2 serious bugs with 3D tracking and metering
Started Dec 1, 2007 | Discussions
jp Senior Member • Posts: 1,151
1) If you use ASF-C with 3D tracking then the metering (spot/matrix) always supposes that the subject is in the middle of the frame instead of under the selected AF point.
2) As the AF point tracks across the screen, the metering does not follow the AF point
This is a serious error that could lead to badly exposed pictures when using 3D tracking.
the first problem is worse than the second one but both should be resolved. Knowning Nikon, I doubt that they will ever adress it.
As a workaround you can take the following measures
always use the center point as a starting point for 3D tracking and
always have cf-f1 on when using 3D tracking: this locks the exposure of your subject when you alf press the shutter
It does not solve the problem completely because when the lighting changes, your subject will be incorrectly exposed anyway.
Sorry guys, I really whish my first post since I recieved my D300 would have been more in the style of "Yeehaaaa" but helas
cameras don't shoot people
People shoot people.
Raymond Bradlau
Raymond Bradlau Veteran Member • Posts: 5,736
Re: 2 serious bugs with 3D tracking and metering
Interesting, I would not have expected this. any custom function to change it to follow the AF point?
regards
Ray
follow the AF point
 Raymond Bradlau's gear list:Raymond Bradlau's gear list
Nikon D3X Nikon D5 Sony a6300 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +14 more
jeminijoseph Veteran Member • Posts: 6,550
May be you are right
The first issue must be causing the over exposure. I will try that tomorrow
follow the AF point
Jemini Joseph
http://www.wildbirdimages.com
 jeminijoseph's gear list:jeminijoseph's gear list
Nikon D500
Led566 Regular Member • Posts: 450
Could you please explain better?
I can understand the problem when you use spot metering, but with 3D matrix metering what you describe is completely counterintuitive (IMHO of course).
Raymond Bradlau
Matrix should be taking into account was is under the focus point carries the most weight.
If this is not the case lets hope this is a firmware issue
regards
Ray
(IMHO of course).
OP jp Senior Member • Posts: 1,151
Both spot and matrix have the problem
Exactly
Indeed, lets hope they correct it. But how are they going to know?
regards
Ray
(IMHO of course).
Raymond Bradlau
Re: Both spot and matrix have the problem
This is a big one, I shoot motor sports and really would like the spot and my AF point to be the same, I MUST have the matrix to work this way.
Did you find anything in a custom setting?
Not sure how to let them know I do not think they actually read there emailed requests, I seem to get generic answers to my tech questions like they have not really read it (there was only camera I had an issue with, it did get fixed but no communication ever took place, I gave up after 3 emails and just sent it to them).
Thanks for the heads up
Ray
Exactly
regards
Ray
(IMHO of course).
No custom function, unlike canon
With 1D canons you could disable the link between spot metering and AF point by means of a CF. It is totally superfluous CF because you always want that link of course. Nikon does not have such a oximoron CF so you always have the link.
This here is a real firmware error.
It was already in the D200 when you used auto area AF with AF-C, this gave you also a simplified 3D tracking and there the measuring bias also remained in the middle, but here it was not such a terrible problem. I guess they reused some software routines in the D300 firmware, or it was programmed by the same team that made the same mistake, only this time it has much heaviwer consequences.
Chroma Regular Member • Posts: 112
Are you sure...
Are you sure you are using a CPU lens and you are not in Auto-area mode? The reason I ask is page 102 of the manual:
Under "Spot Metering" -
"If non-CPU lens is used or if Auto-area AF is in effect the camera will meter center focus point."
Correction: spot metering has only 1 bug, not 2
With spot metering the initial focus point is used correclty, it is only the tracking that is not correctly followed by the metering system.
Both lenses I tried were G-type
JimPearce
JimPearce Veteran Member • Posts: 9,188
Two is a logical consequence of one jp.
This is at most one bug. I mean in the case of matrix metering: who would track using a spot meter and expect accurate exposure?
Jim
 JimPearce's gear list:JimPearce's gear list
Nikon D7100 Nikon D500
David Chin Forum Pro • Posts: 11,670
Thanks JP ...
I appreciate you sharing this information for the benefit of D300 owners.
JH1 Regular Member • Posts: 345
Re: Thanks JP ...
owners.
Is this actually a major issue at all?
I think we might be getting carried away with what we expect a camera to do and what we really need it to do.
Funnily enough my shots with an M4-P (with no in-built meter- I use a Sekonic) tend not to be wildly out between frames. Most people don't notice a full stop error never mind the even smaller ones this 'mistake' must throw up.
When people start complaining about this sort of thing I begin to wonder if they are actually photographers or technology freaks, who have lost sight of creating images and expect the camera to do everything for them.
If you are in an 'odd' lighting situation then I was always taught to get the metering sorted out before the event - it's funny how little it changes. The technology tends to make us a bit hyper about these things.
TwistedMelon Contributing Member • Posts: 559
They're certainly not going to know because of a post in this forum. Start a site with a domain like "NikonD300.com" or "NikonBugs.com" etc.. Use that site to clearly index all the issues you find and make sure there are very details and accurate steps to set up and reproduce in a testing environment. Send the same information to photo blogs.
You can also make sure to inform your dealer who may have a better connection into Nikon than you do. They can in turn perhaps have any Pros they deal with verify this and also move the issue up through Nikon.
You can also do the obvious. Send your camera back to Nikon for service with the same detailed description of the problem.
Again, posting in a noisy forum will help to bring the issue to the attention of a handful of people, but won't do much more.
Save pixels, please trim your follow-ups and don't quote attached images.
Anil Sudhakaran Regular Member • Posts: 142
You are completely wrong. In all Nikon cameras the metering follows the AF point being used. In case of AFS-C it uses whatever AF sensor is used by the camera achieve focus.
Only when you use Auto Area-AF mode does the camera use only the central sensor.
The is unlike Canon cameras where you have to specifically link the spot metering to the AF sensor through a custom function.
Bob Christensen 3
Bob Christensen 3 Regular Member • Posts: 437
Bug or design flaw?
HI,
Are you suggesting this is a bug, or a design flaw? Does the operation of the camera fail to conform to what the user manual states?
bob
 Bob Christensen 3's gear list:Bob Christensen 3's gear list
Sony RX100 III Panasonic FZ1000 Nikon D750 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Nikkor 16-35mm F4G ED VR +5 more
Anthony Medici Veteran Member • Posts: 5,725
Now if we add the word "initial" right before the word focus, I'd agree with you entirely. The dynamic tracking on the previous cameras does not show the movement in which focusing point is being used in the view finder. So there is no assumption that it will move the metering as the focusing adjusts points. The 3D tracking does. The metering is still using the initial focus point that was manually selected which is exactly like the previous cameras.
And... ?
 Anthony Medici's gear list:Anthony Medici's gear list
Nikon D800E Nikon D7100 Nikon 1 AW1 Nikon D810 Nikon AF-S Nikkor 500mm f/4G ED VR +1 more
d_light Regular Member • Posts: 190
on the previous cameras there is no assumption that it will move the metering as the focusing adjusts points, but it clearly can be seen on the capture that it doesnt. Also the acquired focus pont can't be checked on the LCD/ or in N.Capture/N.View and it's clear that in dynamic tracking the metering doesn't follow the target as the focusing does, but sticks to the initial focus point
The
agree
Domain is a good idea
I was immediately thinking of doing that too, but I am afraid that in the unlikey event that it becomes indeed popular and that it impacts nikon's sales, I will have a lawsuit on my hands which is something I would rather avoid.
I also thought of informing Thom Hogan who I have communicated with a while back. He has some connections. There are other important people here who may have the right connections to Nikon but I have no credibility with them.
