New Nikons: another rumour
Started Sep 15, 2007 | Discussions
bobn2
bobn2 Forum Pro • Posts: 70,300
I have a friend who works for Renesas Corporation, and he was talking to me about the development work they do with Nikon. He returned from a trip to Japan recently, and let me know some of the things going on. I'm not sure how much credibility to put on what he said - he doesn't follow photography, but since two of the four camaras ohe described were clearly the D3 and D300 he's got something right., The other two cameras are very interesting.
They seem to be the top end FX and low cost enthusiasts' FX which everyone has been asking for, but they seem to be coming out in a form completely different from what anyone expected. Both seem to be rooted in a homage to Nikon's past.
The high end camera is designed as a prestige camera to outdo anything Canon have. Target price will be $10000 at least for the lowest spec model, and it's aimed at studio and scientific work, as well as those who just must have the best. It is the modular camera that people were speculating on - Nikon couldn't make the cost equations work for the D3 which had to compete with the 1DIII, but with the price ceiling removed everything's up for grabs. The body shares the D3 AF and shutter, but almost evrything else is new. Several sensor modules will be available, including one with the D3 sensor, another 'well above 20MPix' and both will be available in monochrome. Another interesting option is a 6 MPix FX sensor which will allow ISO 51200 native (don't know whether monochrome or Bayer). Nikon's new non Bayer sensor will also debut on this camera. The viewfinder system is interchangeable, with both electronic and optical options, at least one with a style that harks back to the Photomic head. The base camera body is apparently quite small, but gets bigger when all the options are added. FPS depends on pixels, it will run at 9FPS with a 12MPix sensor, or 5-ish with a 24MPix, but there is a grip with an extra EXPEED processor, which doubles the frame rate (mirror up only above 12FPS). In camera processing is, apparently almost completely user configurable (it was the details of this that my friend was involved in). The modular construction precludes proper sealing, so this isn't a PJ camera. Expect it to be released with an 'F' number rather than a 'D', either F7 or F7D.
The low end FX camera is supposed to come in at around $3000, using the present D3 sensor. Its cost means the cost of the body has had to be severely restricted - but Nikon has taken a radical solution to this to meet the price restraints without compromising quality - the camera is not an SLR, it's a 'digital rangefinder'. AF uses contrast detection off the sensor, so there's no mirror or AF assembly. Metering is also off the sensor. The direct view finder has an overlaid internal QXGA LCD which displays variable frame lines (thus allowing zoom lenses) and, if MF is selected, a 'digital rangefinder spot' in which the rangefinder image is taken off the image sensor, and thus operates with a diagonal split. It shares the XGA rear LCD of the D3/300, which is the preferred mode of operation for macro work and non AF lenses. This is not an F-mount camera. Originally it was to use an updated Nikon S-mount, but will actually use an electronic M-mount. This has no mechanical couplings, so although standard M-mount lenses will operate, focus and diaphragm are uncoupled. It will be released with a remounted version of the 45/2.8 pancake, and other 'NM' mount lenses will become available, perhaps modernised version of classic S-mount lenses. An adapter allows mounting of F-mount lenses, with full function only for AF-S lenses. The lens mount decision has been made to allow the camera to be very slim, and it is somewhat smaller in size than a Leica M8, but styled after an SP. The whole thing has been contracted out, probably to Cosina. It has an 'S' series name, maybe SD or SP-D. There's also a rumour that the same camera will be released by Sony/Zeiss, badged as a Contax (having sorted out the wrangle with Kyocera).
As I said, my pal is not a camera nut, so didn't think to ask about detailed feature set, but if they're OK, for me the SD sounds like a brilliant camera, even if the F7 is way out of my reach, or needs. Would anyone else consider a camera this radical?
Bob
Robert Bedwell Senior Member • Posts: 1,304
Re: New Nikons: another rumour
If any of it is true your friends job is in danger. Not only that but the company is in violation of non-disclosure agreements. I can't imagine a company like Nikon not requiring their vendors to sign a non-disclosure agreement.
Slough Senior Member • Posts: 1,809
It is curious that your friend is not a camera nut, and yet he knows so many technical details.
I am not competent to comment on the validity of your posting, but the rangefinder sounds strange. If we assume it uses the Nikon F mount, it would still need the mirror chamber. And the mirror and prism do not add much to the price.
One alternative might be that they will produce a rangefinder using the old Nikon rangefinder lenses. But then the lens to sensor distance would be small and they would be back in the territory of the Leica M8 and have similar problems with sensor vignetting.
It does not make sense to me, though I may be wrong.
bobn2
OP bobn2 Forum Pro • Posts: 70,300
Admittedly, some of this is my interpretation after asking him questions.
Read my post, it doesn't use the F mount. I think the mirror and prism add considerably, otherwise low cost cameras would not resort to pentamirrors. It's interesting whether the market would have taken to a pentamirror in a $3000 camera.
This is something on which I have no information - but I might speculate that the full coverage microlenses are less angle dependent, and that the spend some of the DR doing digital vignetting correction (as do Leica)
So might I, I just passed on what sounded interesting to me.
Bob
bobn2
I did discuss this, he doesn't seem too concerned, as long as I don't identify him - there's a number of people who know this, apparently. Maybe he's going to a new job. BTW, this is not a vendor, it's the supplier of many of the chips in the camera.
Bob
xpherion Forum Member • Posts: 56
some more linfo about renesas technology
http://resource.renesas.com/lib/eng/edge/11/special02.html
n057 Veteran Member • Posts: 8,683
Don't you think it will be easy for Renesas to know who it is that spilled out the beans?
And for Nikon to be upset that one of their partners leaks information about their future plans?
Do you think your friend will still be a friend once the news are spread all around the world?
JC
 n057's gear list:n057's gear list
Nikon Coolpix 995 Nikon D200 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G +7 more
If true, then Renesas might soon no longer be a supplier to Nikon.
michaeladawson Forum Pro • Posts: 17,543
I'm not sure what you mean here. But let me take a guess and you can confirm.
1. The only advantage to use F mount is to use current lenses
2. F mount lenses require a certain distance from film plane
3. This distance is to allow for the mirror box on SLRs.
4. Once you have created the mirror box, including the mirror itself is low cost
5. Rangefinder advantage is compactness. Mirror box negates that.
So you could put an F mount on a rangefinder but "why" is what you are saying?
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
bloomoose
bloomoose Veteran Member • Posts: 3,224
Thanks, Bob for the information ...
... sounds very interesting, the digital rangefinder at 3.000 with FX sensor. I understand that this producst is in development and might never be realised, though.
The modular body sounds familiar, I remember I read something about that at bythom.com ... the price sounds rather steep.
greetz, pam
 bloomoose's gear list:bloomoose's gear list
Pentax 645D Nikon D750 Sony a7R II Nikon AF Nikkor 20mm f/2.8D Nikon AF Nikkor 105mm f/2D DC +7 more
bobn2
All say is that my contact isn't too concerned - he doesn't think he can be easily identified, there are a lot of people in the know. I've had similar information (not in the camera field) from the same source before, and it was correct. I can't speak for his motives, but as I say, he's not worried, even about it being posted.
I think they're both part of the same combine, so they are likely to go on working together, regardless of the actions of some employees.
Bob
dylanear Veteran Member • Posts: 3,441
Thanks for the info, but...
While the high end pro body sounds fascinating, the range finder product sounds far fetched. An interesting product, but SO far out of line with the current product. If it worked with the old Nikon rangefinder lenses perhaps, or the F-mount, but all new lenses would not be likely at all. Why save yourself some trouble by making a simple rangefinder only to have to design and build all new lenses. Would be interesting competition to the Leica M8 I guess.
I for one want a simple, compact, slow if need be, but pro build and ergonomics FX SLR.
 dylanear's gear list:dylanear's gear list
Nikon D300 Nikon D700 Olympus OM-D E-M5 Nikon D800E Olympus PEN E-P5 +7 more
Ronaldhogenboom Senior Member • Posts: 1,142
Yes, nice. It sounds like someone has a really good imagination.
Don't get me wrong, it would quite something if they would cook something up like that but I can't believe it.
The FX camera we'll see first is a 5D competitor.
Amateur photographer. Defined as someone who makes no money with photography, but also as someone who takes no cr*p from people who do.
http://www.lookupinwonder.nl
BRJR Forum Pro • Posts: 13,641
Thanks, For The Link
xpherion:
Quite interesting.
BRJR ....(LOL, some of us are quite satisfied as Hobbyists ..)
 BRJR's gear list:BRJR's gear list
Nikon D700 Leica M9 Nikon AF Nikkor 14mm f/2.8D ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 20mm f/2.8D +21 more
confirm.
is low cost
are saying?
Correct.
Mike Dawson
OldMaster Senior Member • Posts: 1,813
The company is clearly bonafide enough...incredible amount of quite detailed information from some one who is not a camera nut!!
However, it all actually sounds plausible doesn't it. I doubt Nikon have enjoyed Canon's supremacy at the top end. They have cleverly marketed and outsold Canon quite substantially at the consumer end. It is about time they created some peerless product just to show they can...and they like to make cameras and not too bothered with photocopiers and general office equipment!!
They have always had a place in medical and research and were always highly regarded.
Whatever their plans I am certain we are going to see some superb and innovative product from them... the D3 sensor is indeed just the start.
As a long term Nikon user, all I can say is that I am glad I have not switched camps 'cos I suspect they have something actually not just special but dedicated to their professional users just around the corner.
Iliah Borg Forum Pro • Posts: 29,046
Dear Bob,
For the last 4 years I keep hearing from Nikon folks something like this: "Well...modular won't happen, at least not for many, many years" and this: "I know from our engineers that it is just not practical on many fronts"
no text
TechAnimal Regular Member • Posts: 308
Iliah Borg vs. Julia Borg
Ok this is a bit off topic but i just have to ask, any connection between Iliah and Julia?
Petruska Veteran Member • Posts: 9,260
Nikon recent survey sent out...
about two months ago and confirmed here on this site by a few posters contained many questions on how one feels about a modular approach and interchangeable view finders. These two topics were heavily stressed throughout the survey so it sure looks like Nikon is heading toward the modular approach and makes a lot of sense to produce different levels of performance using one body and making maufacturing logistics more doable on a sigle body production line than trying to set up idividual lines for particular cameras. Plus costs should be lower overall and profit higher using the modular approach.
Ronnie T Contributing Member • Posts: 573
Too bad the FX in D300 body everyone is hoping for doesn't show in the radar. I guess Nikon doesn't want to position their models exactly right after Canons like the 5D. I'm sure though it will come later when D3 sales will start to taper off and D4 is about to be introduced.
That $10k camera will be a jaw dropping for the pros. If it is indeed true, Nikon is making a statement here that, if you are a pro, come back to Nikon.
Anything can now happen in DLSR world. Who would have thought that the D3 will be at 25,600? Bring on the 51,200 ISO!
