AutoMeter IV-F is stuck. Known issue?
Started Jun 16, 2007 | Discussions
Prognathous Veteran Member • Posts: 9,328
My AutoMeter IV-F doesn't respond to any button presses. It's just stuck there, displaying ISO 100 and shutter speed 1/60. Replacing the battery and leaving it out for a long period of time has no effect.
Is this a known issue? Anything to try besides sending the meter for service?
Thanks,
Prog.
 Prognathous's gear list:Prognathous's gear list
Sony a77 II Tamron SP AF 60mm F2 Di II LD IF Macro Tamron 18-270mm F3.5-6.3 Di II PZD Sony DT 16-50mm F2.8 SSM Olympus Stylus 1s +13 more
OP Prognathous Veteran Member • Posts: 9,328
Re: AutoMeter IV-F is stuck. Known issue?
First and last bump...
Prog.
Andr Giongo Regular Member • Posts: 130
If you look at it in a front view, u can notice a litle button on the meter´s head, close to the whithe ball at the 4 o´clock position. That button should blink the meter display when pressed, like a "reset". You can also try to move that yellow arrow in the battery chamber, but that will make your meter loose it´s callibration. To do that you should have another meter in order to get a metering comparsion.
Hope it can help. Let us know the results, ok?
Good luck!
André
http://www.fotologia.com.br
Thanks for the suggestions, André, but unfortunately neither of them worked. I guess I'll have to get the meter serviced.
Prog.
Cope
Cope Veteran Member • Posts: 6,331
Kenko bought the rights to the Minolta meter line. You might contact them about service.
'A man will occasionally stumble over the truth, but most of the time he will pick himself up and continue on.'
Winston Churchill
 Cope's gear list:Cope's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tokina AT-X Pro 12-24mm f/4 (IF) DX +3 more
JusGene Veteran Member • Posts: 4,258
Just a general idea...
I haven't had your problem. I did have one which 'lost' it's sensitivity where the calibration wouldn't adjust enough to make it right.(I bought it used...)
One thing I recall with some devices with similar problems: I disassembled a couple of malfunctioning devices and reassembled - some worked like new again while others had no effect. I think sometimes cables or electronics 'get loose' or get dirty.
I think of this like a malfunctioning keyboard they I fixed by 'banging' it up-side-down. I've seen stranger things....
Gene
I live in Minoltaville, just inside Sony City , successfully waited the 7D upgrade.
'The only thing easier than being wrong .. is denying it!' -me
MaxxuM 7 Digital
Lucato New Member • Posts: 14
Hi, I'm facing exactly the same issue. Did you get to fix it? If so, how did you solve it? Thanks.
neilt3
neilt3 Veteran Member • Posts: 3,008
You might be better sending the OP a PM .
Bearing in mind this is a 15 year old thread , they probably aren't keeping an eye on it .
The OP does seem to be still active here but might not visit too often , a PM would flag up in his personal email address .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
