Maxxum 7D Repair Hints
Started Nov 23, 2007 | Discussions
Gui_rc New Member • Posts: 3
Re: Maxxum 7D Repair Hints
This was really helpful to understand the complexity of taking it apart thank you
 Gui_rc's gear list:Gui_rc's gear list
Konica Minolta Maxxum 7D Konica Minolta Maxxum 5D
Hi everyone how can I fix the FFB issue on a 7D in 2022? Thanks any help advice greatly appreciated
Joseph Balson
Joseph Balson Regular Member • Posts: 299
simple answer: you can't.
I think the only way you could find the small gears needed to do the fix is buying a used 7D that is allready fixed, therefore there would be no need to fix yours.
It's just some glass, some silicon and magnesium. It isn't a religion.
johnapp Regular Member • Posts: 423
a picture is worth a thousand words
Tis with the back removed, but you don't need to remove the display. notice the metal tab on the right, that is your hard resets
If you take off the back ,you will see a flap of metal . this is your reset button . With the battery out and the switch on push and hold it for 30 seconds. This will do a total reset on your camera. you only need to take off the back to achieve this. Good luck and a Disclaimer do it at your own risk to your health and to your camera's health. ps watch out for that big capacitor, you need to discharge it by way of a 300k ohm resistor. Having said that if you only go in from the back it should NOT be an issue. Again DO IT AT YOUR OWN RISK.
EXX
EXX Senior Member • Posts: 1,204
What about creating the required gears using a 3D printer?
 EXX's gear list:EXX's gear list
Konica Minolta DiMAGE A2 Sony SLT-A55 Sony a77 II Sony DT 18-55mm F3.5-5.6 SAM Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +18 more
Joseph Balson
I guess if you know this kind of stuff and manage to replicate exactly the tiny gear the repair could be possible.
neilt3
neilt3 Veteran Member • Posts: 3,008
Would it be possible to print such a small item with any degree of precision ?
( I'm not to well up on 3d printing , other than a general awareness !)
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
SQLGuy
SQLGuy Forum Pro • Posts: 12,664
DLP and, even more so, laser SLA, printers can do quite high precision. I can print 1mm helicoid threads on my AnyCubic Mono.
Here's a small part I printed for a Kodak DCS SLR/n (original, broken, part on the right):
I think I made that tab at the bottom a bit too long, but it works fine.
A7R4a with SEL2470Z, 55Z, and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Sony Mavica FD-91 Sony Cyber-shot DSC-S70 Sony Cyber-shot DSC-V3 +45 more
