Firmware for K10D IS here...
Started Jan 18, 2007 | Discussions
Cibalius Regular Member • Posts: 122
... only in my Inbox so far, but I do hope later this evening I'll have it in my K10.
Received it today from our Pentax rep, thanks once again Darko !
So, it'n no hoax and there's no delay.
New functions are exactly as stated in previuos posts these days, wireless flash included !
Enjoy your Pentax, bye, Ivan.
 Cibalius's gear list:Cibalius's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 30mm F3.5 Macro
logan ross Regular Member • Posts: 440
Re: Firmware for K10D IS here...
I do not see it on the Pentax Website. Where did you get it from?
Pete Dee Veteran Member • Posts: 3,759
Sure it is!
Wanna buy a bridge?
If winning isn't everything, why do they keep score?
  • Vince Lombardi
 Pete Dee's gear list:Pete Dee's gear list
Pentax Optio W80 Pentax K-3 Pentax smc DA 16-45mm F4 ED AL Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Tamron SP AF 90mm F/2.8 Di Macro +4 more
Re: Sure it is!
not from you.
OP Cibalius Regular Member • Posts: 122
As I said, I received the mail from Pentax rep this afternoon with firmware and information about upgrade inside.
It's 2 megs file, named "Firmware_Update_101.exe".
For those who doesn't believe, your problem. I'm not a boy wanting publicity, I just wanted you to know that firmware DOES exist and is ready to be announced.
Why there is no information on Pentax site, I have no idea, but their reps seem to have the thing and send it to us who ordered our K10's directly from them.
mactrash Regular Member • Posts: 488
New functions list please
 mactrash's gear list:mactrash's gear list
Pentax K10D Pentax K20D Pentax K-3
David Martin Forum Pro • Posts: 17,056
Good job it's not a Sony upgrade...
..or your camera might explode!
No doubt that the upgrade will be posted on thePentax website in the next couple of days, making some of the cynics look pretty foolish, would be my guess.
DaveMart
'Just a wildebeest on the plain of life'
Please see profile for equipment
Steveo T Regular Member • Posts: 471
Firmware upgrade is NOT available
If you got a pre-release from someone at Pentax, good for you. If it is not available to the general public than it is NOT available.
Copy / paste:
Firmware Version 1.10 for K10D
The following function has been added in version 1.10
① Wireless control of external flash through built-in flash.
How to set
  ・Press Fn button and four way controller key ( )
・Flash mode selecting screen display
・Select Wireless mode
・ Flash discharge method can select by [ Flash in Wireless Mode] in the custom menu
1 ON Built in flash works with master
discharge
2 OFF Built in flash works with controller
discharge
・ HS(High speed sync)in not available
・ Select SLAVE 1 in Wireless slave mode when use
AF540FGZ or AF360FGZ
How to use: Same as using two external flash, refer to the operating manual
② Instantly return to centre AF point by one push of button in AF select mode.
[Center of AF Point] is added to the AF function
In the custom menu
When AF point switching dial set to “SELECT”,
AF point is set to Center
③ Possible to change ISO setting by dial at TV/AV mode.
④ ISO setting change by dial while the ISO setting is being displayed on the LCD by pushing OK button.
・ ISO setting is being displayed in the view finder and on the LCD panel when setting the P/Tv
Av/M/B/X mode and then ISO can change by turning e-dial.
・ Possible to change to AF ISO by pressing green button in P/Tv/Av mode.
⑤ Green button function in M mode is available at TAv mode (Hyper manual).
・ Tv/Av value can set automatically when press green
button in TAv mode.
With this change, the name of [Green button in M] change
to [Green button in TAv & M] in the custom function
⑥ AV and TV switch by dial at P mode.
The item No.2 is added to the [e-dial in Program] in Custom menu.
With this change, Av can change by front dial and Tv can change by rear dial.
⑦ Instant return to the default value by green button at strobe light compensation.
PENTAX Corporation
Re: Firmware upgrade is NOT available
Would you be so kind to show me where did I stated that it is "available" ?
I've said that I've got it, I didn't mention anything about public availability. But it will be available very very soon, that's for sure...
roybin Regular Member • Posts: 154
Does it resolve the banding problem?
Martynas_ds Regular Member • Posts: 223
Would You mind sharing this file? for example through the email.
Mine is undisclosed in the profile
Sorry guys, have no idea about banding yet and have that firmware only in the Inbox of my Outlook so far.
Just wanted to share the information with you and ease up the waiting. I'm going home now and I'll try to upgrade. Just hope that it will not end up like that K110 a couple of threads bellow...
Greetings everyone.
Enjoy your Pentax !
Stig Vidar Hovland Senior Member • Posts: 1,785
Greetings everyone.
Enjoy your Pentax !
There is always some risk at upgrading, but I think most people will try this one. Are you a beta-tester
OK, I'll try to send it - but just for you Martynas_ds, or I will really end up sending mails all night long if all of you guys want me to the same thing. And this IS one big forum, I'm sure
Uh, nothing against beta testing software, but beta testing 1000 euros camera, brrrr...
gyhelle New Member • Posts: 7
The solution is to send it to 2 peoples who will send it to 2 peoples each etc.. etc..
Martynis_ds, I've just send it to you.
If there are others interested ( are there ? ), please be so kind and forward it, especially if you have flat rate DSL...
Bye, Ivan.
Or just wait until it's official. Can't be that important to gain some few hours, can't it?
SV
Many many thanks, Ivan, I will try to upload it into somewhere
