Best Simple Web Gallery program?
Started Dec 6, 2007 | Discussions
BrianPriceUK Contributing Member • Posts: 802
Hi
I don't usually get excited about programs, but httphotos must be one of the best little gallery creator programs I've seen:
http://www.digicamsoft.com/softhttphotos.html
No connection, just very impressed.
Brian Price
reid thaler
reid thaler Senior Member • Posts: 1,705
Re: Best Simple Web Gallery program?
take a look at this one: Free and looks like it has more options
http://jalbum.net/
Thanks!
Reid
Kodak Brownie
Argus 126
Quaker Oats Container Pinhole Camera
6po New Member • Posts: 10
httphotos is also a freeware and it has many templates, including Flash based templates.
Did you give it a try?
arer New Member • Posts: 17
I also have been using JAlbum, quite happy with it.
Example:
http://www.captured-light.com/Galleries/index.html
OP BrianPriceUK Contributing Member • Posts: 802
Hi
I like JAlbum too as it has many more options, but httphotos impressed me by its simplicity. I think even beginners could use it straight away and get a great Flash gallery with minimum effort.
Brian
Lin Evans
Lin Evans Forum Pro • Posts: 17,702
I couldn't get it to work...
Hi Brian,
I installed it and it returned an error message. I uninstalled it, ran registry cleaners, re-installed and repeated this process three times but was unable to get it to work. Even after uninstalling using the internal "uninstall" then running registry cleaner and fresh reinstall, it immediately returned the error as if reading from a cache.
It sounds like a great program and maybe I will try on a different system to see if I can get it to work for me.
Best regards,
Lin
BrianPriceUK wrote:
Hi
Brian Price
digicamsoft New Member • Posts: 12
Hello!
First of all, I'm glad some people get excited and welcome a new web gallery software: httphotos
It's made to be fast, simple, against bloatware!
It's not just a web gallery creator, it also helps to select your photos, organize them, touch-up, ...
I didn't expect someone to post about this new release on dpreview now!
In fact, httphotos is just fresh and there may be some little bugs here and there.
The intent was to bring it to a little bit more users so bugs can be fixed.
Now it spreads more and more, which is good, but some people can have a bad experience, like the last post I see here.
When I read that, I feel really confused! I would like to take this opportunity to explain that your bad experience can help us to improve the soft itself, but you have to tell us. You can send us private messages from the about page or use the forum.
Since I'm there, I will also help thru dpreview forum!
Thanks!
GreG
Re: I couldn't get it to work...
To Lin Evans:
My guess is that you've loaded some jpeg saved as progressive, and this is not supported for now. As a result, it crashes, saved your project, and each time you try to launch it again, it loads the jpeg and this makes a loop you can't exit!
This will be fixed, but for now what you can do is:
1/ click Start menu
2/ click Run
3/ enter %appdata%
4/ now you see application data folder
5/ select httphotos folder
6/ delete it
7/ you can now re-launch httphotos and try with other pictures
GreG
