1D3 English manual download link
Started May 26, 2007 | Discussions
Danny Brenner Senior Member • Posts: 1,500
To all who are witing for the 1D3, like myself. Here's the link for downloading the 1D MKIII English manual:
http://www.brenner.co.il/mark3_manual_en.pdf
brianric Veteran Member • Posts: 8,916
Thank you. NT
Thank you.
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
Ben_Egbert Forum Pro • Posts: 20,228
Did I read this right?
the mirror lock up can be assigned to the set button? Around page 169.
Also a bit disapointed that the AF micro adjust section is thin. I expected Canon to supply targets (PDF or JPG) and instructions for use, like distance etc. Maybe they are still in denial that there is an AF problem. Or maybe AF is just not that accurate and critical focus will always require manual focus.
 Ben_Egbert's gear list:Ben_Egbert's gear list
Canon EOS 5D Mark III Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm f/2.8L IS USM Canon TS-E 17mm f/4L Samyang 14mm F2.8 ED AS IF UMC +1 more
webdog Regular Member • Posts: 331
Re: Did I read this right?
Read page 104 for full explanation1
CFIII-15-2 will enable mirror lock up if pressing the shutter once, aditional presses will take picture but mirror stay in lock-up position.
set button will release mirror!
Thomas Isler Regular Member • Posts: 153
Only center AF with 70-200 f2.8L USM + extender
See page 85. Wonder if there are AF problems with non Canon lenses as well.
Only the non IS version is mentioned though. So hope the IS one should be fine.
Thomas
http://thomasisler.members.winisp.net/
Canon 2oD, Canon 4ooD
Marianne Oelund Veteran Member • Posts: 7,788
SET button functions
See manual p. 110, describing use of the SET button to initiate Live View, which is one type of mirror lockup. For other programmable SET button options, see p. 174, C.Fn IV-4.
AFS Senior Member • Posts: 1,996
Re: Only center AF with 70-200 f2.8L USM + extender
as well.
should be fine.
Also the 3 outermost cross sensors on the left and right don't function as such with 2 wide primes
Terminal case of Lens Lust.
Nikon and Canon gear
DeeDee G. Veteran Member • Posts: 4,707
Link no longer works???
OP Danny Brenner Senior Member • Posts: 1,500
Re: Link no longer works???
Sorry, but i had to take the file off my web site due to overload.
Mahamane Kanoute Forum Member • Posts: 58
I can host it if you want ?
Willa Veteran Member • Posts: 7,328
Oh, GAWD what a tease! The link doesn't work! :( NT
Re: Oh, GAWD what a tease! The link doesn't work! :( NT
I know. I was already excited, but what a big disappointment. Hence the offer to host it, at least for some time.
daytontp Veteran Member • Posts: 3,738
It worked for me
Re: It worked for me
Would you share?
Thanks,
I have no where to host it legally (nt)
Dayton in SC USA
http://www.dtpphoto.com/
bullet1 Veteran Member • Posts: 7,322
Can you email it to me?
My email address is: mdx1a@yahoo.com
Thanks!
Nelson Chen
http://pbase.com/nelsonc
100% RAW shooter with Capture One Pro
Photos of Italy: http://www.pbase.com/nelsonc/italy
 bullet1's gear list:bullet1's gear list
Panasonic FZ1000 Canon PowerShot G5 X Canon EOS 6D Canon EOS M5 Sony a7 III +21 more
Rob Kircher Veteran Member • Posts: 3,451
Re: I have no where to host it legally (nt)
How big is the file?
Rob Kircher
My Stuff: http://www.pbase.com/rkircher
I have some room on a shared host. I could put the file there, at least for a while.
Ghozer Veteran Member • Posts: 3,863
Please do
That would be very much appreciated.
least for a while.
 Ghozer's gear list:Ghozer's gear list
Nikon Coolpix P7000 Canon PowerShot S100 Canon EOS 5D Mark II Canon EOS 7D Canon EOS-1D Mark IV +10 more
5567KB (nt)
Dayton in SC USA
