anyone know about TC / AF-S compatibility issues?
Started Jun 9, 2007 | Discussions
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,437
I have a 300 F4 AF-S ... I recently got a TC17e for it and the combination on my D70s behaves strangely. The LCDs flash, meter goes haywire, and it won't auto focus.
I isolated it to the lense this way:
Tested the lense and body with a known good TC14e.
Tested the lense and TC on a store demo D200 body.
Ergo, the lense is the common element. That lense with any TC does not work on any body.
I took it into a local camera store that has a good reputation for repairs. They took it onto their bench and returned the verdict that the lense and body are fine. The TC is likely at fault. I repeated my story that it failed with a known good unit (known to work on a 70-200VR anyway) and he smiled and said he'd seen multiple TC failures of this type.
So ... what to do? Send the whole kit to Nikon? Or send back the TC and try TCs around the city until I find one that works with my lense? If I never find one, I'll be forced to send the lense to Nikon anyway.
Note: The lense really does work great on the D70s without the TC.
Comments?
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Panasonic Lumix DMC-GX85 Nikon D7200 +17 more
k3rry Regular Member • Posts: 235
Contacts?
Have you tried cleaning all the contacts?
I've seen similar problems due to dirty contacts
 k3rry's gear list:k3rry's gear list
Nikon D2H Nikon D3S Nikon D5 Nikon D500 Nikon AF-S Teleconverter TC-14E II +12 more
Kim Letkeman
OP Kim Letkeman Forum Pro • Posts: 33,437
Re: Contacts?
I'm pretty sure their technician would have done that while he was testing everything.
Pradipta Dutta
Pradipta Dutta Veteran Member • Posts: 9,791
Can you do another simple check
All the E series TCs are known to work fine with AF-S lenses. However, you got to remember that at effective F/6.7 (because you will lose 1.5 stops when you attach 1.7x TC on the F/4 lens) unless you have very good light, AF will not work very well. This is particularly true on a D70s body that sports a relative weak auto focus module - Multi CAM 900.
So, do this very simple test - take the combo out when it is the brightest - probably around 3pm to 4pm. Point it to a very contrasty subject and try it out.
I think, when you tried there was just not enough light for the combination on a D70s body.
Speed is significant and interesting but accuracy is downright fascinating
http://www.pbase.com/pradipta
 Pradipta Dutta's gear list:Pradipta Dutta's gear list
Nikon D800 Nikon D3 Nikon D2X Nikon D3200 Nikon AF-S Nikkor 24-70mm f/2.8G ED +5 more
Pradipta Dutta
One more thing
Check out the TC on a F/2.8 lens. If it works, then the TC is just fine.
BTW, I would be tempted to conclude that if you upgrade your body, the lens + TC combo will likely work ok in reasonable light.
Kim Letkeman
Re: One more thing
fine.
I do appreciate the help, but I did try it in bright light. I had it out in midday sun.
Also remember that the auto focus is the last issue I mentioned. The flickering displays and the inability to meter are actually more important and obviously point to an electrical issue with the lense or the TC when used with this lense.
And also remember than I clearly said that I tried it on a brand new D200 body, so upgrading the body won't do anything. Note also that my D70s is only a year and a bit old.
Pradipta Dutta
Hmmm...get the whole combo checked out by Nikon
I sure missed those points. If I were you, I would get the whole combo checked out by Nikon.
Kim Letkeman
Re: Hmmm...get the whole combo checked out by Nikon
Trying like crazy to avoid being without my cam for a month
Mike Neary Veteran Member • Posts: 3,355
Maybe time for a new body while you wait ?
Mike
Joseph S Wisniewski Forum Pro • Posts: 34,385
Well documented issue...
Nope, they had no TC failures, at all.
Many AF-S lenses, including specimens of the 300mm f4 and the 70-200mm f2.8, have an electrical problem that only shows up when you increase the resistance between the camera and the lens. The teleconverter adds more resistance in the form of an extra set of contacts and a skinny piece of ribbon cable between the two connectors. It often brings out these problems in a lens.
Nikon has this well documented, and performs what they call a "grounding modification" in the US, and an "earthing modification" in the UK. I don't know what they call where you are in Canada.
Nope. Send just the lens, and tell them that you have camera blackouts and lockups only when that particular lens is used on a teleconverter. They'll know exactly what to do.
Or send back the TC
lense?
There's no "magic TC". You'd have to make one, by rewiring it for less resistance, and giving it better contacts.
Nikon anyway.
Comments?
Find a new dealer. (well, you asked)
Normally, a signature this small can't open its own jumpgate.
Ciao! Joe
http://www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D3 Nikon D2X Nikon D90 Nikon D100 Nikon Z7 +45 more
Here's the link...
And here's the post from a fellow who watched the Nikon technician perform the modification while he waited, and saw the Nikon document.
http://forums.dpreview.com/forums/read.asp?forum=1030&message=9602000
Ciao! Joe
Another "simple check"
Actually, they don't.
Many 70-200mm f2.8 and 300mm f4 AF-S lenses (and I'd heard the 300mm f2.8, 500mm f4 and 600mm f4) have a problem dealing with high resistance between the lens and the camera. It's especially likely to show up with a D70 or D50 body. Add a teleconverter, and you get exactly the problems that Kim described.
A good check is to really increase resistance. Kenko converters and tubes have higher resistance than Nikon converters, and are notorious for "setting off" problem lenses. So, a quick test is to put the lens on a D70 with a pair of Kenko 1.4x converters, or two or three Kenko tubes. That will definitely show off the problem.
Nikon does a free "grounding modification" on problem lenses. One wire, and it makes the lens immune to higher resistance.
Ciao! Joe
Kim Letkeman
The perfect excuse is at hand
Kim Letkeman
AWESOME!!!! That's the answer I was looking for.
Kim Letkeman
Re: Well documented issue...
And again, I can't thank you enough for this info. I googled the heck out of it and could not get a hit at all.
It'll be grounding here.
Well, there goes my excuse for a new body
Comments?
I shall definitely chastise them ... this they should have known.
Kim Letkeman
Re: Here's the link...
document.
And once more ... thanks very much. Proving once again the immense value of these forums besides the obvious entertainment value of the bickering.
David Rosser
David Rosser Veteran Member • Posts: 3,491
All this does not alter the fact that Nikon do not guarantee autofocus to work if the resulting maximum aperture of lens+converter is smaller than f/5.6.
Dave
http://www.rosser.pwp.blueyonder.co.uk
http://www.pbase.com/dgrosser
 David Rosser's gear list:David Rosser's gear list
Panasonic Lumix DMC-LC5 Sony RX100 III Nikon D40 Fujifilm X-Pro1 Fujifilm X-Pro2 +10 more
Kim Letkeman
Yes, that issue has been pounded pretty well ... fact is, f6.7 is within the ability of the D70s to focus in decent light. Just not quickly. So I know that it is a stretch and is not going to be all that useful for firds in flight for example.
But for longer shots of animals that are not moving about at dizzying speeds, I look forward to being able to work with the 1.7x ...
Yes, from what I've seen it should work ok in good light. I'll probably end up with the same solution for long reach "on a budget".
What are the alternatives at 500mm ? Tamron 200-500 or Sigma 50-500, both cheaper but worse IQ, and the Tamron does not have AF-S.
Any other solution is more than twice as expensive, more likely three times
Cheers
Mike
Kim Letkeman
UPDATE
My new D2Hs arrived today ... no problems with the 300 F4 AF-s + TC17e ... this makes sense as the whole thing is now being driven by about a half pound of battery.
It will take a while to get used to this combo, but I must say that it focuses very positively with any light at all ... very cool.
Needless to say ... I will not be sending the lense to Nikon at this time. I can easily live with restricting my use of the TC with the D2Hs, since that was a significant reason for acquiring it (among many others of course.)
