D300 AF Fine Tune Feature examples
Started Nov 22, 2007 | Discussions
Commodorefirst Contributing Member • Posts: 795
Simply stated, it works wonders, :biggrin:
Some of my lenses worked better or worse on some cameras for slight front or backfocus at wide open apertures, I tended to shoot some lenses on certain bodies because at 1.4 or wide open, the camera was spot on with this lens but on the other D200 or D2Xs it might have back focused or front focused a bit. Every camera is just a smidge different, and coupled with the lenses, I actually had a card set up for which lens with what camera for those 1.4 or critical focus situations.
Well those days are over. I just took all my Prime lenses and set up a focus test and I was able to dial in all of my prime lenses with the AF fine Tune. They are in the memory and the camera automatically remembers the lens etc. etc. so Cool!:biggrin:
I left the camera overall setting set to default, and I found my 105Vr was spot on, the 50 1.4 was spot on, my 85 1.4 needed an adjustment of +10, which means it was front focusing a tiny amount at super close range, and my 35 f2 needed +5.
At ranges of 2' feet or so I was able to adjust the AF fine focus to move the focus point nearly an inch forward and or backward with a setting of +20 or -20. Very very nice. This of course means that at long ranges the front/back focus range is even greater. With my 180 Prime I was able to move the focus area at least a foot front to back at 40 yds.
Thought I would let you all know the good news. Very easy to use and very very nice. for those of us who shoot indoors wide open this is great news!
Wade
examples:
Examples (50mm 1.4 @ 1.4):
setup:
-20 setting:
-10, starting to come to center:
Centered, 0:
+20 toward the back:
Commodorefirst on the http://www
NikonD200timestwo,Past owner NikonD70CP31000CP5000CP5700
http://www.AestheticPhotos.com
antonoat Veteran Member • Posts: 3,771
Re: D300 AF Fine Tune Feature examples
Thanks very much for that info, if every post here was as helpful we would all be experts in no time !
Seems like a great feature and you have demonstrated it perfectly, thanks for your effort.
regards.
http://www.pbase.com/wildoat
lightavail Junior Member • Posts: 36
Great post,
This is very useful, and the more control you can have over the performance of your lenses the better.
Thanks a lot.
Matt
BLuver Forum Member • Posts: 94
Thanks for the info! Is the adjustment done by the camera or the user?
AllanW Senior Member • Posts: 1,286
3rd party lenses?
Hi and thanks for the test. This is helpful info.
Do you have any 3rd party lenses that you can try. I am still unsure if this only works with Nikon branded lenses.
Cheers
Allan
http://www.pbase.com/thrumyeyes
Raul Veteran Member • Posts: 8,402
AmAzInG test - NASA will surely be interested
arggggggggg
r
 Raul's gear list:Raul's gear list
Nikon Df
OP Commodorefirst Contributing Member • Posts: 795
user set and adjusted and once adjusted the camera will remember the settings with each lens.
NikonD300,D200,Past owner NikonD2XSD70CP31000CP5000CP5700
Nt You are welcome
Re: 3rd party lenses?
No, no third party, but I have heard if it has CPu it will work with others,
Lenses I tried so far, 35 f2, 50 1.4, 85 1.4, 105Vr, 180 2.8 ED-IF AF-D
Wade
NT Thanks you are welcome
David Chin Forum Pro • Posts: 11,670
Please don't ...
... delete the images as I've linked up to your post at http://www.dpnotes.com/nikon-d300-reviews-and-samples/#affinetune
And :BigThanks: for your post and sharing your findings!
Regards, David Chin
http://nikond300.dpnotes.com/
fortydee1 Regular Member • Posts: 256
Wow that is a killer feature
So simple...I bet it will be copied by other companies. I am a big nut on focus, i want good focussing.
SteveL54 Senior Member • Posts: 2,709
See this post
See this post
http://forums.dpreview.com/forums/read.asp?forum=1039&message=25722033
Steve
andye53 Senior Member • Posts: 1,272
Re: Wow that is a killer feature
I vaguely remember reading something about this in-body AF tuning, I believe this has been in the Canon 1D series bodies.
If that was the case, get your flame suit on!
 andye53's gear list:andye53's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Panasonic ZS100 Sony a6300 Sony E 16-50mm F3.5-5.6 PZ OSS +1 more
Beau Long Contributing Member • Posts: 972
A nice little perk. Thanks Nikon & Wade!
http://beaulong.exposuremanager.com
Gizmologist Regular Member • Posts: 328
Patented?
Not if Nikon was smart and patented feature. For example, the reason that you have to press the pop-up button on the built-in flash on your Nikon is because another maker patented the feature of an auto-pop-up flash when the light is too low.
Radu Grozescu
Radu Grozescu Senior Member • Posts: 1,781
Actually it is much better this way :-)
Gizmologist wrote:
the reason
It it worked in auto based on the light level, I would have to patent a tape over the built in flash to keep it in place
I would really hate to have the flash working without my consent.
And it was Canon with the 1D III which get to the market with AF fine tuning for different lenses.
Radu Grozescu
http://www.RaduGrozescu.com
Corporate & Editorial Photography
 Radu Grozescu's gear list:Radu Grozescu's gear list
Sony a6500 Canon EF 70-200mm F4L USM Samyang 8mm F2.8 UMC Fisheye Sony E 35mm F1.8 OSS Sony E 20mm F2.8 +4 more
subdoodle Senior Member • Posts: 1,310
Canon had it first in the troubled 1D III
(the one with the focus issues or recall) However Nikon brought it into the mainstream with the D300. For those that are picky about focus...it's a great feature, it would appear.
Re: Actually it is much better this way :-)
I was impressed when I read that spec when that body came out. I'm even more impressed we can have it in our D300 without having to spend $4000+USD to get a body that has such a useful feature.
ThomasMiller Senior Member • Posts: 2,735
THANKS so much! That's fantastic to be able to fine tune lenses. As most of us know variations are subtle, but pretty common. I had a sample variations on Canon and Nikon glass, so this is great news!
Two more days!
Thomas
