Teleconverter to use with 100/400 f/4.5-5.6L IS
Started Jan 1, 2007 | Discussions
Tony Dunn Regular Member • Posts: 216
I have the 100/400L, which is a great lens that I use with my 20D, and I'd like to get some more reach without laying down several grand. A TC seems the obvious solution.
But according to what I've read, autofocus won't work with the 100/400L using the Canon 1.4x TC. But I've also read that the Canon 2x TC (which apparently autofocus WILL work with) sucks, image quality-wise.
I haven't had good experiences with third party TCs in the past, but that wasn't with a Canon.
Any advice here? Image quality (sharpness) is my top consideration, and I really need autofocus. Is the Canon 2x really that bad? Are any of the 3rd party TCs any good? Will AF work with them? What do you recommend?
Tony Dunn
http://www.adunnphotography.com
misha Forum Pro • Posts: 18,768
Re: Teleconverter to use with 100/400 f/4.5-5.6L IS
quality-wise.
Not correct on both counts - image quality with the 2x can be good, but not with the 100-400, which is too slow, and not sharp enough (it works best with sharpest primes like the 300/2.8 L). AF will NOT work with the 2x and 100-400.
This lens can AF with a 3rd party 1.4x TC or with the Canon 1.4x TC with some pins covered/taped.
Misha
OP Tony Dunn Regular Member • Posts: 216
According to the Canon website ( http://www.usa.canon.com/app/pdf/lens/Lens_Extender_chart_new.pdf - page 2), AF does work with the 100/400 - or at least it doesn't say that it doesn't.
Any particular recommendation on 3rd part TC? Do you know where I can get info on which pins to tape for the Canon 1.4x TC?
Tony Dunn
maratus Regular Member • Posts: 264
Taping pins:
http://www.michaelfurtman.com/taping_the_pins.htm
BTW
Link to your wildlife shots is incorrect
http://www.adunnphotography.com/galleries/index.asp
Your gallery is superb, good luck
Gautam Majumdar Forum Pro • Posts: 20,014
TCs with only 7 pin contacts will allow (theoretically) AF to work. These are cheaper versions of the third party TCs. Or get a Pro version TC, Canon or Kenco/Tamron with 10 pins & cover the last 3 of them. I use a Kenco 1.4 cheaper version TC and AF works only with bright light. But it slows down AF quite a bit. AF does not work at all with 2x TC which is also a 7 pin version.
Gautam
fredlord
fredlord Veteran Member • Posts: 3,306
You may find that the Canon 1.4X TC will not function with your particular camera even with the pins taped. Some do, some don't. People seem to have more luck with the 3rd party TCs that don't all seven pins and therefore don't report the aperture to the camera. I used a Canon 1.4 with the 100-400 on my old D60 which required manual focus. It did well as long as I did my part.
Personally, I have found that either Canon TC works well at extending focal length on my particular copy of the 100-400. It retains sharpness quite well with them. Remember, you lose one stop of light with the 1.4x and two stops with the 2x.
Sharpness results vary among lenses and those that make blanket statements about the efficacy of the combinations just haven't tried them.
In any case, autofocus is lost with either Canon TC on your camera so it is a moot point for your needs. I was not able to tape the pins and get it to work on my D60 and I have read of users with the same problem on later camera bodies as well.
Do a search on this forum and you will find instances where people have been able to use the non-reporting, 3rd party TCs on their 100-400 while retaining autofocus in varying degrees.
 fredlord's gear list:fredlord's gear list
Canon EOS R5 Canon EOS R7 Canon TS-E 17mm f/4L Canon EF 100mm F2.8L Macro IS USM Sigma 15mm F2.8 EX DG Diagonal Fisheye +13 more
discusjoe Senior Member • Posts: 1,685
Well, don't expect the AF to work as well with the TC, it just won't. The AF will work reasonably well in well lit conditions and it can be terribly slow (or not focus at all) and thus frustrating in low light. Using a TC is a cheap way to increase your reach but there are shortcomings as I have mentioned. I do believe you will also loose 1-1/2 f/stop if I'm not mistaken and a slight decrease in sharpness.
100% crop 100-400L IS @ 400mm
100% crop + Kendo 1.4X DG PRO 100-400L IS @ 400mm
Tape these 3 pins
Photography is a never ending tug of war in compromises.
  • page 2), AF does work with the 100/400 - or at least it doesn't
Maybe it does not say, but I give you a 100% guarantee that it does not work If a 1.4x does not AF, there's even (much) less of a chance of AF with 2x (because you lose 1 stop with a 1.4x and 2 stops with a 2x).
Misha
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Take a look at the second page again. There it clearly states a big unmistakable X (with side notice 4 for working IS), but AF operation is definately out of the question!
I have the 100-400L and tried it with several teleconverters. With a 1.4x (no matter what brand) I could only rely on manual focus (even with taped pins) on my 10D, 20D and 30D... With taped pins some sort of trial and error games start and might end up locking on some sort of target, but under normal circumstances heavy hunting will ensue and end in no AF lock...
regards
Karl Günter Wünsch
Visit my gallery at
http://www.fotocommunity.de/pc/pc/mypics/461808
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
Canon EOS 7D Mark II
irvine
irvine Junior Member • Posts: 41
hi i have the sane lens on a 3OD body
using a 1,4x converter you lose autocus unless you do the trick of taping the last three pins on the left of the converter as you look it it. It restores autofocus and is good in bright light, it "hunts: at lower light, Try i and see how it works for you
 irvine's gear list:irvine's gear list
Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EOS M3
bill hansen Forum Pro • Posts: 10,033
TCs will autofocus
Tony - Others may also have written this - There are two ways - two good ways - to get autofocus to work with the 100-400 and a TC. The combo can get some really good images and is well worth trying.
First of all, with the Canon 1.4 or 2 TC, you can tape the leftmost 3 contact points on the lens (the leftmost 3 as you look at the back of the lens, contacts near you, lens pointed downward). That works fine. Place a little piece of Scotch tape or similar tape ( not duct tape please!) on those contacts, and be careful mounting the lens, so you don't wind up with that little piece of tape inside your camera.
Second, and probably just as good (though there is some argument over optical quality) you can use the 100-400 with the Kenko Pro TCs, without taping the contacts at all.
In low light, autofocus will be a little slower. I like to "prefocus" as best possible, tapping the shutter button halfway a time or two before I actually want to take the shot.
Of course there will be some loss of image quality, but the 1.4 TCs are still capable of producing very good quality images with the 100-400.
The only other way is to spend the big bucks and carry that bazooka, the 500mm lens or longer, around with you.
Bill Hansen
Re: TCs will autofocus
works fine.
I think you will find that with a 2x TC, even with taped pins, the lens might autofocus only in extremely bright conditions.
Misha
no argument there
I'm sure that's true, since it would be an f 11 lens. In bright light, it would work. In dim light it would be difficult or impossible to manually focus an f11 lens.
I do have experience using the 100-400 with a Canon 1.4X TC in daylight which was not bright sun. It worked well. I wouldn't argue that focus was as fast as it would have been with out the TC, or that image quality was exactly as good. That would be silly. But the combo was very very good. For those who can't afford a 500mm+ lens or who don't want to carry one around, the 100-400 with TC works well. Photographers far better than I have used it and like it.
Bill
