Too much retouched?
Started Sep 9, 2007 | Discussions
alex.di Contributing Member • Posts: 568
Re: Too much retouched?
I think it's great, but to address those who say it's too dark, you might try adding a graduated midtone adjustment that leaves the immediate foreground dark, but brings up the middle third of the picture.
I don't have PS on this system to try that, but it seems like it might help.
Larry David Forum Member • Posts: 85
here's my try
nice picture that needs little help. it isn't stunning, but it isn't boring.
Last chance to purchase glamorous boots and hats.
Pam R Veteran Member • Posts: 3,421
Another idea...
There doesn't seem to be any focal point in this image. Maybe that's why it felt kind of blah to me. That and I don't think the color is helping. Maybe if you play up the relationship between the flower and the light breaking through the clouds it would help. Try to tell a story...
Before:
Pam
http://www.pbase.com/pam_r
'art is working on something 'til you like it...then leaving it that way'
andyroo770 Regular Member • Posts: 163
Re: Another idea...
Hi Pam, I like what you did, can you please explain how you created the sun rays in the upper right of the image??
sandy2037 Junior Member • Posts: 46
Re: Apply Gloss
Hi mdl50: May be elementary question but can you explain how do apply gloss to an image. I would like to learn. Thanks. Sandy
mdl50
OP mdl50 Veteran Member • Posts: 3,211
Re: Take free plugin, I took ...
... the Red Paw Media (RPM) Beautifier filter to add gloss. Play with the switches, and fade afterwards. then (un)sharpen.
mdl50
Re: thaks Pam, which technique ...
... did you use to get the sunrays in the edge?
BTW, nice Pbase site you have, your photo art folder is marvellous!
jptenor Regular Member • Posts: 180
For me the image is dramatic but a touch too heavy, particularly the foreground.
I had a go at it in Capture NX:
I selected the trees & everything nearer and applied a little D-Lighting to it, just brightening the absolute shadows.
I used the Double Threshold technique to identify the darkest & lightest areas and set Black & White control points on them. This set the total dynamic range.
I used colour control points to bring out each poppy flower and each cow parsley flower, to provide spots of interest.
Light rays workflow...
Here's how I did the light rays. You can do them in the image you're working on, but I created mine as a new image:
1 - open a new layer. Fill with 50% gray:
2 - Go to Filter> Noise> Add noise and use these settings:
3 - Go to Filters> Blur> Motion blur and use these settings (for larger sizes you will need to run the filter again by hitting Ctrl+F until you get clear lines). Ctrl+F applies the previously used filter again (very handy to keep in your list of shortcuts):
4 - Now to give some shape to the rays. Hit Ctrl+A or Select> All. Then Ctrl+T to enter Transform mode. Hover your cursor inside the bounding box and right-click to pull up the transform options. Choose "Perspective". Or, you can go to Edit> Transform> Perspective:
5 - grab a bottom corner handle and pull out. Grab a top corner handle and push towards the middle to get a shape similar to this:
6 - Copy the rays (Select> All, Edit> Copy merged). Paste into your image (Ctrl+V) and move it into position. Add a layer mask, invert the mask (Ctrl+I), then paint white to reveal the rays:
7 - Blur the rays to your taste using Gaussian blur. Experiment with blend modes. Screen, Soft Light, and Overlay are good starting points:
Have fun!
Pam
BALLhead Forum Member • Posts: 94
Re: Light rays workflow...
This will come in handy. Thanks!
Wilkev Veteran Member • Posts: 3,711
Great instructions Pam, they've been saved for future reference/use. Thanks.
Bill
http://www.pbase.com/wvphoto
http://williamvogt.zenfolio.com
mdl50
Re: WOW Pam! I wouldn't have come to that ...
.. myself. Thanks a lot !
tbnj Contributing Member • Posts: 805
Saving for later (nt)
Tina
Everybody has to start somewhere. Here's my start.
http://www.captured-photo.com
ratherbsouth Regular Member • Posts: 275
Re: Saving for later (nt)
Me too... cool effect
joe filer Senior Member • Posts: 2,934
Thanks Pam
Your tutorial was fun to work with. It gave me a couple of ideas that might elaborate on the effect. I tried these additions:
Increase the contrast of the motion blurred rays image.
Add a few additional white beams with a white brush, constraining to vertical by holding the shift key.
Blur the beams before pasting the image into the scene. Then the transformation will also increase or decrease the blur.
I added a mask with a radial gradient to fade the beams.
Finally painted in a few spots on the mask to correspond to holes in the clouds.
Could also paint on mask with a low opacity white brush to highlight beams falling on the flowers.
My 2¢ worth
Joe Filer
Mahomet, IL
http://www.pbase.com/filer
My still camera history: http://www.pbase.com/filer/image/49099880/original
My wife is proud to participate in the Alzheimer's Quilt Initiative!
http://www.alzquilts.org/
She has met her first $1000 promise for Alzheimer's research and is working on her second $1000. Cheer her on at: http://www.amisimms.com/1000promise.html
 joe filer's gear list:joe filer's gear list
Canon PowerShot G3 Canon EOS 20D Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 +5 more
DigitalDetailer Regular Member • Posts: 304
Just Tagging...nothing to see here...
