Minolta 5600HS on A200, will it work?
Started Sep 24, 2007 | Discussions
jojoc Junior Member • Posts: 45
I have an A200 and a 2500D flash combo. I want something with swivel head so that I can still bounce off the ceiling even when I shoot in portrait orientation. There is a post in our local ebay for a Minolta HS5600 at a very good price. I was wondering if this will work with the A200? The reason I asked is that its not the 5600-D model for digital cameras. But since my cam is not a sophisticated dSLR, I am hoping this flash will work also.
Any experiences with this set-up anyone?
iammobay Contributing Member • Posts: 576
Re: Minolta 5600HS on A200, will it work?
This question comes up from time to time. There was only one "5600" model from Minolta, the Program Flash 5600HS(D). This model will work with the Dimage A200.
This flash is typically not in the bargin bin, so make sure it is not really the older 5400HS which does not support pre-flash TTL and will not work in program mode with digital camera models.
OP jojoc Junior Member • Posts: 45
My bad... I just checked right now and its the 5400HS they were selling and not the 5600HS-D. Anyway, thanks for the tech answer. At least, now I know.
Canon 64 New Member • Posts: 9
Owners of Sony or Minolta type flash guns who- The flash MUST be attached to the camera and both turned on in the funcion button on the camera it should be on "Wireless mode" you will then be able to use wireless setting on the flash gun 1/1 power setting is default but can be set to 1/2 for less power the W/L symbol will show but the most important thing the Flashgun will emit a red blinking from the AF sensors this will mean that the wireless function is working and ready to fire wirelessly from the camera.
Two Minolta Flash Gun that DO work fully with Sony DSLRS with the old Minolta Hotshoe are as follows
Minota 3500 HS-D
Minolta 5600 HS-D
Unless you have The D prefix no other Minolta Flashgun will work in full TTl Mode
The above two flashguns came out basically for very late  Film then Digital KonicaMinolta DSLRs , basically the flashguns above were also later marked as Sony  AS long as your Sony DSLR has a a Minolta type hot shoe both Minlta HS-D will fully co-operate with your DSLR also wirelessly follow the instructions the Flash operaring manual if you dont have a manual they can be downloaded
Many people have not attached the flashgun to sync the settings of the camera to operate wieless control and thought the flash did not work in wireless mode.
neilt3
neilt3 Veteran Member • Posts: 3,008
Minota 3500 HS-D
Minolta 5600 HS-D
The O.P asked this 15 years ago , and was last seen here 7 years ago .
I think they've either figured it out or moved on !
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
MikeInOr
MikeInOr Senior Member • Posts: 1,630
True, but it is still good information to have.  Someone out there into old cameras might find the information very helpful!
 MikeInOr's gear list:MikeInOr's gear list
Sony SLT-A55 Sony a7R IV Sony 20mm F2.8 Sony 100mm F2.8 Macro Sony FE 12-24mm F4 +11 more
SQLGuy
SQLGuy Forum Pro • Posts: 12,664
Minota 3500 HS-D
Minolta 5600 HS-D
Mentioning wireless in this context is confusing, as, on newer cameras, these flashes cannot act as wireless triggers. On a newer Sony you can use a newer Sony flash as a trigger to 5600HS(D) and 3600HS(D).
For something like a KM7D or Maxxum/Dynax 7, you should use the built-in flash as the trigger.
But, yes, in the hotshoe, or on the ADP-MAA adapter (for MI shoes) these flashes are fully functional with anything from late Minolta through latest Sony.
A7R4a with SEL2470Z, 55Z, and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Sony Mavica FD-91 Sony Cyber-shot DSC-S70 Sony Cyber-shot DSC-V3 +45 more
