self focus adjust for dl,ds,ds2,k100d.
Started Feb 11, 2007 | Discussions
M.S. Shin New Member • Posts: 4
hi,
Here's come How-to-adjust dl, ds, ds2, k100d!!
I can't find exact source of this, because it is wide spreaded.
If your pentax camera scribed above have problem with focus, you can adjust it yourself.
And Of course, You yourself is responsible for doing something scribed below.
STEP
1. Power OFF
While pressing [AE-L]+[INFO], turn the camera on.
Firmware is desplayed on LCD.
Press [MENU]-> [MENU]-> [INFO] within 5 seconds.
You can see DEBUG mode screen.
By pressing [Right key],Make [DEBUG MODE DIS] to [DEBUG MODE EN].
Then, Press [OK].
2. Press [MENU], you can see setup menu.
By pressing [Up key], select AF TEST.
By pressing [Right key], go into AF TEST menu.
By pressing [Down key], select FOCUS CORR.
now you can adjust shift amount by pressing [right key] or [left key].
( Don't touch AF Area Test.)
after changing the value, Press [OK] to save.
3. Test your camera that Focus is corrected.
(repeat step 2. till you satisfy the result.)
4. Power OFF
By pressing [Right key],Make [DEBUG MODE EN] to [DEBUG MODE DIS].
Then, Press [OK].
5. Go out and enjoy!!
Again, You YOURSELF is responsible for doing this process.
Russ Houston
Russ Houston Veteran Member • Posts: 6,377
That's great!
Thanks for posting this! I can't believe I haven't read of this before, especially on here.
Gold star for you!
Russ
http://www.flickr.com/photos/rfortson/
Even bad photography can be fun
 Russ Houston's gear list:Russ Houston's gear list
Olympus OM-D E-M5 Olympus PEN E-P5 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +7 more
pjv Senior Member • Posts: 1,319
Tagging for 'My Threads' [nt]
No text.
Nols Senior Member • Posts: 2,997
I'm a coward when it comes to these things
Then again, my Ds still works perfectly after 2 years. Thanks for posting!
Nols
'Ask not what your camera can do for you...' (oh well, you know how this ends)
bluwing Regular Member • Posts: 212
Re: self focus adjust for dl,ds,ds2,k100d.
Hi,
Thank you for this information, But you for got one model.... The original the istD. That is unlessthis works on the D also..
Thanks again
bluwing
No one is listening, Untill you make a mistake.
mutleybird Senior Member • Posts: 1,095
Its confirmed that it won't work on the K10D?
Or is the method the same?
Re: Its confirmed that it won't work on the K10D?
Dunno if it's the same but he made a separate post here:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=22013971
Nols
salv Regular Member • Posts: 282
Good info to know! Thanks! (nt)
Have you ever noticed if someone calls you a 'monkey' it's an insult, but if they say you came from a monkey, that's 'science'?
Edvinas Senior Member • Posts: 2,812
Has anyone already tried that?
Edvinas
 Edvinas's gear list:Edvinas's gear list
Nikon D3S Nikon D600 Nikon D700 Pentax smc FA 77mm 1.8 Limited Pentax smc FA 31mm F1.8 AL Limited +5 more
sinahua Forum Member • Posts: 93
great!
M.S. Shin wrote:
hi,
scribed below.
STEP
1. Power OFF
Then, Press [OK].
4. Power OFF
Then, Press [OK].
blackcoffee Forum Member • Posts: 94
Thanks for the info.
Rome L.
Stovepipe Forum Member • Posts: 52
Hey look, no screwdriver required
You probably couldn't see it, but I did my Happy Dance just now.
I'd been waiting for my DL's warranty to expire before I was going to try the mechanical adjustments that have been posted here before.
But I went ahead with this, and in the first couple of tests was able to get obviously improved autofocus on my FA50/1.4 wide open. I don't have any other AF lenses with such wide aperture so don't think it can throw others off significantly. Besides, to be honest, the50mm seldom comes off the camera.
Doesn't seem this should void a warranty, but right now I almost wouldn't care if it did. Nice that I know how to put it back if I ever need to. Pretty easy.
Thanks!
sorinat Regular Member • Posts: 155
Right after turning the debug mode on, when I pres MENU, I have a 'waiting HS' message on the screen and nothing happens...this is on my DS...does anyone has the same message?
-Sorin-
http://sorinat.blogspot.com
barneycg Regular Member • Posts: 239
Also works on GX-1S
Yep.
Also to add to the body of knowledge ... this also works on ver 1.00 firmware on the Samsung GX-1S firmware.
TUT Forum Member • Posts: 73
Omit the OK button after selecting DEBUG MODE and go directly to press MENU.
TUTAN
superakuma Contributing Member • Posts: 594
tagged for future reference
Lance B
Lance B Forum Pro • Posts: 34,204
As a matter on interest, what about the D?
Not that I have a focus problem on my *ist D, but there maybe some that do. Is there a focus adjustment for the *ist D? As far as I know there is no mechanical adjustment, so maybe there is a software adjustment.
Lance B
http://www.pbase.com/lance_b
GMT +10hours
 Lance B's gear list:Lance B's gear list
Nikon Z7 II Nikon Z9 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Nikon AF-S Nikkor 400mm f/2.8E FL ED VR Nikon AF-S 105mm F1.4E ED +19 more
tc333 Veteran Member • Posts: 3,967
Thanks....hope this makes my spot focus point more accurate. Though i am sure it will affect all the other focus points too....for bad or for worse
Tony
 tc333's gear list:tc333's gear list
Panasonic Lumix DC-GX9
ogl69 Contributing Member • Posts: 688
Wait HS camera are working in engineer mode all the time
yes..camera are working in engineer mode all the time.
point 4 doesn't work
Power OFF - yes
While pressing [AE-L]+[INFO], turn the camera on. - yes
No I see this
http://forum.ixbt.com/post.cgi?id=attach:20:20473:1378:1
No reaction.
Re: As a matter on interest, what about the D?
As for repair back focus at 77 and 43 - I made it.!!!
-10 in this menu
http://forum.ixbt.com/post.cgi?id=attach:20:20473:1378:2
  • and all is perfect.
But how can I exit from engineer mode?
Help me...^))))
