Maybe K10's first "bug"
Started Nov 28, 2006 | Discussions
mikerigel Contributing Member • Posts: 755
Some of you might have read this already http://forums.dpreview.com/forums/read.asp?forum=1036&message=21047498
but I feel it deserves its own thread, especially if more K10 owners experience it, please post here if you do.
Now, I think it's not a true "bug".... it may be just a protection that won't let you do long exposure in Bulb mode if the battery is halfway depleted.
That makes sense if you think about the equally long "dark frame" the camera is taking after each exposure.
As I mentionned on the other thread, it happened to me again tonight, even though my battery was just charged this morning... it doesn't make sense...
Either way, it's nothing a firmware update can't fix.
Mike
 mikerigel's gear list:mikerigel's gear list
Pentax K-1
blende8 Senior Member • Posts: 1,494
Re: Maybe K10's first "bug"
I think it is a battery thing.
Unload/reload the battery say 5 times and try again.
Helmut Eder
Helmut Eder Contributing Member • Posts: 504
This problem sounds to me like a "voltage droop under high load" problem. In other words, the battery cannot supply the required sustained current for powering the camera, and then the "battery empty" sensor kicks in.
Not an easy firmware fix, as it would have to do with the internal impedance of the battery. Would be interesting to see if this happens when supplying the power through an AC adapter or external power supply.
Just my opinion of course.
-Helmut
mvb123 Veteran Member • Posts: 3,302
auto shut off?
Maybe the auto shut off is set to 30 seconds and it doesn't check whether a picture is being taken? If the auto-shutoff is set to 30 seconds you could try to change that and see what's the effect.. I know, it's not very probable.
Menno
eyore New Member • Posts: 14
Re: auto shut off?
Mike,
Perhaps the camera isn't too keen on running out of puff with the mirror up, half way thru a shot? And perhaps that may also be due to your battery still getting to its advertised half-life (being brand new I'm sure!).
Inghard Ehrenberg
michael przewrocki Senior Member • Posts: 2,350
right, when fresh, battery will only give best power after 4-6 first loadings. at least for nimh.
http://www.europanorama.tk
3d-stereo-aeropanoramas
SWISS ALPS like never before!
3d-stereo-marspanoramas
Bronek Regular Member • Posts: 204
Mike, do you have SR on? It might be consuming some power while taking exposure, you know.
OP mikerigel Contributing Member • Posts: 755
Al right, I'll wait then and make further tests.... I hope you're right
Mike
Pentax K-1
Re: auto shut off?
Yes, the auto shutt off was on when I did my first 15min test... the camera is smart, it knows when it's taking a picture... so I guess that's not the reason.
Mike
Pentax K-1
Yeah I know but no, I don't have it on , since i'm on a tripod.
Mike
Pentax K-1
So what are you saying ? that we can't use the camera's B mode ?
Why would they include it if the battery can't supply enough power for it ? I never had that problem with my Ds and crv-3...... sigh....
power supply.
It should be fine with the AC adapter but that's not always practical when you're in the field....
thanks Helmut.
Mike
Pentax K-1
Richard N. Allen Senior Member • Posts: 2,001
I hope this is an isolated problem or one that can be simply corrected.
Has anyone contacted Pentax about the situation (I'm hesitant to call it a problem yet)?
Does it happen with the BG2 (with battery aboard) is used in conjunction with the K10D?
Pentax *istD & K10D + Sony F828 & H5
Richard
http://www.pbase.com/richarda/galleries
GMT/UTC-6 (-5 summer) Southern Great Plains USA
JensR Forum Pro • Posts: 17,971
Hi Mike!
Well, I remember some people stating/predicting/hoping that now with the supadupa cool LiIon technology, all battery issues would be gone.
Apparently, not...
Umm. #fingerscrossed#
BTW, was it cold at night, this might have led to premature exhausting of the battery?
Jens
'Well, 'Zooming with your feet' is usually a stupid thing as zoom rings are designed for hands.' (Me, 2006)
http://www.jensroesner.de/
--=! Condemning proprietary batteries since 1976 !=--
Joe Barnhart Veteran Member • Posts: 3,393
Happened to me, too
I also tried to take a picture with "B" for the astro interested people. I kept the lens cap on and triggered the shutter. 32 seconds later the shutter closes and the battery is flashing. I charged the battery, put it back in, and tried again. Exactly the same result with a freshly-charged battery.
I'm not too worried as I almost never take bulb pictures myself. But it would be inconvenient to need a power supply for long exposures -- especially for the astro people.
JensR wrote:
Hi Mike!
be gone.
Apparently, not...
same here...
Well, I'm in Florida.. does that answer your question ?
It was probably around 75 degres F, in the 20's range in celsius... not exactly cold.
Mike
Pentax K-1
Simon de la Court Junior Member • Posts: 46
You should mail Pentax asap, so if it is a real technical mallfunction they can easiliy fix this
JohnCPentax Contributing Member • Posts: 534
My K10D did this the first two times I tried a bulb exposure in the office this morning. It would only take a maximum 32 second exposure. However, after reading a post about the auto power off, I changed the setting and now the bulb mode works perfectly. I set the auto power off back to the default setting and it still worked properly from that point on. I have tried two other K10D's in the office and they are not experiencing this issue.
I will keep researching and keep you posted.
John C.
John C.
Thank you John for your input!
i will try again tonight with the "auto power off" turned off and see if it makes a difference.
See, I did a 15 minutes exposure 3 nights ago, and the "auto off" was on... weird.
Thanks again.
Mike
Pentax K-1
Re: auto shut off?
Instead of guessing you could try it out, doesn't take a lot of time..
Menno
Re: auto shut off?
Menno
You don't understand, I'm not guessing, I already did take a 15 minutes exposure with it ON and it worked, that's why I said that should not be the reason.
Mike
Pentax K-1
