K10D - Systematic Focus Problem - Quality Control Issue?
Started Feb 21, 2007 | Discussions
Genes Pentax Senior Member • Posts: 1,044
Hi all,
I'm rather frustrated with K10Ds ... what would you do?
PROBLEM: Front focusing on TWO (2) K10Ds shipped directly from Pentax.
DILEMMA: Whether to order another (3rd) copy of K10D to see whether it'll be any better (or strike out), or just return both K10Ds for refund and just live with my DS until a even higher quality Pentax is released.
I really like the faster focus and controls on K10D. Also, I got a great price on the K10D (Anyone interested in a new K10D + a kit lens for $850?). So, I'm rather reluctant to part with it. But on the other hand, I am rather disappointed with the focus accuracy issue. Besides, because my DS produces very good pictures also, I am not sure whether further hassle with K10D is worth it for now.
SITUATION:
1. I first purchased a K10D about a month ago. Serial number 231XXXX. But I noticed that it was having a front focus issue. So I bought another one before returning the first one to see how the first one compares with another copy of K10D.
2. I received the 2nd K10D today. Serial number 236XXXX. The front focusing problem is worse on this one.
3. Both K10Ds were shipped directly from Pentax in Golden, Colorado.
4. I took the same picture with my ist DS to make sure it's not my lens.
What do you think?
Gene
TEST SETUP:
1. FA 50/1.4 @ f/1.4
2. Tripod, center focus, SR off on K10Ds.
3. Distance from the target: about 50cm and about 20 cm above the plane.
4. The horizontal lines are 2cm apart.
5. From left to right: K10D (copy 2), ist DS, and K10D (1st copy)
Focus on the intersection of two lines, one of which is marked with an "x."
Focusing on the line further away....
SFT007 Veteran Member • Posts: 5,855
Re: K10D - Systematic Focus Problem - Quality Control Issue?
I think its a common problem with K10's = mine would FF too - did you try adjusting the AF through the debug menu? Its a shame Pentax cant get the AF issue right on this camera - especially since it seems fine on other Pentax's. I dont really believe anyone that says there is no AF problem with the K10 - there most certainly is and therea have been many many comments about focusing issues with the K10 and most of them warranted - mine would FF just like your two copies did there, unfortunate but true. I still love the K10 - I just have to adjust the AF when im shooting indoors or at worst leave it at a value like -40 for all around use (since in daylight im likely to use smaller apertures so DOF will cover the slight BF that I will get by setting -40).
Sinan
 SFT007's gear list:SFT007's gear list
Olympus XZ-1 Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Leica Summilux DG 25mm F1.4 +3 more
OP Genes Pentax Senior Member • Posts: 1,044
Debug menu? What debug menu? Where is it? Did it solve your FF problem?
I wonder whether anyone sent their K10D to Pentax for warranty repair and how it worked out.
Alfisti Veteran Member • Posts: 6,649
It is the lens
There are dozens of threads showing the FA50 front focussing, dozens.
Fanboys here will deny everything and say it is user error (we are all idiots apparently). Others will say that AF is a gimmick and they only use MF, I also assume they get about on horse and cart as well.
Learn tolive with it or switch. I still cannot make up my mind. If the D80 was smaller and 6MP rather than 10, i'd just about jump ship because this AF business is ridiculous.
Please visit my gallery at http://www.pbase.com/alfisti
Pentax Lens examples at http://www.pbase.com/alfisti/images_by_lens
I did. It came back a little better but the process was harrowing (a complete balls up, morons the lot of them). Shipped to the wrong address, idiot reception girl, no notes on what they changed, unable to talk to the repair person ... freakin nightmare.
problem?
wlachan
wlachan Veteran Member • Posts: 6,759
Forgive me if I miss something but I am about to sleep and didn't reading everything. But to keep it brief, DON'T test AF accuracy with any 45 degree target. This test is flaw by design. The reason is that the actual AF sensor covers a wide area, and its actual placement might not be dead centre. If you must, test it on 2D target which is perpendicular to the camera. Also, don't draw any conclusion based on 1 lens only.
Alan Chan
http://www.pbase.com/wlachan
blende8 Senior Member • Posts: 1,494
Yes there is an AF issue under tungsten light.
I predict that you did this under tungsten light.
If you repeat the test under normal daylight, it will be (about) ok.
This issue has been confirmed by many users so far. It appears to be a special K10D issue. There is no real solution or explanation yet.
The only workaround is to use the (inofficial) service menue and use correction values.
wlachan
CR.K. I presume? Yeah they suck.
Alan Chan
Sorry Alan, what is CR.K?
Alan Chan
No the K100D does it too, I feel it is morwe the FA series lenses causing the grief.
blende8 wrote:
It appears to
yet.--
wlachan
causing the grief.
But all my FA lenses AF fine with my DS.
Alan Chan
wlachan
CR Kennedy.
Alan Chan
Julian324 Regular Member • Posts: 140
What is service / debug menu???
Heard about it many times, but can ' t manage to find info ...
wlachan
Re: What is service / debug menu???
Have fun!
http://forums.dpreview.com/forums/read.asp?forum=1036&message=22013971
Alan Chan
Bronek Regular Member • Posts: 204
now, that's a thought! I actual plan to do it (mine has strong back focus with 77 Ltd) but part of me resist parting with the camera ...
please tell where? US, Europe?
Laurens Senior Member • Posts: 1,391
Use the infamous Nikon test chart
http://www.focustestchart.com/focus21.pdf
rather than the chart you have. Your camera may have an AF problem, but your test method is flawed. The AF area is ca. the size of the centre ( ) on the DS and may be slightly offset. We must assume that anything in focus in the AF area is deemed "in focus" by the camera.
FWIW I have focus problems with some of my lenses (DA21, DA40), but my FA50 works well under all light conditions. What is the shutter speed/ISO?
Laurens
Genes Pentax wrote:
Hi all,
Pentax.
SITUATION:
lens.
What do you think?
Gene
TEST SETUP:
plane.
an "x."
tootal2 Regular Member • Posts: 132
You Know if you set your f-stop higher the whole page will be in focus. Its called depth of field.
What a tool of a comment.
Re: It is the lens -- I don't think so....
I'm a Pentax fan also, but a rational one.
If it's the lens, then my ist DS should've been out of focus also. But as you can see, it is not.
Also, although I've not tested with my FA 43 on the diagram, but from the pictures I've taken, the K10Ds do have the problem.
well.
