2 Important K10 Issues that need to be settled for good!! (Please read!)
Started Jan 5, 2007 | Discussions
OP SFT007 Veteran Member • Posts: 5,914
Re: Hold on that Ketchup until
Mine is focusing just fine - in fact its fast and sure in its lock even wide open at F1.4. Are you sure there isnt something wrong with yours?
My DA18-55 kit lens is by far the worst at the wide-end (and I would expect it to be) and my DA50-200 is also very good just like the FA50 with the freshly charged battery.
In fact my DA18-55 is front focusing quite slightly at the wide-end but not by much- but now I know its not a camera problem - though I have found a workaround which is to zoom in fully to 55mm lock the focus at that focal lenght and zoom out to 18mm - works like a charm - and I definetely get better results that way than at locking focus at 18mm - though it is also much much better than before - so it seems it really was a battery issue and not a camera issue - the 18-55 FF at 18mm is due to the lens I am sure (or I hope!) I will see how my Sigma 18-50 f2.8 fares compared to it once that arrives.
JeffJS wrote:
you get a little more exposure with that FA 50 1.4.. Being one of
the first lenses I purchased after deciding to go Pentax Dslr (see
sig for which one), I was very anxious to try it out. I've noticed
several situations, particularly dark room lighting, where this
lens Hunts A LOT for a focal point. Sometimes gets it right,
sometimes not. I doubt it's the camera because the Kit lens, that's
right, the 18-55 slow, cheap, kit lens nails it almost everytime.
The Tamron 70-300 Di also nails it almost everytime. Not only that
but the exposure is right with the kit lens. I'm not knocking the
FA 50 per say, but for what it cost, I did expect better from it.
I've noticed too that it seems to consistantly underexpose by a
full stop, full battery or not. That's using autoexposure modes,
viewing the histogram after the photo is taken. Again, this isn't
really to knock the lens because I do get nice results from it, but
I can match or better the performance with my SMC-M 50 f1.4. I'd
gladly trade the FA 50 1.4 and some change for a nice SMC-M 50 f1.2.
http://photobucket.com/albums/v285/jjmel
Still happy with the K10d (in spite of the pixel peepers)
Sinan
 SFT007's gear list:SFT007's gear list
Sony a7 IV Sony FE 70-300mm F4.5-5.6 G OSS Sigma 85mm F1.4 DG GN Sony FE 35mm F1.4 GM Sigma 28-70mm F2.8 DG DN +1 more
Re: 2 Important K10 Issues that need to be settled for good!! (Please read!)
Trust me - the battery life made a HUGE difference. A difference like night and day in fact - I also read that the SR is not as effective once the battery life is close to being diminished so I guess its important with an SLR to keep your battery healthy - this wasnt the case with my little compact F30 so I always used it until the battery died - I wont be doing that with the K10 and I will probably order a spare battery sometime soon then.
Sinan
Thanks for the info Rupert
Thanks Rupert - glad to see that the Green button in M mode is not very reliable - that wasnt my major problem since It always acts in the same way I know how much to compensate it by when shooting with the M - it was the focusing issue that was getting to me and Im very glad that having a fully charged battery made a world of difference and now my FA50 is focusing like a champ!
Rupert60 wrote:
No focus problems.
The Green button when used in M mode is absolutely worthless.
Worked perfect on my DS. I expect Pentax to repair this one way or
another, probably firmware?
'This is more serious than I thought.....but it is still fun!
http://www.pbase.com/rupertdog Take a look- It's Free!
Sinan
JeffJS Senior Member • Posts: 2,886
I may not have explained it as clearly as I could have.. When the lens focuses, it focuses just fine. In fact, they all do. I've not noticed any front or back focus issues with any of them. Either they are dead on, or I can't figure out what spec of dust in the air they chose to focus on. Because when the autofocus photos are out of focus, they are WAAAAAY out of focus. Not just a little bit but focused at infinity on a closup subject. It seems to happen more with the FA50 than the rest. It may be because that's the one I paid the most for. This is only in certain conditions however, dark indoor room, as stated previously. I haven't had a lot of chance to try it outside. With respect to the exposure, I actually prefer a little underexposure. Coming into DSLR from B&W film, expose for shadows, process for highlights.
I will freely admit that I'm still learning how to use this new medium (to me) called DSLR and many of my problems could be user error. In my mind, I'm sometimes the first to accuse (though I rarely put it into writing) someone of blaming the equipment rather than the operator when problems pop up with our beloved Pentax gear. No, I don't think there's anything wrong with my copy, I'm probably expecting too much from it. Quickly Autofocus on my black lab in a dark room for instance. Like I said, Some situations......
How big is the AF point?
I see what youre saying - that was exactly what was happening when my battery was low - I couldnt even tell what the hell it was trying to focus on.
Im actually curios as to the size of the AF point. How big is it? Is it exactly the size of the red box that lights up - is exactly there - or is it a little bigger than that?
Sinan
Brett St Pierre
Brett St Pierre Veteran Member • Posts: 7,036
Jeff
here is a comment that gets debated occassionally and I am not convinced but it has some merit...
.. AF rwquires a degree of subject contrast for the AF system to get enough data to process a lock, you see this when you try to focus on a flat object like a plain wall, it just won't do it. The FA50/1.4 images at f/1.4 produce very low contrast, it doesn't start to get normal lens contrast until stopped down f/2 or more (but not as bad as say the 50/1.2) - it's just the nature of a very fast aperture lens. What is the very low contrast of the lens (because at AF time it is wide open) disadvantages the cameras AF system to get sufficient contrast in certain conditions?
Just an idea... would the out-of-production FA50/1.7 be better in that regard? (don't know, I sold mine to get the f/1.4 version and I had had no trouble with either but then i don't put them under any AF stress, i MF in tricky conditions)
Brett
http://www.pbase.com/shreder
The Journey is the Thing
 Brett St Pierre's gear list:Brett St Pierre's gear list
Pentax K-1 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA 21mm F3.2 AL Limited +7 more
paulkienitz
paulkienitz Veteran Member • Posts: 5,461
Re: Well Hot Damn! I will eat my words :)
There'd been speculation before that the poor AF performance in lower light might be happening when the batteries are low... and now you've nailed it down. That's good to know. We've also heard that the SR gets weak when the battery is low. So I guess the battery life statement should say, like, "300 shots with full performance, 400 more shots with reduced performance".
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
I would say thats a very fair assestment - the AF performance seems to go down quite rapidly actually and I woudlnt be surprised if your figures are dead on!
Ive already taken like a few hundred test shots since I charged the battery and already I can see the AF starting to be more hit and miss! It was very sure when I first took it out the charger with the battery full but now its not as good and I bet if I take another 100 shots it is going to keep on getting worse. Its interesting though that it affects it in indoor lighting - shouldnt this in theory also affect it in good outdoor lighting too? I am going to throw my battery in the charger again now and leave it overnight and after I get back from work tomorrow see again how it does with the full charge - I think this theoruy may be correct though - up to around 300 shots and then from there it starts to be hit and miss and then by the end of the life completelly miss! I wonder if it starts missing if the battery is almost dead in daylight too? I havent tested this.
Sinan
lock Veteran Member • Posts: 6,202
Can it be the battery ?
Most of us have no problems outdoors. At least to some degree the lower temparature will take some of the juice out of the battery. Still, nobody complains outdoors. If you are correct, then why does nobody complain outside in lower temperatures ?
lock
Jan Moren Veteran Member • Posts: 3,745
Re: Can it be the battery ?
As a guess: going outside, at night, at "lower temperatures" (read: winter) to take pictures happens less than playing around with the camera at home in the evenings. Going outside in the dark and cold and specifically play around with autofocus performance happens much, much less than horsing around indoors.
And at least I make sure to have an empty card and a full battery whenever I actually go outside with the camera. I guess most people do the same. Which of course means you'll remove the possible fault of a rundown battery.
XavierP56 Contributing Member • Posts: 941
Re: Cideway & Jan and others
Beware : In A Mode on the aperture ring, you can use MATRIX metering.
With M Lens (or A Lens but not on A on aperture ring), CENTRAL-WEIGHT is used, whatever the exposure mode switch is on.
So, if you want to comapre things with a lens in A setting on the aperture ring, please set the metering to CENTRAL-WEIGHT !!!
If not, you are comparing apples to oranges.
Could be the case in Sweden, but I do not think it's very much an issue in y country. Actually, if it gets cold enough to stay inside, everyone runs outside to get a glance of the ice and snow. Many pictures are taken then. But the fact is indeed that nobody tried it. But that could be caused by the fact that incadescent light ven in low light outdoor situations is usually not the major light source. But we could try it in low daylight situations close to a conventional lamp.
Before I can do that kind of testing (it's about +10 Celsius) I will first have to get the K10d ( this afternoon). But I think I will not suffer from the problem since it looks like something that does not affect the DA zoom lenses and the Sigma 17-70.
The thing is, both charging and using them works best at room temperatures. At higher or lower temperatures both charging and using will be worse. Storing them however works best in cool places !
lock
D TONG Senior Member • Posts: 2,559
LBA FA50mm ; why manual focus ???
Sinan Tarlan wrote:
D TONG wrote:
We look forward to see some of your LBA pict. Apparently you like
the lens a lot.
It is really fast in focusing. Why did you use manual? Very unusual
indeed
I will most definetely shoot some pics with the lens soon and post
another set.
I like the lens a lot since I love the M 50mm f1.4 I own and this
is practically the same lens but with auto focus, etc.. So I
naturally love this one too. Its the M in modern form in a plastic
body and the focusing is still nice and smooth - but not nearly as
smooth and it doesnt have that heavy feel of the focusing action of
the M of course.
I used manual focus because I had to - It doesnt focus on what I
want it to focus on with AF and I used manual exposure testing the
exposure with the green button in M mode because I encountered this
problem when I was using the M 50mm too so I wanted to see if it
was a lens problem (aperture blades old, misadligned, etc.)
That does not make any sense. Did you use spot focus? You are saying you have to do manual focusing on your FA50mm 1.4. Its focus ring is not meant to be top notch
http://www.pbase.com/danieltong
Does this not simply mean..
...that the battery supplied is simply too weak ? And yes, it would suffer from misfocus as well in nomral light as well. Especially in low light outdoor conditions. Can you check this ?
Btw, there are stronger batteries available for the k10d ( heard of 1850 mAh).
lock
David Martin Forum Pro • Posts: 17,056
Info on stronger batteries?
have you got any names for brands and so on that would fit the K10D?
Thanks!
1850 mAh).
lock
DaveMart
'Just a wildebeest on the plain of life'
Please see profile for equipment
I was always comparing in non-A setting, which always sets the camera to central weighted average automatically.
PentaxNick Senior Member • Posts: 1,835
Under exposure in M Mode
does the amount of underexposure depend on the aperture set? I was just thinking it could be that the camera is taking the reading before the aperture has completely stopped down.
Nick
 PentaxNick's gear list:PentaxNick's gear list
Ricoh GR Fujifilm X100T Olympus Tough TG-4 Ricoh GR III Olympus PEN-F +12 more
Dana G Contributing Member • Posts: 627
Re: Great to hear...
I keep two batteries, with the camera set to "grip first". If I have any low-battery issues, I remove and charge the grip battery. Then I put it in the camera and switch the other one to the grip.
So far, seems to work like a charm!
'We have met the enemy, and he is us!' - Walt Kelley
Re: Under exposure in M Mode
It changes with the aperture.
But, it changes exactly the same as if the camera tries to adjust both aperture and exposure according to the program line. But since it can't adjust aperture, the exposure goes wrong. Exactly how much, and whether it becomes over- or underexposure depends on the ambient light level. But you get consistently identical results to when you use program line; it's pretty clear it's what is effectively happening.
Thanks Xavier - I was aware of this and I did all the tests in average and not matrix.
Sinan
