24 inch iMac - interleaved memory and performance question
Started Sep 12, 2006 | Discussions
b.c. Senior Member • Posts: 1,479
the new 24" Core 2 Duo iMac has 2 memory slots and supports up to 3GB RAM max, see the developer note here:
http://developer.apple.com/documentation/HardwareDrivers/Conceptual/iMac_0609_SuperDrive/index.html
The spec says max performance is achieved with 2 same size/speed DIMMs in the slots to allow interleaved memory function - i.e. 1GB or 2GB configurations.
My question is this: does anybody know what kind of performance penalty there might be (if any significant) in a 3GB configuration, i.e non-interleaved 1GB+2GB DIMMs?
I guess we may know for sure in the coming weeks as more benchmarks come out, but I'm just wondering if anyone can guess - perhaps based on their knowlege of other Mac systems using memory interleaving, the difference with interleaving active and not.
I'm planning to buy a new 24" iMac to replace an old 17" G4 1GHz/1GB iMac which I currently use for Photoshop CS etc, and I assume with Rosetta the more RAM the better. So perhaps the better question behind this all is: performance-wise, would you think it's better to go for 2GB or 3GB, ignoring cost?
any opinions appreciated.
 b.c.'s gear list:b.c.'s gear list
Canon PowerShot S95 Sony RX100 III Canon EOS 5D Mark IV Epson Stylus Photo R2000
modsvsrockers New Member • Posts: 21
Re: 24 inch iMac - interleaved memory and performance question
The performance penalty is close to nil in real-world performance - and completely overshadowed by having an extra GB anyway.
MediumFormat Regular Member • Posts: 121
bc, I ordered a 24/2.33 this morning and also questioned the 2/3/4 gig situation.
What about a 2 gig in each slot?
uwe_r Veteran Member • Posts: 3,429
gig situation.
Due to limitations of the chipset OS X can only address 3 GB on this machine. You would pay for an expensive 2 GB DIMM for nothing, it will only use 1 GB of the second DIMM.
Uwe
 uwe_r's gear list:uwe_r's gear list
Canon PowerShot G15 Canon EOS 5D Mark III Canon EOS 70D Canon EF 14mm f/2.8L II USM Canon EF 24mm f/1.4L II USM +10 more
Rod Smith Contributing Member • Posts: 610
Re: Any references?
... or test results you can supply?
Rod Smith
Niceville, FL
erik hansen Contributing Member • Posts: 569
Re: Any references?
i don't have any specific links, but as long as dual-channel memory systems have been out, there has always been only a slight improvement in real-world benchmarks with matched pairs. synthetic benchmarks show that memory speed does in fact increase, but it doesn't translate to much in terms of real performance. i'm sure if you do a test on dual-channel memory benchmarks you might find some info.
Erik Hansen
Eug Senior Member • Posts: 2,779
Actually, it makes a huge difference...
Actually, it makes a huge difference, but generally only with systems which have integrated graphics. As you're probably aware it's because these machines depend on system RAM for performance. 3D performance on these machines improves dramatically when paired memory is used.
In most tests of machines with dedicated GPU memory though, the vast majority of popular apps show marginal improvements in performance. There are exceptions to that rule however.
info.
Erik Hansen
