Carl Zeiss lenses: Reviews by Photozone
Started Apr 8, 2007 | Discussions
amarkin Regular Member • Posts: 372
Carl Zeiss fixed focal length lenses have been reviewed by Photozone. All 3 of them. And all have received average and below averages reviews. What's more is that these lenses are MF and cost twice as much as everything else in that range.
CA on 50mm f/1.4 suprised me. Of all companies, one would think Carl Zeiss could have produced a better 50mm lens.
What do you make of these reviews?
http://photozone.de/8Reviews/lenses/zeiss_zf_25_28/index.htm
http://photozone.de/8Reviews/lenses/zeiss_zf_35_2/index.htm
http://photozone.de/8Reviews/lenses/zeiss_zf_50_14/index.htm
http://photozone.de/8Reviews/lenses/zeiss_zf_85_14/index.htm
Nikons: D50, N80. Nikkors: 20-35 f/2.8 AFD, 50mm f/1.4 AFD, 85mm f/1.8 AFD
Kent J
Kent J Senior Member • Posts: 2,378
What are you reading?
averages reviews.
Did you READ them?
Not that I necessarily put a lot of stock in these testers, but how in the WORLD did you come up with "average or below average"?
50mm:
"In fact the Zeiss beats all comparable Nikkors and sets a new (center) resolution record on the D200. It is quite safe to state that the Zeiss easily outresolves the 10mp Sony sensor. "
25mm:
Similar to the Zeiss 50mm f/1.4 the Distagon produces breathtakingly high center resolution figures straight from the max. aperture setting. At f/4 and f/5.6 the center quality matches or exceeds the limits of the 10mp D200 sensor. "
35mm:
"Quality-wise the Zeiss Distagon ZF T* 35mm f/2 is a little superior compared to its its sister lens, the Distagon T* 25mm f/2.8, and it easily outperforms the corresponding Nikkor AF 35mm f/2. The resolution in the center is about as good as it gets on the Nikon D200."
85mm
"The price tag of the Zeiss comes almost as a surprise - at 1200 € US$ it costs about the same like the (optically slightly inferior) Nikkor AF 85mm f/1.4D. If you can live with its manual focusing approach you don´t need to go any further - highly recommended! "
-Kent
Life is too short for slow glass.
http://www.pbase.com/kjoosten
 Kent J's gear list:Kent J's gear list
Nikon Df Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G Nikon AF-S Nikkor 300mm f/4D ED-IF Carl Zeiss Makro-Planar T* 2/100 +15 more
OP amarkin Regular Member • Posts: 372
Re: What are you reading?
I've been reading the results. Now, what have you been READING?
THe conclusions only?
Check out on CA, vignetting. Yes, the lenses, especially the 50mm is sharp. But where it is sharp? READ the chart. I don't think these are better than Nikkors: 50mm 85mm AFD even though it Carl Zeis is sharper at the centre at several f stops. Plus, these are mF lenses.
MarcV
MarcV Veteran Member • Posts: 4,000
Optically superior or not, I'll never understand why they couldn't just include the simple screw driver AF mecanism...
Marc Vandenhende
 MarcV's gear list:MarcV's gear list
Panasonic LX100 Panasonic LX100 II Olympus XZ-1
Kent J
amarkin wrote:
I don't think
The review SAYS they are better. Again, I don't put any particular stock in these reviewers. I'm only reading back what the reviews say and pointing out that you are concluding the opposite.
50mm:
"The price tag of the Zeiss is almost surprisingly affordable at 499EUR (about 650US$) ... which is still twice the price of the corresponding Nikkor AF lens which is only marginally inferior. "
85mm:
"The price tag of the Zeiss comes almost as a surprise - at 1200 € US$ it costs about the same like the (optically slightly inferior) Nikkor AF 85mm f/1.4D."
When the reviewer say the Nikkors are slightly/moderately INFERIOR, I think we can conclude they think the Zeiss are slightly/moderately SUPERIOR. I'm not trying to state my opinion here, I was just confused that you would post links to these reviews, and then conclude the opposite.
Each person has to conclude what is important to them in lens characteristics and whether that makes one particular lens "better" than another. Vignetting and 1.2 pixels of edge CA on a wide angle lens are not that big a deal to me. High center resolution and build quality are. And yes, these are expensive lenses, so if you want to sacrifice optical quality for cost, making it a "better" lens for you, that's fine, too.
Yes, they are. If that is a deal breaker, why even be concerned with optical performance?
Now, this IS my opinion: I actually own the 1.4/50mm Planar and found it optically better than the 1.4/50mm AFD Nikkor which I subsequently sold. Manual focus works for how I wanted to use the lens and I was willing to pay the price for it.
By the way, here's a quote from photographer Roger Hicks in this Month's Shutterbug (on reviewing the Zeiss 2/50mm Makro-Planar, the 2/35mm Distagon and the 2.8/25 Distagon):
"If you still like "real" manual-focus SLRs, these lenses are as good as the best ever made, and better specified than most of the best ever made."
-Kent
Kent J
...plus CPU chip, plus electonic contacts, plus cams instead of focusing helixes....
-Kent
Xiaomage Contributing Member • Posts: 546
principle of the thing
Zeiss can do AF, as we can see with Sony/KM lens releases. They're not doing it with the ZF because the ZF lineup is targeting a different market. Sure, the nostalgic crowd may not be the biggest market, but it definitely does have its following. The reasoning may come from a few different sources (economical, legal, etc.), but the end result is what it is.
To put in an AF screw with enough slop to be useful on consumer DSLR motors would detract from the simplicity and perceived precision of manual gimmick-free lenses that largely appeal to the folks who still use the FM2 and F3. I agree with this approach, though electronic meter coupling would have been a cool touch (akin to the 45p).
People bitch a lot about these lenses without buying or using them. Yes they're expensive. No they're not perfect. Get over it. Buy them if you want them and don't buy them if you don't. It's not that complex. Nikon (the company that makes the cameras that people on this forum usually talk about) also happens to make a few nice lenses which are often cheaper (except the 85/1.4 Nikkor which is about the same or slightly more expensive here than the 85ZF).
I don't own a ZF yet, but I may in the future--particularly if they offer something compact and unique. I like their lenses, but they don't really offer anything I want yet (in terms of focal length and size).
Robert.
Idealism is precious.
MarcV
Re: principle of the thing
I think they could sell a lot more if they would just add AF and metering...
to the 45p).
and size).
Robert.
Marc Vandenhende
BasilG Veteran Member • Posts: 9,599
Re: Carl Zeiss lenses: Reviews by Photozone
From these reviews, it's clear that Klaus absolutely loves those lenses. I don't know why you read the reviews the way you do...
BG
not everything
Not everything needs to be about sales. Yes they're nice to have when playing the justification game, but I don't think Zeiss is banking much on the ZF line (if you want Zeiss AF, Sony's got 'em). Nikon has offered lots of oddball products and limited releases with high price tags in the past (rangefinders anyone? UV Nikkors? FM3a and 45p? tip of the iceberg...), so these days when Nikon is whoring itself out more to the consumer market, it's nice to see a company offer something that stands out as not being clearly intended for the masses.
Robert.
For a RF camera I'd buy Carl Zeiss lenses. For a DSLR - no.
PS: I don't know why people are making fuss about my comments. I have
read many technical reviews for different lenses from different manufactuers.
I don't even need to read a conclusion, often the data from the tests is enough to see lenses' pro & cons.
Of course, data from various sources has to be collected and looked at. The images themselves need to be examined too.
Anyway, I think MF lens from Carl Zeiss is for a niche market.
Pavel S Regular Member • Posts: 159
Sample pictures - superb lenses!
Looking at the sample pictures incuded in the "test reviews", I dare to say the lenses are really good. I do not see any particular issue with the CA. It is there, but well under controll.
I would like to see some more "artistic" pictures though, to reveal the lenses "character" in full.
fpessolano
fpessolano Veteran Member • Posts: 4,165
Question to owners
For who has both the 25 and the 30, how do they compare?
From photozone (first shot) I see quite some CA on the 25 ... which is the only one I was looking for replacing my dear AIS 28 (despite the look out f the lenses seems quite different).
Francesco
webpage: http://www.thefoodtraveller.com
 fpessolano's gear list:fpessolano's gear list
Panasonic Lumix DMC-TS30 Nikon Z7 Nikon Z50 Nikon Z9 Ricoh Theta V +1 more
And there was never any doubt about it. Same with Leica M8...
anotherMike Forum Pro • Posts: 10,464
They can't just add the AF - my understanding is that:
a) while the basic Nikon lens mount is in public domain, the AF part of the mount is not and Nikon did not license them that.
b) they (Zeiss) were getting some interest in folks who used manual/film Nikons and were concerned about the availability of Nikon manual focus lenses at the time a year or two ago that Nikon announced that most of the MF line were being discontinued. That means there's a potential market - users of MF lenses with updated designs. Example: if you have an FM2 body, even the new and amazing exotic 200/2 AFS VR ED G won't be of much use on your body - it has no aperture ring. The 105/2.8 VR macro - same thing. Your choice is either one of the older MF nikons or one of the Zeiss ZF designs.
There is a place for a niche player in lenses - the Zeiss offers a choice - if you want the feel of a MF lens (an AF lens by nature of AF has to have a different MF feel) and want a definite different rendering of things in terms of image quality (note I did not say better, I said "different" - my view currently is that some of the ZF lenses are worth looking at and some are not at all better than the comparitive offering from Nikon) then the ZF line is definitely an option for you.
-m
ddk Veteran Member • Posts: 3,661
Licensing
I asked Zeiss's US director about AF, F mount lenses and he said that Nikon wont license them.
david
I think that amarkin is envious...
david
BG
Re: Question to owners
Color & contrast is almost identical between the two. The 35mm is sharper but I find 28mm's fov has other uses. The 25mm focuses incredibly fast, it just needs a touch, making it ideal for street & faster paced photography. Here are a couple of comparative samples, I should mention that aside from some mild usm applied to the eyes, I don't sharpen the images in or out of camera.
35mm
http://www.pbase.com/ddk/image/76005912
25mm
http://www.pbase.com/ddk/image/76007027
I haven't come across any serious CA with either one. You should realize that CA has to do with the camera sensor as well. The same lens will return differing results when it on different cameras. A few months ago someone had posted some 35mm images with really bad CA, I did the following test shooting against the sun to test CA for myself. You be the judge, the 25mm is very similar to the 35 in this respect on my camera, Fuji S5. I posted these images up on another ziess thread before but here they are again:
100% crop
david
Francesco
fpessolano
My case is D200 and the 25 looks really interesting. I saw you previous posts and I quite like what I saw from most zeiss, apart from the 85 (personal taste).
I should get to try the 25 myself I guess and decide.
Thanks.
ahh ... BTW do you use the standard Fuji or have you got something like the Katz Eye to it?
Francesco
Re: Thanks
I wonder what it is that you don't like about the 85, here are a couple different from what lowfreq's images, again no sharpening or pp of any kind besides downsizing, out of camera jpegs:
http://www.pbase.com/ddk/image/75974891/original
http://www.pbase.com/ddk/image/75974876
Thanks.
I don't like split screens, never did. I installed a matt Katz Eye screen in my S3 but I honestly don't see any difference, which to their credit KatzEye did warn me before purchasing. I find S5/D200's screen & finder with the DK-21m eyepiece adequate if not ideal. There's also Brightscreen that offers a wider range of screens, I had one with microprism center installed in my Kodak slr/n but I found it more difficult to focus than the original matt screen. I mostly shoot portraits and I found anything in my line of vision very annoying, including all the focus/metering boxes in fov.
david
Francesco
