CHDK firmware hack discussion (12)
Started Jun 15, 2007 | Discussions
zdravko Junior Member • Posts: 48
This is a sequel to the old threads discussing the CHDK firmware.
The CHDK fw is a hacked firmware for DIGIC II cameras. Currently
supported cams are A610, A620, A630, A640, A710 IS, S2 IS and S3 IS
(see the FAQ for a complete list).
The CHDK fw implements new features like RAW, battery indicator,
live histogram (RGB/luminance), zebra mode (blinking areas of
over- underexposure), DOF calculator, scripts (intervalometer,
exposure/focus
... bracketing etc.), text reader, file browser,
calendar, games and much more. New features get implemented
frequently, so check the timeline for the latest changes, or the
FAQ for a complete list.
The CHDK firmware does not touch the original firmware of your
camera. It is an additional program which gets loaded into the
memory of the cam. If you have a problem, just turn your cam off or
remove the batteries, and the CHDK fw is gone.
For further information, a guide, download links and FAQ see the
english WIKI:
http://scratchpad.wikia.com/wiki/CHDK
Timeline:
http://tools.assembla.com/chdk/timeline
Dear Vitalyb, GrAnd and all the others: Thank you so much for
creating this wonderful piece of software!
Some screenshots:
Main menu
Histogram (Blended) and Zebra overexposure indicator
Script menu
Link to the previous thread:
http://forums.dpreview.com/forums/readflat.asp?forum=1010&thread=23558340
sandra deeley New Member • Posts: 16
Re: CHDK firmware hack discussion (12)
so could you have this loaded onto one memory card...and use another for 'ordinary shooting' and when you wanted to use raw...take out the card with the hack loaded onto it, and just use that one?
rlx
rlx Senior Member • Posts: 1,360
David
microfunguy wrote:
Just spellout a suitable email address.
rlemieu(a)cooptel(d)qc(d)ca
These are beautiful little mechanisms driving a leadscrew and
fitted with position and rotation sensors.
If one is taking 6 microns as the circle of confusion, that means
that a single step of the focusing motor nearly takes the focus
from the hyperfocal distance to infinity. That behavior is
similar for all zoom positions.
Of course, you have assumed a single thin lens moving in a
simple linear fashion. We don't know if those assumptions are
justified.
I started just taking measurements without making many
assumptions. Then I added that assumtion and the model fits the
data not so badly. I agree that with better measurements one
could get into more elaborate models.
What may be of practical use, is to use the new feature to move
the lens to a certain position and then find-out what distance
it really corresponds to by using magnified centre of screen
and moving subject.
What do you have in mind here? Using the center of screen to
focus at 7.3 mm ... I didn't have much success when I tried it.
David
Richard
OP zdravko Junior Member • Posts: 48
that one?
Yes, you catched the point
BUT, if you do not need CHDK to load every time, just do not execute the procedure of making the card bootable (leave it unlocked).
And if you want to use some of the other features of CHDK (like the battery indicator, DOF calculator etc), but not to save RAW files, you have the option from the CHDK menu to disable saving RAW.
Zdravko
microfunguy Regular Member • Posts: 234
'StereoData Maker' for Canon Compacts
Thanks to the excellent work by Vitalby and GrAnd, it has been fairly easy to add features to CHDK that provide on-screen display of certain parameters to aid stereo photography.
Thanks to 'znanev' and 'Jcduc' for testing (n6mod did not reply to emails).
The data can also be saved in CSV or XML files and displayed with the image by a mere click of the mouse.
This addition is called 'StereoData Maker' and is available here http://stereo.jpn.org/eng/ .
Be sure to also download the very popular 'StereoPhoto Maker', it autocorrects the errors in your images to make viewing comfortable.
You can create stereo photos with a single camera by moving it between exposures and for outdoor photos simply shift your balance from one foot to the other so the camera moves about 65mm.
Surf the web for 'stereo cha-cha'.
David
Re: Distance numbers
OK, it is tricky with the 7.3mm but I am suggesting that moving the focus motor to a particular position should be very precise and repeatable.
We just need to check, especially for macro, where the distance is measured from.
I am suggesting you measure or estimate distance (or use calculated hyperfocal) and use feature in 'StereoData Maker' to move to that position.
Press ALT + DISPLAY.
I will now send you version that increments distance in variable-sized chunks, it will be interesting if you get the same numbers that I do.
I have put the simple lens equation into a spreadsheet and with an 'infinity' image-distance of 7.304004mm and a stepper movement of 3.666 microns can get object distances very close to the 'allowed' distances.
David
Vahooka New Member • Posts: 2
Did you notice that on A640 when you flip the display out it sometimes turns completely grey? It happens when the ALT mode is not active and when the display is flipped out in such way that the screen should be mirrored (left-> right). It never happend with older revisions of CHDK. And if you turn ALT mode on the screen will go normal but when you turn it off it will go grey again.
Russel_Sprouts Regular Member • Posts: 300
GrAnd wrote:
http://forums.dpreview.com/forums/readflat.asp?forum=1010&thread=23558340&page=8
Build #129
+ uBasic: Added commands - "wait_click" and "is_key". To be able to write interactive scripts.
I peeked at the source code and it appears the new is_key command
can accept any of the following as arguments. Correct?
display
down, up, left, right
erase
flash
iso
macro
menu
mf
print
set
shoot_full, shoot_half
timer
video
zoom_in, zoom_out
timed (vs eternal) wait?
Regarding the wait_click command:
It would be helpful to have an optional argument available so that the wait isn't necessarily eternal.
wait_click x
(where x is time, in ms or sec, until the command exits if no keypress)
If no argument is passed, the wait is absolute/eternal
As-is, without an inbuilt "timeout" for the command, I'm unsure how to wrap code around it to allow breaking out of the loop after a specified time has elapsed
print "More? (12 max)"
print "click RIGHT to increment"
print "[5sec wait for input]"
goto wait_five
:wait_five
let s=s+1
if s=> 5 then return
wait_click
is_key k "right"
if k=1 then gosub "k_right"
sleep 1000
goto "wait_ten"
:k_right
if a
return
The situation represented in this example reminds me:
If the 5 line runtime OSD overlay isn't an imposed uBasic limitation,
I wish a runtime command was available (??? set_plines xx) to force the OSD to display the script author's desired number of lines.
With only 5 print lines avaliable (or 4, considering that one line will be used for [waiting for input] prompt) it's sometimes impossible to present sufficient info to the user within one "screen".
Marty Too Senior Member • Posts: 1,219
RAW update?
Andre (or anyone else who knows),
Is there a new RAW implementation? I took a few test shots this morning and the RAW seemed absolutely great (or grand if you wish). I noitced that Vitaly listed some RAW update on a recent release and wonder if I am actually seeing the better RAW as it seems.
I did notice something that others might want to comment on. I saw purple fringing in the Cam2PC browser that was not present with Picasa and the Gimp.
GrAnd Regular Member • Posts: 325
Fragglerock wrote:
Just a simple question. I convert all my RAW to DNG.
Since the beginning of the hack i keep all my originals RAW
(CRW_XXX.JPG).
Now it began to be very heavy in my hard drive.
Do you think it's usefull keep them or i just need to keep DNG ?
IMHO, You do not need to keep both files. The only difference between them is the file format. No difference in the image data.
Did you enable 'Flashlight' option?
display
[snip]
Yes. This command accepts the same button names as 'click/press/release' commands.
Re: timed (vs eternal) wait?
wait_click x
keypress)
[snip]
In current implementation you can't emulate 'timeout' because the script will pause at the wait_click command.
This limitation is just 'by design'. Just to not overwritel whole screen.
Actually, I do not think that it is useful. In the beginning there was no console at all and nobody complained.
donmorris Regular Member • Posts: 155
Hi,
I collected all the scripts posted on pages 1 and 2
http://scratchpad.wikia.com/wiki/CHDK/uBASIC/Scripts#User-written_Scripts_-_Page_01
They are in a zip file here.
http://www.mediafire.com/?bcwcjgilzi7
If anyone needs it,
Don
Re: RAW update?
It is impossible to get 'new' RAW. The RAW always is the RAW. CHDK can save two 'types' of RAW - RAW and RAW with dark frame substraction. Vitaly just implemented the another way to save absolutely the same types of RAW. And I even have not integrated his approach yet.
gorton Regular Member • Posts: 131
Re: RAW update?
his approach yet.
I have a question, for RAW with dark frame substraction, is it only for the exposures over 1 second?
So that's how you activate flashlight... I was wondering. But anyway... I noticed that when the display flips (left-> right) all characters flips as well and it's not readable... that would be probably difficult to fix, right?
szek New Member • Posts: 21
(CRW_XXX.JPG).
DNGs seem to be much bigger than CRWs ( 10 vs 6 MB for 5MP photo), don't they? Is there any purpose other than compatibility with different software to convert CRW to DNG ?
Shadow clipping indicates black background in playback mode
Hi, I have noticed that if the camera is set to indicate shadow clipping it will also indicate black background when it is in playback mode whenever background is visible.
Cheers
