mike earussi
Has anyone made a direct comparison between the two to see how much actuial improvement in IQ/resolution there is?
--What I see so far is that SD14 reaches optimal resolution of
current lenses (higher resolution scared no chance for handheld,
lower like SD10 details broken sometimes).
Pic above is with SD14 - a messy corner of Saigon, see original here.
http://www.pbase.com/image/80389969
Rgds,
Hung
Well, couldn't it be both?Thank you for your reply. Unfortunately, because he does not use
the same software to process both cameras, the comparisons merely
show how much better the new software is, not how much of a
difference there is between sensors.
How much difference between sensors? I presume OP means in resolution or in what way? In resolution, for a comparison, of course you can take the technical figure (aka Roland style, analyze data) I'm not being scarcastic, I mean you can do the figures analysis. Or you can anecdotally describe what happens 'in the field.' BUT if my experience, that will vary with the scene. In a well-lit highly detailed scenes, say cliffs across the valley or landscapes in Monument Valley or out west or leafed out trees and foliage, the SD14 will capture more detail. How much? what % more? To which leaf? Very hard to say. I see this in my own photos. But I think the difference might be hard for others to perceive.Well, couldn't it be both?Thank you for your reply. Unfortunately, because he does not use
I really like that picture.
Mike
Rgds,
Hung
'America is not at war,
The Marine Corps is at war;
America is at the mall.'
--How much difference between sensors? I presume OP means inWell, couldn't it be both?Thank you for your reply. Unfortunately, because he does not use
Where the advantage of the SD14 comes into play for me isn't pure
resolving detail, but that it has greater latitude around different
ISOs so different shooting circumstances. Like in the woods on
Sunday http://www.flickr.com/photos/sandyfleischmann From how the SD14
worked there -- compared to SD10 in deep woods (Muir Woods) last
year -- the SD14 would be my choice to take on the next walk too --
More later --
Best regards, Sandy
[email protected]
http://www.pbase.com/sandyfleischman
http://www.flickr.com/photos/sandyfleischmann (Sunday's SD14s)
In N
--Yes, you're saying rather much the same as I'm saying, other
varibles matter. But I have seen a difference in detail captured,
upon close scrutiny of photos and prints.
BTW, the cherry blossoms I mention in another post weren't what may
be termed 'false detail' as the blossoms were blossom shaped,
irregular in positioning, not a regular symmetrical pattern like
the balustrade effect of #s of lines.
Best regards, Sandy
[email protected]
I just wrote a long reply post and lost it; shorter reply. We're writing/talking about several different qualities: the 'pop' which is more color differentiation, edge rolloff, color contrast. And then the detail in foliage.It's strange but I'm finding absolutely no difference in the
rendering of distance foliage. The crops I have done of trees and
forests - well, you couldn't tell whether they came from the Sigma
or the Canon.
I'm really puzzled as to the circumstances where the 'magical'
qualities of the Foveon sensor can be seen because I can't
reproduce it.
I see it in my own photos, I've shot the same scenes with different cameras, looking for grass, foliage detail. For example, look at the foliage and the background and building detail in these photos of the 'cow barn' http://www.pbase.com/sandyfleischman/fujifilm_f30_pointshoot Of course, people will say, 'different times' but I've taken this scene over and over, with different cameras. It's near my moth-in-law's home in PA. And the results are consistent: the SD10 and SD14 capture the best detail. The x530 (with small Foveon sensor) hangs in there pretty well too. More shots here of grasses, reeds at the end photos http://www.pbase.com/sandyfleischman/samples_sigma_1020mm__or_other_ex&page=all I had other cameras too side-by side but the photos aren't online. Also the scenes in the top part of that gallery, I've shot with different cameras.When people come to the conclusion the sigmas can do foliage better
did they do so after side by side testing or is just retrospective
single image conclusions?
There have been some side by side tests for the Nikon d200. It was not what I would call "really distant foliage", but more like 100 yards or so. To my eye the results were interesting because the d200 kinda picked up a little more detail (which it should due to more pixels in the final image) while the sd10 which it was matched against had better roll off (which it should due to no interpolation, and no AA filter).It's strange but I'm finding absolutely no difference in the
or the Canon.
reproduce it.
