AF-ON how many use it and what are it's merits
Started Mar 12, 2007 | Discussions
michael Regular Member • Posts: 273
I would be interested on how many of you use this button and why ?
Michael
http://www.pbase.com/yube
http://www.shuttercity.com/ShowGallery.cfm?AcctID=1854
John Cote Senior Member • Posts: 1,523
You be in control..not the camera
Michael
Michael,
If you use the shutter button, you need to press an AF lock button or the camera will refocus when you take a photo. I want the camera to be focused on what I focus it on. Not some high contrast area it likes near what I want of a fence behind the subject.
Switching focus to the AF-ON button and off of the shutter button means that after I take my finger off the AF-ON button, focus is locked. When I take the picture the camera can not re-focus.
To me, focusing and taking are two different functions. I do not want the to happen together with the press of a single button.
It takes a while to get used to this but once you do, you will never switch back. It also allows you to manually tweak the focus with AFS lenses and not have the camera refoucs back to where it had mis-focused originally.
IT ALLOWS YOU TO BE IN CONTROL.
John Cote
http://www.johncotephotography.com
'Cameras are just cr@p we have to lug around because there is no direct brain to printer connection...yet!'
 John Cote's gear list:John Cote's gear list
Nikon D850 Nikon Z9 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
Foxie Contributing Member • Posts: 935
I use it all the time...
...been discussed here often. Depends on your way of working I guess. In my case, I only use the centre AF-sensor and with AF-ON I can focus to any subject, keep it in focus (button pressed) and re-frame and then make the picture without refocussing.
CHEERS!
Nigel_L Regular Member • Posts: 102
Re: AF-ON how many use it and what are it's merits
Here is an example: You have a long zoom and are waiting for that "special moment" when your subject does something memorable.
You can pre-focus on the subject (using the AF-ON button) and then press the shutter release as soon as you see the "special moment". The advantage of this is that pressing the shutter release takes the picture immediately - will not cause the camera to try and update the focus - thereby possibly missing the pic.
Advantages - great when you do not want your camera to hesitate (to update focus) before taking the picture and you can pre-focus on the general area beforehand.
Disadvantage - it is easy to forget that you left your camera in "AF-ON" mode especially if you are using a wide angle lens. You can then end up with a whole bunch of images that are not properly focussed.
Regards, Nigel
jonathanHodd Regular Member • Posts: 267
what john said
fantastic tool for sports photography. definitely wierd to start with, but doesn't take long to get used to.
RangerJoe Contributing Member • Posts: 975
Most of my pictures are of my kids' sports activities and I'm having a difficult time wrapping my brain around this.
Could you (or someone) describe a sports scenario where you would use this feature along with your "workflow" for capturing a scene?
RangerJoe
winnie Veteran Member • Posts: 4,224
I am new to the D200 but am I right in thinking then that once the AF-ON is set as the only focus mechanism via the menu's, you only have to press that once to focus. You don't have to keep your finger on the AF-ON button?
Is this what I should be testing works with my Sigma lenses? I read that they sometimes have to be re-chipped.
Cheers
Alex
http://www.alexwinserphotography.co.uk
Jim Carr Senior Member • Posts: 1,532
Always on
I always use the AF-on button to focus.
Having learned photography on manual cameras it only seems natural to have focus separated from the exposure reading.
Jim
 Jim Carr's gear list:Jim Carr's gear list
Nikon D200 Nikon D500
Vieri Bottazzini
Vieri Bottazzini Veteran Member • Posts: 6,995
I do, all the time
My usual setting is AF-ON, and AF-c (continuous focussing). This way I can keep track of my subjects if I want to, and have shutter/metering completely separate. Works great once you got used to it, I would never go back. Best regards,
Vieri
 Vieri Bottazzini's gear list:Vieri Bottazzini's gear list
Hasselblad X1D II 50C Hasselblad XCD 21mm F4 Hasselblad XCD 135mm F2.8 Voigtlander 15mm F4.5 Super Wide Heliar Hasselblad XCD 35-75mm F3.5-4.5 +2 more
Thomas Comerford Veteran Member • Posts: 9,745
Yep, although if you're using AF-C you might want to keep pressing AF-ON in certain cases.
With the original D200 firmware you'd have to half-press shutter + AF-ON for HSM lenses. The new firmware fixed it.
Cheers
Alex
kenwilkes Regular Member • Posts: 465
great info... thanks
RangerJoe
Joe,
Kid's field sports, or anybody's field sports are where this technique really shines. The thing you need to look at is the percentage of perfectly in focus photos you get now, and how many of your out-of-focus clicks are the result of the camera being in focus...just not on what you wanted it to focus on. This technique is all about YOU being in control...not the camera. Being in control usually means that you have to do a little more work but it means that your work will pay off in better results.
If you use the AF-ON button, the way it should be used, you will have to be thinking about focus all of the time. You will have to be watching focus in the viewfinder. You will have to be looking for situations which will fool AF, like chain link fences in the background and players running in front of your main subject. You will have to learn when to to let your finger off of the AF-ON button and when to put it back on.
Just think of it like this...taking your finger off of the AF-ON button is like having a focus lock.
John Cote
focussed.
Nigel,
This is only a disadvantage if you keep changing from using the AF-ON button back to using the Shutter Button for focus. If you just get used to using the AF-ON button to focus...all of the time...this is not a disadvantage.
John Cote
Re: what john said
Thanks, John!
Does it go something like this? Say I'm shooting kid soccer with AF-C, AF-ON and using the center sensor. Press and hold the AF-ON button. Since I'm using AF-C, then the AF is continuously working/focusing. At the moment of peak action, say a header, then release AF-ON and press the shutter?
On paper, it "sounds" awkward; however, I will definately give it a go this weekend!
RangerJoe
Gordon Chau Regular Member • Posts: 248
Use AF-ON for D2 but not D40
I use(d) AF-ON for reasons listed for D100, D2H and D2X.
In my latest, the D40, the AE/AF button also serves as "protection On" during the instant playback/review. In continuous shooting mode, the effort on the button trying to focus would instead produce a "protection-on" action during the instant playback. So I cannot use the button effectively for this purpose.
Gordon Chau
Kabe Luna
Kabe Luna Veteran Member • Posts: 9,502
Because I like having AF separate from shutter release.
This is an idea I'm glad Nikon and others have taken from Canon–in fact going one better with a dedicated control for it. I detest cameras with AF coupled with the shutter release, and in fact this is the one thing that drove me to Canon so many years ago.
Michael
 Kabe Luna's gear list:Kabe Luna's gear list
Canon EOS R Canon EOS R5 Sigma 50mm F1.4 EX DG HSM Sigma 35mm F1.4 DG HSM Art Canon EF 16-35mm F4L IS USM +9 more
jaba Contributing Member • Posts: 879
I activated the option to have the focus only on AF-ON when I bought my 70-200 VR and realized the VR was working continuously when I was pressing the shutter just to have the viewfinder in focus.
Apart from the reasons above, this allows you to uncouple VR from AF and save some hard-earned batteries...
 jaba's gear list:jaba's gear list
Nikon D800 Nikon Z7 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF +19 more
kevm14 Senior Member • Posts: 2,253
focus.
But doesn't VR need a moment to stabilize itself? Like, about the time it takes to auto focus? I agree on the battery thing though...
johnnymcclung
johnnymcclung Senior Member • Posts: 2,657
Re: You be in control..not the camera
John, forgive me for not simply reading my own D200 manual but i have a question -
does that mean the AF-ON button while held down is essentially AF-C, and as soon as you let go it locks focus - then you can take your shot?
John Cote wrote:
Michael
Michael,
'Procrastinate now, don't put it off.'
 johnnymcclung's gear list:johnnymcclung's gear list
Canon EOS 5DS R Canon EOS R Canon EOS R5 Canon EF 24-70mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM +8 more
jeff-c Senior Member • Posts: 2,096
Re: Because I like having AF separate from shutter release.
Since when Canon has a dedicate AF-ON button?
In fact they just add this button first time to their newly released EOS-1D Mark III due to popular demand.
Contax has been using this for long time.
 jeff-c's gear list:jeff-c's gear list
Sigma DP3 Merrill Nikon Coolpix 990 Nikon D700 Nikon 1 V1 Nikon D50 +26 more
