Hp lens error! please help
Started Jul 19, 2007 | Discussions
bronge New Member • Posts: 1
ok i dropped my camera which is a hp photosmart
and an error pops up on it everytime i try to turn it on
lens error m525-12 (7f80)
then a m525-22
pops up shortly after
what do i do!
please please help.
Jim Cockfield Forum Pro • Posts: 16,342
Re: Hp lens error! please help
Most of the time when you see those types of errors after dropping a camera, it means that something in the lens mechanism was displaced (usually a small nylon gear has moved and is jamming the mechanism), and would require dissassembly of the mechanism to fix.
I have seen users report banging a camera fix those types of things, freeing up a jammed gear (but, you'd risk damaging it if you tried that).
Sometimes users have figured out a way to fix these types of problems themselves. But, I dont' know where you'd find any instructions. So, it would probably be a trial and error type of thing if you wanted to give it a go, and you'd risk damaging it even more if you're not careful.
I'd get another camera (chances are, it would cost more to repair it than it's worth).
