18-200 VR Distortion?
Started Nov 19, 2007 | Discussions
chester0711 Regular Member • Posts: 143
Getting some bent horizon lines with my 18-200 VR.......any advice on how to correct this in post or a way to keep it from happening during shooting? It looks like a fisheye effect almost??? Any suggestions........
 chester0711's gear list:chester0711's gear list
Nikon D700 Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +3 more
Maike Contributing Member • Posts: 962
Re: 18-200 VR Distortion?
Well you're going to need some software. It's hard to know what to suggest, there are so many options. The ultimate is probably DxO Optics Pro as it's tuned to particular lens/camera combinations and automatically corrects depending on the focal length of the actual shot ( http://www.dxo.com ).
Rectilinear Panorama ( http://www.altostorm.com/products/ ) is another option that works differently but does a good job.
Also many of the editing software products like Photoshop CS3 have distortion correction filters you can use.
If you're looking for a free option, try this page here for a tutorial on how to do this with hugin (free software - has Windows version).
http://www.linux.com/articles/55174
or you might look at the Gimp free editor.
http://www.gimp.org/
I don't know for sure that it has a distortion filter but it's extremely full featured, so I would be surprised if it doesn't, or if there isn't an add-in available.
Hope this helps,
Mike
suggestions........
Rick L Contributing Member • Posts: 907
I would second what's been said above, with this added issue. The 18-200 is particularly troublesome in that the distortion (if you look closely) is not as simple as most lenses at the wide end (e.g., getting more curve toward the edges in a continuous way), but is actually kind of "wavey". The only software that I know that really can take care of this is one modeled to the particular camera/lens combination, i.e. DXO. That's what I use, and it really improves the quality of this lens, including uneven sharpness issues as well that can't be addressed with simple sharpening filters. But it is another chunk of change, and many people hate the interface (maybe because it's different than they are used to, although I've gotten used to it and like it).
Rick
Rick L
http://www.pbase.com/ricklawrence/root
Interesting points Rick. I've been experimenting with the DxO demo and have been very impressed (with 18-200). The $169 is like you say a "chunk of change" though. I'm waiting for it to go on sale
Mike
and like it).
Rick
Rick L
OP chester0711 Regular Member • Posts: 143
I appreciate the feedback, Unfortunately I figured this was going to cost another chunk of change (DxO is expensive!) I knew this was the only sure fix though.
I have CS3 ....I will give that a shot.
Bruce Irschick
Bruce Irschick New Member • Posts: 23
Re: 18-200 VR Distortion? PTLens Plug-in?
Has anyone tried the PTLens plug-in? It's only $15.00 USD and I know it has a database of lenses. I just don't know if it handles the complexity of the 18-200 VR lens very well.
 Bruce Irschick's gear list:Bruce Irschick's gear list
Nikon D300 Nikon 1 V1 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +5 more
Check out Ken Rockwell's suggestions for correcting the 18-200. I haven't had a chance to check if the numbers he uses are helpful, but it may give you a place to start.
http://www.kenrockwell.com/nikon/18200/18200-distortion.htm
Mike
I haven't tried it recently. I wasn't all that impressed with the last version I tried but it was a while back and it may have improved. The database seems pretty generic so it probably just corrects the general curvature, which you can do pretty well with the native CS3 filter.
Mike
Don't hold your breath for a sale, they are about to come out with a new version.
Rick
Rick L
tunney Regular Member • Posts: 154
I just got back from Europe last month and used my D200 and 18-200 lens while on the trip. I got a lot of distortion especially when shooting buildings/churches. I easily corrected them in Adobe CS3, which has a lens correction filter.
Tunney
 tunney's gear list:tunney's gear list
Nikon AF-S Nikkor 85mm f/1.4G
Wilfred Wong Contributing Member • Posts: 624
PTlens
Big Daddie Contributing Member • Posts: 936
If one subscribes to DxO's newsletter, eventually they get some coupon code for a small savings ($20-$30 usually).
