Nikon D3 shoots Orion Nebula &....
Started Dec 16, 2007 | Discussions
Todd Hargis Senior Member • Posts: 2,293
Tonight I went out to a dark location and tested the Nikon D3 on Astrophotogragraphy and let me tell you, there virtually is NO noise in these images (ISO 800) for 3.5 minutes. I was blown away... Nikon sure pulled through oin this camera. I love my D3.
Now I used the same mount and scope for these shots as I did for previous images. I used the MC-36 remote timer for the exposures. Telescope is 1000mm f/5 unit. I hope you enjoy the images and I can't wait to get out and image more objects.
-Todd
The first image is Comet Holmes, a 3.5 minute exposure @ ISO 800.
Next is the Orion Nebula, which turned out so awesome.... ISO 1600 for 70 seconds! Wow, 70 seconds!Very little noise at all.
H36 New Member • Posts: 14
Re: Nikon D3 shoots Orion Nebula &....
Awesome, awesome shots...wow
Eric
LucVN
LucVN Forum Member • Posts: 74
Beautiful pictures, bravo!
Thanks for sharing.
 LucVN's gear list:LucVN's gear list
Nikon Coolpix P7000 Nikon Df Nikon AF-S Nikkor 50mm F1.4G Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 180mm f/2.8D ED-IF +10 more
puddleduck Senior Member • Posts: 2,513
Superb - how do you set this sort of shot up?
Why ISO1600? It this to avoid star trails etc?
photoforfun Veteran Member • Posts: 6,084
outstanding! Can you please explain a little...
Can you please inform me if you're doing this with a refractor of with a reflector telescope, which size and some more details. Isn't the weight of the D3 disturbing the setup?
I had a Tasco refractor 75mm(with motor) many years ago, but sold it, I'm ready to start all over again. What's the minimum I should be looking for? Which minimum budget?
Thanks in advance.
Kindest regards,
Stany
I prefer one really good picture in a day over 10 bad ones in a second...
http://www.fotografie.fr/
betamax Regular Member • Posts: 109
Re: outstanding! Can you please explain a little...
Exellent!! Thanks.....
Craig
OP Todd Hargis Senior Member • Posts: 2,293
Stany
Hi there....
I am using the Celestron CG-5 reflector telescope with the D3 attached to the focuser. ( D3 is not too heavy if you rotate the tube to where the focuser is on top). You definitely have to be careful not to touch the scope as it is not the most stable thing / mount available. My set up cast me approx. $1300.00 give or take. Here is the scope I bought: http://www.celestron.com/c2/product.php?CatID=11&ProdID=57
It has gone up some since I got one. I also have a 90mm Maksutov as a guide scope and use this eyepiece to guide with. http://www.celestron.com/c2/product.php?CatID=40&ProdID=265
It does take a while to get the hang of but worth it. As for a minimum budget, well that depends on how serious you get into it. To have a basic set up like mine, well $1200~$1400 will get you going well. I don't use the tube that much as I prefer wide wield photos.
-T
Isn't
Thanks in advance.
Kindest regards,
Stany
second...
Andy
I chose ISO 1600 to see how well the camera would handle the noise... which there was not hardly any. As for the set up, I used my 8-inch scope and attached the camera to the focuser using an adapter and T-ring for the camera. I then polar aligned the scope and used a guide scope to track with. Here is more info:
-T
Roger T. Senior Member • Posts: 2,523
Live View?
Just curious -- is Live View of any use in a setup like this? (Aiming, etc)?
 Roger T.'s gear list:Roger T.'s gear list
Panasonic Lumix DMC-LX3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DC-ZS70 Nikon D40 Nikon D100 +14 more
natureman Veteran Member • Posts: 3,979
Beautiful shots. Thanks for sharing them.
Georgi Veteran Member • Posts: 7,638
Very cool
I'd like to see a larger image of the Nebula
One more question for Todd...Re: Stany
Thanks Todd for the very usefull information
How Do you attach the D3 to the telescope? Can you give me also some info on the specific pieces?
Can you use all kind of different oculairs to get different magnifications or did that system change after so many years? (Astronomy as my main hobby dates from 1968 till 1974...)
Thanks in advance,
Kindest regards,
Stany
Hi there....
It does take a while to get the hang of but worth it. As for a minimum budget, well that depends on how serious you get into it. To have a basic set up like mine, well $1200~$1400 will get you going well. I don't use the tube that much as I prefer wide wield photos. -T
Thanks in advance.
Kindest regards,
Stany
second... http://www.fotografie.fr/
Kindest regards,
Stany
MBoatner
MBoatner Senior Member • Posts: 1,495
Nice work - beautiful shots. From the posts looks like the D3 is a handy little tool to have around the house
Mike
smhagger Senior Member • Posts: 1,425
Todd,
The guys over on the Canon forum aren't going to like you very much at all because you didn't process the pictures in the right way that prove that the D3 isn't going to be useful at all for astrophotography! LOL. I remember being a little disappointed a few weeks ago after reading their comments about the D3 and astrophotography. Thank you for blowing all their useless comments and 'proof' away with your examples!
Great work! M42 looks AWESOME as does the comet. Truly spectacular. I want to see more.
Sean
 smhagger's gear list:smhagger's gear list
Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 135mm f/2D DC +5 more
Re: Live View?
You know I forgot to try that... Now I wish I would have. The next time I attach this camera to a scope I will see what it looks like and report back by sending you an email.
-Todd
(Aiming, etc)?
Re: Very cool / Larger image posted
Hi Georgi, her is a 50% image of the nebula.
-T
Thanks Mike...
Yes a handy tool indeed.
http://www.pbase.com/todd991
Craig Robinson
Craig Robinson Senior Member • Posts: 1,211
Todd
If I'm not mistaken, I believe if you use live view you'll be able to zoom in and obtain a very precise focus...
Craig
Re: One more question for Todd...Re: Stany
Hi Stany... here is what you will need to attach the camera to the telescope
It is called a -adapter and they are made to fit all SLR's, it is a bayonet ring that you attach as you would a lens. Here is a link:
http://www.telescope.com/control/product/~category_id=photo_accessories/~pcategory=astro-imaging/~product_id=A0317
then this T-ring threads onto a camera adapter like this:
http://www.telescope.com/control/product/~category_id=photo_accessories/~pcategory=astro-imaging/~product_id=A0321
Of course this really depends on what type of telescope you have so you have to get the adapter that will work for you. You will have to call the store and explain to them what you have so they can sell you the right adapter. The link I gave was just an example.
As for the oculars, and magnification... they will come in handy for shooting the moon and planets. For images of deep space, galaxies, nebulae, etc., your best bet is prime focus from the scope. Increasing magnification greatly exaggerates tracking errors. And with a camera adapter with and ocular only the plossl eyepieces will work as most of the new ones will not fit into an adapter. The link I sent for the adapter will hold eyepieces.
-Todd
Thanks in advance,
Kindest regards,
Stany
Re: Todd
That would be cool!!!! I must try.
-Todd
Craig
