's gear list:DezM's gear list
Nikon D850 Nikon Z6
differently.
pleased
Ahhh, enjoy that new glass and by all means post some images soon.
I agree about the similarity between D300 Vivid & D2X Mode III. They both pack enough saturation punch without appearing cartoonish. One thing I come away with from this test is a willingness to shoot in Standard & Neutral, capture an accurate base image and afterwards apply filters & effects.
As to the MET & tripods - they're allowed on weekdays but NOT weekends. Of course flash is strictly verboten. Strangely my beloved Musuem of Natural History allows flash but not tripods (they do, however accommodate Triceratops)
http://www.amnh.org/
http://www.metmuseum.org/
RomanJohnston
RomanJohnston Forum Pro • Posts: 18,825
LOLOLOLOL!!!!! That last one made me laugh!!!
Thanks for cheering up my morning.
Roman
'Miles to go before I sleep.'
--Robert Frost
http://www.pbase.com/romansphotos/
DezM
Joe
differently.
pleased
Thanks for the heads up, but curious.......did you need the tripod w/the D300? You could've use ISO 3200 as I did downtown at the American Indian Museum.
Last night i was trying to sneak onto some state property to get a shot of this building that i've been wanting to shoot for awhile but couldn't get in. I will disclose the location later when I successfully capture this building. Don't want to jinx it
Dez
Nikon D850 Nikon Z6
hammonda1 Regular Member • Posts: 162
Good post
Ken Rockwell's OTT
Otherwise good pic's
Dave Hammond
I especially liked the D2X Mode III image because of the REDS.
As the photographer which mode gave the most accurate colour reproduction?
Dave Hammond
reproduction?
Hi Dave. To my eyes Neutral - Standard - D2X Mode I were closest to reality. But as I indicated in a previous response - one person's reality is another person's fantasy (or bad trip as we said back in the day). What I'm now leaning towards is capturing 'accurate images' and then alter to heart's content with PS, Nik Filters et al.
JulianK Regular Member • Posts: 263
Thank you for the tests. It will be probably impossible in a museum environment, but it would be interesting to place next to a subject like this a GretagMacbeth ColorChecker. Obviously, it can be done in a studio but would be interesting with a test like yours also.
Certainly a matter of personal preference. I like the Neutral mode. At this point I might be biased - I found it most acceptable to judge portrait photography prior to any PP, and to minimize PP.
I Googled the painting you photographed and got back a different painting. I was just curious how how other images are presented. I am wondering whether there is maybe more than one painting with the same title.
BTW - Triceratops get spooked by tripods. I hope this explains this.
same title.
I probably messed up the name of the painting. My google search also brought up a different canvas. I'll check the MET's home page.
Agree with you about Neutral (and Standard as well). They both produce close-to-reality images. When I want a bit more in-camera saturation I use D2X Mode III. All other image tweaks I leave to post processing.
I am fine with your error. I guess we will get more tests from the MET ... just kidding. Thank you again!
processing.
Phobos 790 Contributing Member • Posts: 626
The D2X mode I is great for natural skin tones. I'm glad i took the few minutes for the download...
Thanks for the color modes demonstration.
the more abstract the better
Neutral mode
If you use this, or the D2X modes, you should set the brightness to -1. This reduces the tendency of the D300 to make images look a bit washed out. Nikon recommends doing the for the D2X controls.
