Tutorial: Adding Datestamp to all pictures using Irfanview
Started Jan 9, 2007 | Discussions
coenocyte Regular Member • Posts: 395
Here's a quick way to add datestamp to all your photos using irfanview for output of 3mp...you may need to change x/y coordinates for different output resolutions.
1. Go to http://www.irfanview.com and download the most recent version 3.99.
2. Open any image
3. File--> Batch conversion/rename--> advanced option.
-RESIZE: SET LONG SIDE to 2048 (3mp image)
-PRESERVE ASPECT RATIO
-RESAMPLE
-MISCELLANEOUS--> ADD TEXT OVERLAY--> SETTINGS
--X COORD = 50; WITDH = 300.
--Y COORD = 110; WITDH = 300.
CHECK = RIGHT BOTTOM
TEXT = $T(%m/%d/%Y)
$T(%m/%d/%Y) uses exif file to insert month/day/year. look in help file for further modifcaitons.
FONT SIZE = ARIAL 36.
FONT COLOR = RED
TEXT ALIGNMENT = RIGHT.
SAVE AS JPEG 90% OR ABOVE.
gvar1965 New Member • Posts: 1
Re: Tutorial: Adding Datestamp to all pictures using Irfanview
Excelent! I have been able to build a timelapse placing time of each shot over 1500 shots! Evenmore, I  was able to reduce the size of each file in order not to have to work with 25Gigs of jpegs files!
 gvar1965's gear list:gvar1965's gear list
Nikon D750
