5D Mark II
Started Jul 2, 2007 | Discussions
Dany C New Member • Posts: 2
5D Mark II
I found this in a German forum.
Maybe something's going on.
Icypeak Senior Member • Posts: 2,523
doomed
Without the direct print button, it is doomed to fail as a professional camera
David
http://www.davidfantle.com
;-)Lint Forum Member • Posts: 83
Re: 5D Mark II
3 by 4 screen ratio?
Earthlight Veteran Member • Posts: 3,209
Where do I sign? ;)
These actually look pretty good to me. Let's hope we'll see the 5D successor in fall.
Earthlight
ps. WOW! We can actually edit our messages now! Very cool!
Mostly harmless
Fovea Contributing Member • Posts: 779
Re: 4/3 screen ratio
Looks odd, but then it is a standard (and may be cheaper) format for LCD screens...
And then, data could be shown underneath for horizontal pictures, and vertical images would be bigger.
What I'm eager to see is whether focus points are going at least to the thirds !
 Fovea's gear list:Fovea's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 17-40mm f/4.0L USM Canon EF 50mm F1.4 USM Canon EF-S 60mm f/2.8 Macro USM +3 more
PIXSultan New Member • Posts: 12
How do you edit them?
...I have a LOT of work to do...
successor in fall.
Earthlight
TIP: If you do not like this post, simply press the 'COMPLAINT' button. Mommy/Daddy/GrandMa/GrandPa are just one click away.
Barugon Veteran Member • Posts: 9,148
Re: 5D Mark II
http://bildupload.sro.at/a/images/3-1.jpg
http://bildupload.sro.at/a/images/61-2.jpg
Interesting, even though they're fake.
[edit] I edited this message just because I can.
Whoever said 'a picture is worth a thousand words' was a cheapskate.
http://www.pbase.com/dot_borg
PIXSurgeon Veteran Member • Posts: 4,009
Still not sure...
...How you can do it...
8-)
GOT IT! I now see the button. BOY, I have TONS of cleaning to do! 8-)))
TIP: If you do not like this post, simply press the 'COMPLAINT' button. Mommy/Daddy are just one click away.
Ocean View Regular Member • Posts: 295
Looks like they will incorporate the silver flash shoe similar to the 1DIII.
 Ocean View's gear list:Ocean View's gear list
Canon EOS-1Ds Mark III Canon EOS-1D Mark II N Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 +9 more
But is is a one-time deal...
...and then seems to get disabled, once you edit...
200mm Senior Member • Posts: 1,210
1DIII.
good on pointing that out. so maybe this one could be a real one. there is exif info on the pics..
Roger.
' Nothing is so firmly believed as what we least know'
Re: But is is a one-time deal...
Yup, looks like we get one chance to correct mistakes.
Where did you see the edit button ?
I can't find it...
Re: 5D Mark II
okay, but now for the inside. will it have sensor shake dust removal, even lower noise at higher iso, still higher pixels?
Matt_Anderson
Matt_Anderson Veteran Member • Posts: 3,787
Edit works slick.
Could they potentially put the MKII 1ds 16 MP sensor in a 5D ?
 Matt_Anderson's gear list:Matt_Anderson's gear list
Sony a7R III Sony FE 24-105mm F4
LCD screens...
The LCD on the current 5D has a 4:3 aspect ratio.
Rumle
Rumle Senior Member • Posts: 1,502
Re: 5D Mark II
It gots to be fake there is no print button.
l2u/l\Le
 Rumle's gear list:Rumle's gear list
Panasonic Lumix DMC-LX3 Fujifilm X70 Nikon D3S Nikon D200 Nikon D700 +21 more
Abe Tong Regular Member • Posts: 368
is this for real ?????????????????? Re: 5D Mark II
since there have been so many fake 'preview' of upcoming cameras, not sure how 'real' is this one. kinds suspicious since it looks like formal release photo instead of spy photos.
Jason Chan Regular Member • Posts: 228
Mode dial angle?
Is it me or does the mode dial on the top left look too angled to be natural? It is noticeably steeper than on the current 5D.
vtpeters
vtpeters Regular Member • Posts: 285
I think it's a fake
You can clearly see part of the top of the mode dail in both the front view AND rear view image of the camera. As if the dail was slightly tilted to the front when the front view image was taken and slightly angeled towards the rear when the rear view image was taken.
Usually these kind of shots are 'flat'. Too much of the top of the mode dail is visible on these images to make them believeable 'leaked' product shots.
On the other hand, I could be wrong ...
Victor Peters
 vtpeters's gear list:vtpeters's gear list
Nikon Z6 Nikon Z 70-200 F2.8 VR Nikon Z 24-70mm F2.8 +4 more
